Old Oct 25, 2010, 09:02 PM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
I have never tried building one of your antennas before but I think I will try this one for 2510 mhz. Thanks.
bracky72 is offline Find More Posts by bracky72
Old Oct 25, 2010, 09:50 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I take it the bowtie being horizontal provide the correct polarity for a vertical VTx antenna?
Vantasstic is offline Find More Posts by Vantasstic
Old Oct 25, 2010, 10:29 PM
etman is offline
Find More Posts by etman
Flying with the eagles
etman's Avatar
Eagle's nest
Joined Nov 2008
Wonderful! Subscribed.
etman is offline Find More Posts by etman
Old Oct 25, 2010, 10:33 PM
tom3holer is offline
Find More Posts by tom3holer
Cape Cod
tom3holer's Avatar
United States, MA, Barnstable
Joined Sep 2010
IBC,
Once again you have come up with that seems to be almost too good to be true.
One question if I may slightly off the subject. I am also on 900mhz and was wondering if you have done the "SAW" mod to your receivers and was it worth it. I have the new Saw filters already. I thought I read somewhere you did it and did not think it was worth the effort.
Tom
tom3holer is offline Find More Posts by tom3holer
Old Oct 25, 2010, 11:24 PM
Talajouy is offline
Find More Posts by Talajouy
Australia, QLD, Gold Coast
Joined Aug 2007
Alex, you must be a teacher, you are so patience to explain every thing and you do it well.
I made mine PCB base and I'm using it for a while, This antenna works just fine.
http://www.rcgroups.com/forums/showthread.php?t=1301126
Now Im planning to make a new one and use PCB for antenna element instead of wire, I mean to print the antenna element on a piece PCB, It would be neat.
Talajouy is offline Find More Posts by Talajouy
Old Oct 26, 2010, 04:25 AM
HF_ATL is offline
Find More Posts by HF_ATL
Portugal
Joined Nov 2009
All the dimensions remain the same using the pcb, galvanized steel or other material?
HF_ATL is offline Find More Posts by HF_ATL
Old Oct 26, 2010, 04:56 AM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
If using a tracker - is there any reason to have more than one of these? Seems like this on a tracker and a di-pole for close in would do the trick.
Blue Chip is offline Find More Posts by Blue Chip
Old Oct 26, 2010, 06:04 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Vantasstic - Yes, the bowtie should be flat, not upright. Look at Talajouy's.
Talajouy - I wrote the tutorial because the Martybugs tutorial wasn't that easy to follow or build. Your BiQuad is a work of art! My next one will be with a steel wire.
HF ATL - Any metal will work. Dimensions remain the same.
Blue Chip - This is a great antenna to use with a tracker.
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 26, 2010, 07:05 AM
Megafluffy is offline
Find More Posts by Megafluffy
Norway, Hordaland, Bergen
Joined Feb 2009
Hi IBC,
I see you run the coax trough the reflector and fold back the screen and then connect it to the reflector.
On many other bi-quads I have seen that they connect the screen when it goes trough the reflector.
Have you done any simulations (or reading) on which method is best, or if it is the same?
Megafluffy
Megafluffy is offline Find More Posts by Megafluffy
Old Oct 26, 2010, 07:46 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by Megafluffy View Post
Hi IBC,
Megafluffy
Actually, it doesn't matter much, but will make some difference. So long as the shield remains around the center conductor up to the connection point with the bowtie, it really makes little difference. However, you need to keep the shield from fraying. I suggest that if you use this method you solder all the way around the edge of the shield to keep it from fraying.
I simply ran my simulations based on my design.
On the other hand, many use a small copper tube to feed the coaxial line through. I did not do this simply to cut down on the amount of material needed. I made my design as easy to do as possible with minimal parts count. Future builds will be of a more rugged design. This unit was built for this tutorial and testing.
-Alex
Old Oct 26, 2010, 02:37 PM
JONBOYLEMON is offline
Find More Posts by JONBOYLEMON
Full disclosure, not sponsored
JONBOYLEMON's Avatar
United States, UT, American Fork
Joined May 2002
This looks like a doable build for me. Thanks in advance for all your work!!!!!!!!!!
JONBOYLEMON is offline Find More Posts by JONBOYLEMON
Old Oct 26, 2010, 06:52 PM
jhoexp is offline
Find More Posts by jhoexp
Italy
Joined Jun 2010
HI IBC,
already did myself a patch and many dipole following your instructions (and they are good!), now it's time for the biquad.
Is 10 AWG Iron wire any good for the bowtie?
What diameter is just righ with iron?
A piece of wood glued on the back is ok for mounting on the tripod/ tracker?
jhoexp is offline Find More Posts by jhoexp
Old Oct 26, 2010, 09:18 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
10 AWG is a bit excessive for anything over 900MHz. For 900 MHz, 10 AWG is fine.
You can use anything on the backside of the reflector to mount it so long as it is an insulator. And even then, it's not that critical.
-Alex
Old Oct 27, 2010, 11:42 AM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
I will be building this one soon. Couple questions... Does painting (light spray paint) have any discernible effect on performance? I am thinking flat black but would there be any benefit to a chrome/copper type paint?
techspy is offline Find More Posts by techspy
Old Oct 27, 2010, 01:13 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
None what so ever
Build Log How To Build a BiQuad RX antenna Talajouy FPV Talk 21 Dec 22, 2010 11:52 PM
Question DIY Biquad antenna for a 900mHz Moosthegoose FPV Talk 5 Jan 14, 2010 03:37 AM
Discussion Antenna tutorial JIMOOO FPV Talk 1 Feb 25, 2007 12:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 04:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 08:05 PM
