Bang
"I will be changing the sheeting geometry to what was mention here before to get full adjustment.Also need to play with tunning which I dont have much experience so any suggestions are appreciated (like rake, bang, outhaul and how much the jib has to go in compared to main...)"
What's bang ????? Stringfly <>++++ |
Anyone tried or know someone who has used the Hitec HS815BB sail servo?
Spec documents make it out to be a mAH hog. Recommendation is 6volts and minimum 1200 mAH. Just curious how much mAH it consumes per half hour of normal sailing or racing would like to know what users are actually seeing in their boats |
Asturias, Spain
Joined Mar 2001
I ran one on my 1 meter multihull and it had plenty of power to haul in about 1100 sq. inches of sail area. I used a "Y" Adapter with 4 cell NiCads (700 mAh I think) and I could get about 3-4 hours sailing time depending on wind conditions. Using 4 volts was a concern at first, but never needed to increase, and the arm is extremely fast.......one problem when trying to get small, incremental sheet adjustments. It's a workhorse - and big and heavy. But unless space requires a drum, I would use these all the time. |
5 cell pack.
I was thinking of one of these. Pretty good capacity and 6 volt if you really need it. They have other 5 cell hump packs depending on what will fit. these are 2/3A size cells.
http://www3.towerhobbies.com/cgi-bin...?&I=LXMUG9&P=7 Most AA cells just don't have that much capacity. My enelops say 1900 to 2000 mah but I don't really believe it. Stringfly <>++++ |
I bought some NiMH 2500 mAh "AA" batteries for my digital camera, and it seems like I am always running a set on my charger. I hate them because there is no warning - one minute you have flash, the next photo everything is "dead". At least with NiCads, you coud see the flash recharge get slower and slower - so it was sort of a "warning" system.
I am thinking of trying a set of LiFe and haven't seen much negative comment on those. Not sure if they require a special charger - so there is more added expense in changing battery chemistry from one to another. God love the U.S. EPA and their edicts ! Probably continue to use Alkeline for most of the small stuff and I found you can "bang" them for a short recharge if careful and monitor them. |
| Thread Tools | |
| Wanted wtb aquacraft ul1 boat!! | kremecheze | Boats (FS/W) | 0 | Oct 21, 2010 07:39 AM |
| Wanted Small aquacraft/futaba compatible RX | wparsons | Boats (FS/W) | 2 | Oct 15, 2010 05:19 PM |
| Wanted Aquacraft UL-1 Hull | jwg1978 | Boats (FS/W) | 24 | Oct 15, 2010 09:48 AM |
| Wanted Small aquacraft/futaba compatible RX | wparsons | Cars - Accessories (FS/W) | 0 | Oct 11, 2010 07:29 PM |
| Question ¿Alguien en Venezuela haciendo vela a radio control? | naufrago | Sailboats | 10 | Jan 06, 2009 03:23 PM |
