Old Jan 08, 2013, 05:40 PM
FourDollaRacing is offline
Find More Posts by FourDollaRacing
FourDollaRacing's Avatar
United States, OR
Joined Feb 2011
Try this thread for Tower Hobbies' coupon codes:
http://www.rcgroups.com/forums/showthread.php?t=1368076
Do note that most codes, posted by RCG members, are for Tower Hobbies "Super Saver" members:
http://www.towerhobbies.com/ssc.html
The yearly Super Saver membership can pay for itself with free shipping, and discounted purchases.
Discounts, for non-members (Tower), can be found on their home page:
Buying models from your LHS is a fair deal, too, because Hobbico and the retail store will absorb the shipping costs with the rest of their wholesale/bulk orders.
FourDollaRacing is offline Find More Posts by FourDollaRacing
Old Jan 08, 2013, 10:52 PM
Rssailor is online now
Find More Posts by Rssailor
United States, CA, Alameda
Joined Nov 2010
Osito,
Try the 110lbs spectra http://www.midwestmodelyachting.com/RiggingLine.asp
You could also use Item 210 with some turnbuckles. http://www.midwestmodelyachting.com/RiggingWire.asp
I use stainless wire for my uppers and spectra for my lower shrouds. Ryan
Rssailor is online now Find More Posts by Rssailor
Old Jan 10, 2013, 09:24 AM
osito is offline
Find More Posts by osito
osito
Joined Jan 2013
thank,s i talked with Greg at midwest and he said he would look at Vela and set me up with a rigging kit.
osito is offline Find More Posts by osito
Old Jan 14, 2013, 07:27 PM
osito is offline
osito
Joined Jan 2013
I got my boat today, had it in the pool.BUT i have a problem with the back stay hitting the top edge of the main sail ,What do i do ?
Old Jan 15, 2013, 01:58 AM
martin richards is offline
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
I'd think you'll have to live with it. The sail, when working is never in contact for the stay to affect the sail shape and, when jibbing, the obstruction is minimal.
martin richards is offline Find More Posts by martin richards
Old Jan 15, 2013, 01:48 PM
osito is offline
osito
Joined Jan 2013
fixed the sail problem, thank,s Rssailor.Now i,m sinking, taking on water, probable throught the keel post or rudder .What glue do i use to seal the keel post , rudder ?It would be nice to have a longer arm for the rudder servo.
Old Jan 15, 2013, 02:09 PM
sbales is online now
Find More Posts by sbales
Barstow, Ca
I use a small o-ring and water proof grease, "boat wheel bearing" I also use a small
amount on the rudder post. My boat is always dry.
Steve
sbales is online now Find More Posts by sbales
Old Jan 15, 2013, 03:36 PM
Joined Nov 2010
Leon
You need todetermine where the water is coming from. If from rudder shaft, take the ruuder off and grease the shaft with some teflon or silcon grease, then reinstall. If the keel or rudder shaft is leaking where they are bonded to the boat, then that's a differerent issue. Contact me offline about that if that is a problem. Where are you at? Ryan
Old Jan 16, 2013, 01:55 PM
ronnied is offline
Find More Posts by ronnied
United States, WA, Spokane
Joined Dec 2011
I have found that the best thing for keeping water out of my vela is the following. Take the keel of and brush the inset with vaseilne, replace the keel and tighten it. Then place some around the rudder and use a small rubber o-ring at the top of the rudder connection and the hull. You can also take a brush and apply some around the rubber seals on the deck openings. This has worked very well for me and I have found it is a cheap and easy fix. ronnied
ronnied is offline Find More Posts by ronnied
Old Jan 16, 2013, 04:04 PM
osito is offline
osito
Joined Jan 2013
water
that is what aquecraft said to do.BUT my boat was one day old and it took on alot of water.so it is being replaced buy the place i bought it from.
Old Jan 18, 2013, 06:03 PM
osito is offline
osito
Joined Jan 2013
i got the new Vela ,and not a drop or water !!
Old Jan 18, 2013, 06:33 PM
United States, OR
Joined Feb 2011
Come sail away....
Old Jan 18, 2013, 07:46 PM
Barstow, Ca
Good Deal
Old Jan 19, 2013, 09:55 AM
osito is offline
osito
Joined Jan 2013
If i increase the length of the rudder servo arm, will that increase the rudder angle ??
Old Jan 19, 2013, 07:42 PM
BrushlesHeaven is offline
Find More Posts by BrushlesHeaven
Lipo Power
BrushlesHeaven's Avatar
Joined May 2009
Yes...
BrushlesHeaven is offline Find More Posts by BrushlesHeaven
Wanted wtb aquacraft ul1 boat!! kremecheze Boats (FS/W) 0 Oct 21, 2010 07:39 AM
Wanted Small aquacraft/futaba compatible RX wparsons Boats (FS/W) 2 Oct 15, 2010 05:19 PM
Wanted Aquacraft UL-1 Hull jwg1978 Boats (FS/W) 24 Oct 15, 2010 09:48 AM
Wanted Small aquacraft/futaba compatible RX wparsons Cars - Accessories (FS/W) 0 Oct 11, 2010 07:29 PM
Question ¿Alguien en Venezuela haciendo vela a radio control? naufrago Sailboats 10 Jan 06, 2009 03:23 PM
