Old Mar 13, 2011, 07:03 PM
pandj888 is offline
Find More Posts by pandj888
Joined Mar 2008
hi all
what is the best or easy way to remove the graphics.
pete
pandj888 is offline Find More Posts by pandj888
Old Mar 13, 2011, 08:00 PM
STRINGFLY is offline
Find More Posts by STRINGFLY
STRINGFLY's Avatar
Little Rock Regional, Arkansas, United States
Joined Sep 2002
graphics......
Different boat !
Stringfly <>+++++
STRINGFLY is offline Find More Posts by STRINGFLY
Old Mar 14, 2011, 12:19 AM
Boomer1 is online now
Find More Posts by Boomer1
Boomer1
Boomer1's Avatar
United States, CA, Temecula
Joined Sep 2009
Originally Posted by pandj888 View Post
hi all
pete
Pete
I suggest placing a call to AquaCraft to seek their advise. The hull is fiberglass which has good chemical resistance, but the hull has been painted and I don't know what kind of paint has been used. There are a number of household chemicals that might help you remove the decals, with little or no chance of harming the finish.
Goof Off is one, some of the orange based adhesive removers might work. Using a hair dryer good help soften the adhesive that holds the decals on.
Hot water can work some times. Do a Google search on removing decals. I am sure there will be a lot suggestions for you.
There is always sand paper and new paint. Last resort.
Boomer
Boomer1 is online now Find More Posts by Boomer1
Old Mar 14, 2011, 09:07 AM
winch is offline
Find More Posts by winch
Joined Feb 2011
graphics......
Originally Posted by Boomer1 View Post
Pete
I suggest placing a call to AquaCraft to seek their advise. The hull is fiberglass which has good chemical resistance, but the hull has been painted and I don't know what kind of paint has been used. There are a number of household chemicals that might with little or no chance of harming the finish.
Boomer
Must be nuts... but was thinking of doing the same myself . (Just to add a more unique touch to my model..)
Fortunately I know someone in fiberglass and gelcoat repair on big boats that can airbrush any colour I want to change to.
Since it is made out of fiberglass.. wet sandpaper starting at 800 grit then moving up to 1200 or higher should do the trick.
Thinking of a royal blue hull ...
I also have mailed my sails to Rod Carr so he should have template for all future orders.
winch is offline Find More Posts by winch
Old Mar 14, 2011, 06:47 PM
ralphhager is offline
Find More Posts by ralphhager
ralph
ralphhager's Avatar
Antelope, CA 95843
Joined May 2004
winch: Could you explain wet sandpaper or “What is Wet Sandpaper”?
Thanks Ralph
ralphhager is offline Find More Posts by ralphhager
Old Mar 14, 2011, 07:24 PM
Boomer1
Boomer1's Avatar
Joined Sep 2009
It is sandpaper that is wet. Seriously there are types of sandpaper that are designed to be wetted, as you sand. Generally, the sanding surface is blackish and is in the finer of the grits.
Used to get the smoothest finish possible, also used in color sanding, again the sandpaper is dipped in water regularly. With the proper grit you avoid scaring.
Boomer
Old Mar 14, 2011, 10:08 PM
winch is offline
Joined Feb 2011
Thanks Boomer, You explained as well as I could. Most hardware stores have wet sandpaper and can explain how to use.
My new sails are on route to me ...still maybe a bit till I get out on water though..
Old Mar 15, 2011, 08:31 PM
pandj888 is offline
Joined Mar 2008
thanks boomer and all for the input. i will wet sand the decals off and repaint. it would be interesting seeing more then two boat on water sailing with the same graphics.
Old Mar 15, 2011, 09:17 PM
Boomer1
Boomer1's Avatar
Joined Sep 2009
Don't start sanding until all the other options have been tried
Wet sanding would be your last choice. The hair dryer should be your first approach, then the Orange based adhesive removers.
I can't image that you'd have to sand off those decals. There are many more easier ways and less intrusive to the process. Your guy will have to sand the hull before he paints it, but very lightly to prep it for the new paint.
