This thread is privately moderated by Foskje, who may elect to delete unwanted replies.
Old Oct 23, 2010, 04:51 PM
Foskje is offline
Find More Posts by Foskje
Norway
Joined Dec 2009
My project
Well this is my project, building my first plane from skratch, my drawings, my opinions and for now, all my ideas.
I have buildt one plane ever, a FF-supernova from rcfoamfighters and after that plane was totaled, I decided to build a plane from skratch.
Description:
I designed my plane using google sketchup.
Description:
From the computer to pen and paper... then cutting
Name: Jager - 475mmCG.jpg
Description:
After cutting the foam
Name: IMG_20101001_093755 - Kopi.jpg
Description:
A bit more hot wire cutting
Description:
sanding and add vertical stabilisators and motor mount with hot glue
Description:
Adding electronics, this plane would not fly, the torque from the engine made it hard to take off. I did also add bigger flaps.
Description:
Finally a plane that was able to takeoff!
Description:
The plane DID FLY (!!!) on first try!
In the near future I will find a CG I like, and then try to move the wings a bit more forward, cause the flaps have to be a bit trimmed up to conteract the nose to go down... moving the CG further back will make the plane unstable and it goes up and down to easy! (if i made the flaps smaller that problem might be gone??!?)
I might begin 2. layout tomorrow (23.oct) - I will build the plane with edfs this time!
Foskje is offline Find More Posts by Foskje
Old Oct 26, 2010, 01:36 PM
A Useless Geek is offline
Find More Posts by A Useless Geek
just Some Useless Geek
Chicagoland
Joined Oct 2008
Hey, you did pretty well for a scratch build with a hot wire cutter! That plane looks awfully fragile, though. Don't make any mistakes while flying, or you'll end up with a pile of crunched styrofoam instead of an aircraft, eh?
Looking forward to your next project. #2 looks even better!
A Useless Geek is offline Find More Posts by A Useless Geek
Old Oct 29, 2010, 05:16 PM
Foskje is offline
Norway
Joined Dec 2009
Thank you!
Fragile? - oh yes... I will not tape or add carbonfiber yet, because it takes too much time if I am going to work into all details at all the planes.. Instead I will use a lot of glue
Old Nov 04, 2012, 03:03 PM
vincent123 is online now
Find More Posts by vincent123
InceCreations
vincent123's Avatar
Joined Jul 2009
nice design!
I saw you use pretty thick foam, which seems very rough.
The build would be easier and the resukt eveb better, when you would you use 3mm depron sheetings. Did you already use this?
vincent123 is online now Find More Posts by vincent123
Build Log My Habu Project wwestover Foamy EDFs 27 Jan 13, 2011 04:16 AM
Discussion Which ESM warbird for my next project? st_dysan Fuel Warbirds 24 Nov 06, 2010 08:16 AM
Help! Paprazzi tiny 2.11 for my Final Project,need some assist alz3abi UAV - Unmanned Aerial Vehicles 4 Oct 20, 2010 10:13 PM
Discussion Need advice on my fpv project Goofy68 FPV Talk 4 Oct 16, 2010 07:22 PM
