Old Oct 24, 2010, 04:04 AM
Wiebe9999 is offline
Find More Posts by Wiebe9999
fpv rules
netherlands
Joined May 2010
Try a flexayagi ,nice and not heavy.
http://www.flexayagi.de/
Wiebe9999 is offline Find More Posts by Wiebe9999
Old Oct 24, 2010, 06:00 AM
srnet is offline
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Plenty here, the ZLs are shorter than a conventional yagi;
http://www.moonraker.eu/Amateur-Radi...l-Yagi-Antenna
srnet is offline Find More Posts by srnet
Old Oct 24, 2010, 06:07 AM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
Lots of 433 MHz Yagis below. A 433 MHz patch too!
http://www.wsplc.com/acatalog/Tonna_Yagis.html
Ian Davidson is offline Find More Posts by Ian Davidson
Old Oct 24, 2010, 06:19 AM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
David22, I'd like to avoid using a booster if possible. the reason we need a yagi is to blast through houses far away, as we want to fly 40km but at ground level. I can take a dropout of the video for 2-3 seconds, but control must be strong. That dictates we always have 20dbi margin, which we don't this far out. So we must use high-gain yagis (9 - 11dbi) in order to up the power to the required level.
thanks for all the suggestions guys, I'm looking through them right now!
trappy is offline Find More Posts by trappy
Old Oct 24, 2010, 08:16 AM
srnet is offline
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
ZL Specials are the way to go, for a 12.5dbi gain a standard yagi is 190cm long, the ZL special is 110cm.
Same price, 50.
Old Oct 24, 2010, 08:36 AM
SENTRY 62 is offline
Find More Posts by SENTRY 62
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
Am I missing something?? I didn't know you were on 433 Trappy.
SENTRY 62 is offline Find More Posts by SENTRY 62
Old Oct 24, 2010, 08:41 AM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
uhf dewd
Blackrat is offline Find More Posts by Blackrat
Old Oct 24, 2010, 09:42 AM
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
Aaaaah - right on!
Old Oct 24, 2010, 10:44 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by trappy View Post
David, I saw those, they're $150 - $250 on that site (if I remember correctly). add to that another $40 in shipping minimum ...
Moe, Alex = IBCrazy?
I'd recommend a different antenna rather than a standard Yagi. Perhaps a loop Yagi or a BiQuad would be better?
What gain are you looking for? Here's a 12dbi unit: http://www.directivesystems.com/PDF/DS432-11R.PDF
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 24, 2010, 11:29 AM
ganapati08 is offline
Find More Posts by ganapati08
Unlimited FPV
ganapati08's Avatar
Latvia, Riga
Joined Jun 2010
ganapati08 is offline Find More Posts by ganapati08
Old Jan 03, 2011, 11:54 PM
Wind_of_Change is offline
Find More Posts by Wind_of_Change
More Combat Please!
Wind_of_Change's Avatar
Utah
Joined Dec 2003
Okay, I've been thinking all along that Yagi's were used for video reception over long ranges. But if you're using Yagi's on UHF frequencies, then are you using them to SEND your RC signal to your UHF receiver onboard the plane?
Pardon me for my ignorance, but this is the first I'm hearing of that.
So do you guys have 433mhz Yagi's for RC transmission AND 2.4ghz Yagi's for video reception on a single base station?
I don't understand how you'd manually point those antennas, seems like you'd need an antenna tracker to be accurate.
Are there any antenna trackers that would work with the DragonLink? I like the DOSD+, so I'm thinking DL all the way on my setup. But the EzUHF is the only one I've seen that has the antenna tracker features as part of the product suite.
Sorry, questions on several topics, but would love feedback from the "pros" on this thread.
Many thanks!
Todd
Wind_of_Change is offline Find More Posts by Wind_of_Change
Old Jan 04, 2011, 01:27 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
you put both yagi's on a pole that can be aimed at the plane.
both yagi's are in the same polarization and alignment.
But spaced apart by a minimum of 70 cm
the video yagi goes on top because it is the weakest and needs more height
you do the manual aiming by useing the video reception
when in close for like inflight flying, or to land, the manual aiming is not really needed, the video is good for flying close range with a video yagi and uhf is for sure not needed to be aimed at close range.
Divercity, antenna trackers and other things are just a possable weak link that could cause you future problems IMHO
I like to keep things as simple as possable
Many thanks!
Todd
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Jan 04, 2011, 01:57 AM
More Combat Please!
Utah
Joined Dec 2003
Okay, that's totally awesome. Thanks for the info David.
I just placed a HUGE order for 2.4ghz AV gear, following Trappy's recommendation. I must wait a little while to build up the funds to get the UHF stuff. I'll fly 72mhz to begin with in close range while training and getting used to flying through a camera, then get the UHF gear with another Yagi on 433mhz for long range stuff.
I had no idea you guys were pointing your Yagi's manually. I mean, the way the BlackSheep guys fly, I can't imagine they'd have a free hand to do that sort of thing! So if your signal starts to get a bit blurry, you just start moving your antenna around until it cleans up?
Wow. Low tech, but puts control of the entire experience in the pilots hands. I kind of like that.
Gives new meaning to the phrase "Mad Skills"! Ya gotta be mad to do that, and it sure takes skills!
So, question about the video transmitter. Do you just use the little 2.4ghz black antenna that it comes with for video transmission, or do you use something fancy for that as well?
Old Mar 23, 2014, 11:54 PM
Gibbedy is offline
Find More Posts by Gibbedy
Australia, VIC, Berwick
Joined Oct 2013
Originally Posted by ganapati08 View Post
I'm after something as high gain as possible for openlrsng lost plane beacon. Anyone got any simple DIY instructions I can follow like this one but higher gain.
I need to check but I think beacon is around 450-460 MHz.
Thanks for the help.
Gibbedy is offline Find More Posts by Gibbedy
Old Mar 24, 2014, 02:45 AM
srnet is offline
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Do a Google on 'DIY 70cm yagi'
You should find plenty of examples out there.
Discussion 433mhz vario system adi91 Eagle Tree Systems 1 Oct 11, 2010 08:51 PM
Build Log Fokker DVII scratchbuild (70cm WS) tacchino Scale Kit/Scratch Built 20 Nov 16, 2008 03:04 AM
Discussion ATV transmitter on the 70cm band? Carlyle Harper FPV Talk 2 Sep 09, 2008 10:03 PM
Discussion Whynot 70cm milled out... Video! BrunooO Indoor Pattern/F3P 5 Mar 20, 2008 11:00 PM
