Old May 16, 2011, 02:23 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
Nice , so maybe I could do without a booster ...I know you are not the expert on boosters but do you maybe have an idea why some booster were failling over time for some guys, maybe because they weren't using attenuators to lower the signal?
msev is offline Find More Posts by msev
Old May 16, 2011, 02:28 PM
Neo360 is offline
Find More Posts by Neo360
Joined Jul 2009
Alex,
Today i made 14km using this antenna on RX i'm glad with our antenna
Neo360 is offline Find More Posts by Neo360
Old May 19, 2011, 10:05 PM
Flightbox is offline
Find More Posts by Flightbox
Flightbox's Avatar
United States, OR
Joined Jan 2010
IBCrazy How are you getting the solder to stick to the galv sheet. Mine seems to break free real easy.
Flightbox is offline Find More Posts by Flightbox
Old May 20, 2011, 04:16 AM
tascheri is offline
Find More Posts by tascheri
Fly like never crash as always
tascheri's Avatar
Rio de Janeiro
Joined Mar 2007
You need a more powerful soldering iron!!
tascheri is offline Find More Posts by tascheri
Old May 20, 2011, 06:55 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Small torch
IBCrazy is offline Find More Posts by IBCrazy
Old May 20, 2011, 07:33 AM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
Originally Posted by IBCrazy View Post
Small torch
Same. Also - I found it helps to take some sandpaper and really rough / clean the area on the reflector. I have not had much luck using and iron...the small torch works well.
Blue Chip is offline Find More Posts by Blue Chip
Old May 20, 2011, 07:52 PM
Flightbox's Avatar
United States, OR
Joined Jan 2010
doesn't burn the outer cover of the coaxial??
Old May 20, 2011, 10:31 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
You need to tin the galvanized sheet first.
Take the torch and heat the plate until it accepts the solder. Remove the flame and then use the soldering iron to remelt the solder and bind it to the cable.
-Alex
Old May 21, 2011, 12:18 AM
Flightbox's Avatar
United States, OR
Joined Jan 2010
Thank you I finally got the solder to stick. Alex this 11dbi BiQuad is awesome its the best antenna I have used. I just need to figure out how to get a signal over head and a little behind. Thanks again
Old May 22, 2011, 01:03 PM
roadgraders is offline
Find More Posts by roadgraders
summitmk3
roadgraders's Avatar
United States, NE, Alliance
Joined Jul 2010
I bought one of your (IBCrazy) 900mhz BiQuad antenna from readymaderc. I know the beam is 50 degrees but for an example how wide is that actually at 300 ft or 1/2 mile for examples? Is there a chart to show this for the different types of antennas?
roadgraders is offline Find More Posts by roadgraders
Old May 22, 2011, 08:20 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
50 degrees is the -3db point.
Thus at the folowing angles the gain is as such:
0 - 11db
50 - 8db
90 - 5db
120 - 2db
Old May 22, 2011, 10:23 PM
summitmk3
Joined Jul 2010
0 - 11db
50 - 8db
90 - 5db
120 - 2db
I was talking about on how wide of path does the antenna cover at a distance, like for example 50 ft at 300 ft and so on?
Old May 23, 2011, 07:39 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
At 300 feet you can fly anywhere with the BiQuad. It will still pick up your signal. Use the angle geometry measurement I posted to get effective coverage capability.
In other words, if you are 25 degrees off center (edge of beam), your gain will be 8 dbi - equal to a patch antenna dead center.
If you go to 60 degrees off center, you will only have 2dbi gain - equal to a dipole.
I think that is the best way I can explain it.
-Alex
Old May 23, 2011, 09:02 AM
sawman is offline
Find More Posts by sawman
Air Crash Expert
sawman's Avatar
Louisiana
Joined Oct 2005
Trigonometry 101 http://villavu.com/forum/showthread.php?t=22334
But to answer your question, a 50 degree beam width will be 250 feet wide at 300 feet from pilot....2200 feet at half a mile...all approximate as many variations come into play.
sawman is offline Find More Posts by sawman
Old May 23, 2011, 05:03 PM
summitmk3
Joined Jul 2010
Thanks guys! Math is not one of my strong suits.
Build Log How To Build a BiQuad RX antenna Talajouy FPV Talk 21 Dec 22, 2010 11:52 PM
Question DIY Biquad antenna for a 900mHz Moosthegoose FPV Talk 5 Jan 14, 2010 03:37 AM
Discussion Antenna tutorial JIMOOO FPV Talk 1 Feb 25, 2007 12:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 04:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 08:05 PM