It is always nice to see custom work done on boats that personalize them. The Vela is a good looking boat the way it comes, but it has been noted that the water line is not correctly placed. There are several ways to determine the actual water line. One method is the most obvious and requires you to put the boat in the water fully set up, so it is the weight it will be when you are using it. If it is lighter or heavier the waterline will be different. That is pretty obvious, sorry.
You then have to mark the hull, and take measurements to insure you get the actual water line. That being said, you may not want a water line stripe.
All that is up to you and your painter.
Food for thought
Boomer
Old Mar 16, 2011, 04:05 PM
Dick L. is offline
Find More Posts by Dick L.
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Use talc or baby powder. Sprinkle on surface of water. Set boat into middle of the powder carefully. Lift from water and talc/powder will stick and show waterline. Use a marker and mark bow, stern and midships waterline on both sides. Then tape and paint - or apply pinstripe tape.
Be sure your weight is centered inside (batteries) so you have symmetrical waterlines on each side.
Dick L. is offline Find More Posts by Dick L.
Old Mar 16, 2011, 06:39 PM
transam2k4 is offline
Find More Posts by transam2k4
United States, OH, Maple Heights
Joined Feb 2011
Dick I like your talc Idea!! I remember when I co-oped in a yachts company I had to jump into the water to mark water line with a wax pencil... (it was pretty cold water too)
transam2k4 is offline Find More Posts by transam2k4
Old Mar 17, 2011, 08:17 PM
304cz is offline
Find More Posts by 304cz
Joined Sep 2007
Winch
Could you post a pic of your vela with the new sails?
304cz is offline Find More Posts by 304cz
Old Mar 17, 2011, 09:50 PM
winch is offline
Joined Feb 2011
Originally Posted by 304cz View Post
Winch
Still waiting for them but should be here soon - I will try and get some "on the hard" pictures posted then. (might be a wait to get out on water though..)
They are for a 0 - 10 mph wind range - 1.0 oz mylar called TriSpi 40.
Also want to upgrade the rigging.
Old Mar 20, 2011, 05:09 PM
JDCrow is offline
Find More Posts by JDCrow
JDCrow's Avatar
Arkansas USA
Joined Jan 2006
Sailed Vela today on 6volts. 8-11 mph wind.
She would inhaul the sails, but nothing like I anticipated. In fact, I think the steering servo wasnt too happy after being powered on 6v for a while. I just dont believe the servos are up to the task for performance sailing. They are adequate for daysailing, yet ultimately I'll upgrade them.
I did make a change to the sheet rollers. I removed them, and replaced them with a piece of antenna tubing. This solved my fouling issue I was having.
I did have one failure today. The sheet that goes thru the Tack of the Main ripped thru the sail (no eyelets, just holes punched, in the kit sails). I used the second hole, and had it tear thru it as well. Going to add a patch, then add eyelets.
JDCrow is offline Find More Posts by JDCrow
Old Mar 20, 2011, 08:27 PM
winch is offline
Joined Feb 2011
JD -
Think this boat can be a good one but seems like a lot of small probs...
Since its compared to the Seawind a bit....Do you know if the was same way when it came out ?
Guess its back to topic of which servo is best fit.
I'll be waiting for peoples suggestions .......
Wanted wtb aquacraft ul1 boat!! kremecheze Boats (FS/W) 0 Oct 21, 2010 07:39 AM
Wanted Small aquacraft/futaba compatible RX wparsons Boats (FS/W) 2 Oct 15, 2010 05:19 PM
Wanted Aquacraft UL-1 Hull jwg1978 Boats (FS/W) 24 Oct 15, 2010 09:48 AM
Wanted Small aquacraft/futaba compatible RX wparsons Cars - Accessories (FS/W) 0 Oct 11, 2010 07:29 PM
Question ¿Alguien en Venezuela haciendo vela a radio control? naufrago Sailboats 10 Jan 06, 2009 03:23 PM
