Old Oct 24, 2010, 07:05 AM
Chophop is offline
Find More Posts by Chophop
Not like poor old Ibzan
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
Symmetrical vs Flat Bottom Wing
I seem to see more flat wing planes than symmetrical. I have flown both and when landing or maneuvering, prefer symmetrical. When Sport flying light aerobatics at low or medium speeds, flat bottom seems best for lower battery drain at low speeds.
It also seems a symmetrical has a higher top speed but not so good glide. So, maybe a nearly symmetrical is a good compromise for all around flying.
Chophop is offline Find More Posts by Chophop
Old Oct 24, 2010, 08:10 AM
ChrisS is offline
Find More Posts by ChrisS
Really?!?
ChrisS's Avatar
Lost ...on the 3rd rock out
Joined Sep 2001
"I seem to see more flat wing planes than symmetrical."
Wow, kind of hard to believe. A quick walk through any hobby shop these days reveils a ton of 3D and sport planes, the vast majority of which will be symmetrical. Pretty much the only planes using flat bottomed or semi-symmetrical would be gliders, trainers and some scale stuff. Most of which are not used for much more than basic flying and rudimentary aerobatics.
You have it right though, flat bottomed or SS are true lifting bodies and do not need incidence to fly (assuming they are moving forward fast enough). As such they will generally fly slower and more efficiently for a given unit of thrust.
However, as you may have seen, big, floaty, lightly loaded, symmetrical airfoiled planes can be slowed down to a hover and flown on prop thrust alone (o.k. you could do that with a flat bottomed wing too, but most don't)...
Flat bottomed and SS do not penetrate as well into wind, tend to jump around more in turbulence and do not fly the same inverted as they do right side up.
For all out speed, you would want a lifting type of wing (one that does not need incidence to fly as this is very draggy). Then it's a matter of thinning it enough to reduce the profile drag (so that it's easier to push through the air) but not so much that you loose lift.
To glide a symmetrical wing, you of course can add camber with flaps or flapperons. Lightly loaded, this technique can work very well for gliding. However a true lifting airfoil is always best for this. But not as much fun when you want to blow holes in the sky.
You buy your ticket and take your ride.
Chris
ChrisS is offline Find More Posts by ChrisS
Discussion Flat Bottom to Semi Symmetrical Wing stemo99 Beginner Training Area (Aircraft-Electric) 11 May 26, 2010 07:33 AM
Discussion Blade CP+ - flat bottom vs. symmetrical eaglechaser Micro Helis 7 Jul 29, 2008 09:45 AM
Flat Bottom Rotor Blades -vs- Symmetrical (Which Better for Training?) mrebman Micro Helis 13 Jul 29, 2005 04:00 PM
Flat Plate vs Symmetrical main wing Jim Woodward Foamies (Kits) 0 Aug 13, 2003 12:30 PM
flat bottom, symmetrical, undercamber, what purpose does each serve? atsiang Power Systems 2 May 12, 2001 03:33 PM
