Old Apr 04, 2011, 08:22 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by badlands View Post
Yea im hoping that works for me, my commercial patch works excellent near the ground, i was hoping my GP patch with its correct (larger) ground plane would work on a tripod up high but it sucked! (was ok on the ground thou)
All good fun testing gear thou...
Which is why I am developing an antenna replacement for a patch that is not ground plane dependent. I have the design done, I just need to build and test it. It's called the UniQuad... and you guessed it, it only has one quad square. It requires a matching stub to get it to work properly, though.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Apr 07, 2011, 01:15 PM
Zahnarzt is offline
Find More Posts by Zahnarzt
Earth's Mightiest Hero, KC9TBO
Zahnarzt's Avatar
United States, IL, Lemont
Joined Apr 2010
How do you like THEM elements? OK, element.
Zahnarzt is offline Find More Posts by Zahnarzt
Old Apr 07, 2011, 04:21 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The corners are a bit sharp. That's ok for RX, but in the TX this causes spurious emissions
-Alex
Old Apr 07, 2011, 05:27 PM
Zahnarzt is offline
Zahnarzt's Avatar
Joined Apr 2010
-Alex
Interesting. It will only be on the Rx side. For use on the Tx end, is there a formula that determines the length of the bend? Can you point me to a book I could read about this? Thanks!
Old Apr 07, 2011, 09:38 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I reference the ARRL antenna book: http://www.arrl.org/shop/The-ARRL-Antenna-Book/
Old Apr 07, 2011, 10:51 PM
scrtsqrl is online now
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
I just built one for my 2.4G video...Very straight forward build. Thanks for the awesome instructions.
It seems to work in the house. We'll see how it works in the air. LOLs.
The antenna is enclosed in a plastic sandwich tupperware container for some protection. Anyone see a problem with that?
Thanks again Alex!
JBB
scrtsqrl is online now Find More Posts by scrtsqrl
Old Apr 08, 2011, 02:46 AM
mark hitchman is online now
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
Thanks again Alex!
JBB
You wont be able to fit your sandwiches in
mark hitchman is online now Find More Posts by mark hitchman
Old Apr 08, 2011, 09:48 AM
scrtsqrl's Avatar
Joined Oct 2006
LOL...
Remind me again, theoretically, range doubles every 3dB?
Thanks.
Old Apr 08, 2011, 10:46 AM
chimaera is offline
Find More Posts by chimaera
THEY MOSTLY COME OUT AT NIGHT
chimaera's Avatar
Kaysville, Utah
Joined Jul 2005
See any problems with this? I'm going to try OMM's balun idea for multipath rejection. Admittedly I'm not well versed in this area, but I'm trying
chimaera is offline Find More Posts by chimaera
Old Apr 08, 2011, 10:54 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That only works for circular polarization, not linear. For linear it helps balance the antenna, that's all. The build looks great!
Old Apr 08, 2011, 10:55 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
LOL...
Thanks.
6db doubles range, 3 db doubles signal strength. You need 4X signal strength for 2X range.
-Alex
Old Apr 08, 2011, 10:59 AM
chimaera is offline
chimaera's Avatar
Kaysville, Utah
Joined Jul 2005
Somwhow I think I should have put that together. Told you I was ignorant Will it hurt or should I remove it?
Old Apr 08, 2011, 11:04 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Leave it. Any balancing of an antenna is a good thing.
Old Apr 08, 2011, 12:15 PM
Zahnarzt is offline
Zahnarzt's Avatar
Joined Apr 2010
Ahh. I have that one. Haven't found a section that directly address spurious emissions related to element geometry, even with a solid PDF search. If you have that earmarked, wouldn't mind knowing what section it is. Anyway, I picked up a biquad from Tim, and it arrived a bit beat up. That's why I made my own element in a freak spurt of free time while I happened to not be at work, and my 3mo old was sleeping!
Old Apr 09, 2011, 01:58 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The sharp bend issue is not outlined in the ARRL antenna book. It is in one of their other publications, though. I can't remember which one. However for an RX antenna, there are no spurs as it is only receiving a signal, not transmitting, so it's not a problem. In fact, the square geometry is just for ease. you can make it a circle, triangle, octagon, ect. It doesn't matter the shape so long as it is one wavelength and symettrical
-Alex
Build Log How To Build a BiQuad RX antenna Talajouy FPV Talk 21 Dec 22, 2010 11:52 PM
Question DIY Biquad antenna for a 900mHz Moosthegoose FPV Talk 5 Jan 14, 2010 03:37 AM
Discussion Antenna tutorial JIMOOO FPV Talk 1 Feb 25, 2007 12:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 04:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 08:05 PM
