Sources for SS Turnbuckles and SS leader
Jim
For the leader contact: http://www.southcreekshop.com/AFW-Su...essLeader.html It comes in two different size rolls 30 and 300' be sure you order the matching sleeves to crimp the lines in place. American Fishing Wire Surflon 1X7 Stainless Leader C030T-0 30 lb Test: Diameter .024" - Length 30 ft - Color: Bright $3.59 American Fishing Wire Surflon 1X7 Stainless Leader C030T-4 30 lb Test: Diameter .024" - Length 300 ft - Color: Bright $26.09 or 45lb test American Fishing Wire Surflon 1X7 Stainless Leader C045T-0 45 lb Test: Diameter .028" - Length 30 ft - Color: Bright $3.74 American Fishing Wire Surflon 1X7 Stainless Leader C045T-4 45 lb Test: Diameter .028" - Length 300 ft - Color: Bright $27.07 Sleeves in order 30lb and 45lb 3 Bright C030T-0 S3, 4, 4L Bright C045T-0 The best place I have found for the SS turnbuckles is from sailetc.com (the manufacturer) or Denton Roberts @ Radio Yacht Supplies Australia at www.rysa.com.au email @ sales@rysa.com.au or radioyacht.supp@optusnet.com.au The turnbuckles on your Nirvana and my Yamaha are part number #030-030 are called rigging screws single end and he has them in stock $5.18each plus a little postage. I got 7 last order and it was $3.00 postage. I think he also sells the Pekabe 482 style as well. I included pictures of the items mentioned above. Boomer |
JD, String,
You guys are dedicated! Lowering from a pier, waders, man you guys a true sailors. I have got to see how you lower your boats from a pier. How high is it? Or is it more of warf? I admire your dedication. I attached a couple of pictures of the type of hard work we have to do to get our boats in to the water. ![]() Compared to what you guys have to do, seriously, we are so spoiled it is a joke. I don't know the temps are you boys will be sailing in this weekend, but it was 75* here today. I know, keep that kind of info to myself! Boomer
Sailing....
Beautiful lakes Boomer!!!! Ah the good life!!! Because of the shallow water at shore we lower from the dock carefully which isn't to bad. Retrieval is a little trickier but works.
Great here yesterday, also 75 *, light wind until later in the afternoon then about 8 to 10. Got my China Team in the water finally. Did well, have some sail issues to work out but sailed fine. My friends and my Seawind we were playing with also. Friends Seawind was just as fast as my China, no really speed difference yet. Time to race the VELA !!!!! ![]() Stringfly <>++++++ |
Vela, Seawind and China Team.....
Good day Sunday and nice winds. JD's Vela, Bruce's Seawind and my China Team. Some pictures. Me playing catch up most of the time but a good time by all.
Vela and Seawind doing great. China still in shake out mode, at least that's my story !!! ![]() ![]() Stringfly <>+++++ |
great time sailing the Vela, TT Team China, and Seawind today. All three performed competitively.
I had a couple of issues Im going to work thru. Still getting water in the hull. Either coming in from the hardware attachment points, hatches, or still thru the rudder/keel shafts. I'll find it eventually. Had my jib line port side of the mast. After sailing a port tack close hauled, then tacking starboard to the mark. I kept having an issue rounding the mark and setting sail downwind. My jib would not extend. Ended up my jib line kept fouling under the mast step. Getting pinched on the upwind legs of the course. Need to add a guide for the jib line near the mast step to keep this from occuring. I am sure the stay lines are still strectching some and I need to do a better job of adjusting the rigging each time into the water. No matter how I rig the lines, I can't achieve close haul on the main, and the recommended 80 degrees outhaul on the main/jib. Maybe replacing the sail servo/arm with a sail winch will improve the amount of sail travel we can achieve. Feedback or Suggestions welcome on this one. Boat sailed really good. Good acceleration and speed, headed into the weather really well Excellent attitude down wind and wing-to-wing. Held course with minimum to no helm input. More on the way the boat holds course. After sailing for a couple day trips, and extended time on the water today, As we were all heading to the weather mark, Vela was nicely traveling on her port tack close hauled. About the time I was ready to tack to Starboard on my lay-line, she didnt respond. Lost radio contact. She never luffed and sailed across the lake. She took on enough water, that the receiver either shut down (I need a can of CorrosionX. Hint Hint. Wink Nod), and/or the batteries, (energizer lithium) just ran out of juice. Tried another battery box and fresh batteries when I got home, but no communication between the TX and RX. I'll let it dry out and try again later. Great boat. And a mix of TT's, HK's, and the Vela should make a fun, well matched, class of 1Meter racing. JD |
Still using the Tactic 2.4 radio gear and servos that come in the boat. It all works well. Is all dried out and working normally again |
| Thread Tools | |
| Wanted wtb aquacraft ul1 boat!! | kremecheze | Boats (FS/W) | 0 | Oct 21, 2010 07:39 AM |
| Wanted Small aquacraft/futaba compatible RX | wparsons | Boats (FS/W) | 2 | Oct 15, 2010 05:19 PM |
| Wanted Aquacraft UL-1 Hull | jwg1978 | Boats (FS/W) | 24 | Oct 15, 2010 09:48 AM |
| Wanted Small aquacraft/futaba compatible RX | wparsons | Cars - Accessories (FS/W) | 0 | Oct 11, 2010 07:29 PM |
| Question ¿Alguien en Venezuela haciendo vela a radio control? | naufrago | Sailboats | 10 | Jan 06, 2009 03:23 PM |
