Old Jun 27, 2001, 09:14 PM
mt_100 is online now
Find More Posts by mt_100
I have no friends
United States, MI, Holland
Joined Dec 1996
Energizer ACCU AAA cells
I have a pack of eight of these that I use in slow flyers. THey are light and 720mah so they work great.
Does anyone know what kind of amperage I could get out of them?
I'm tempted to put them in the Zagi...
mt_100 is online now Find More Posts by mt_100
Old Jun 27, 2001, 10:18 PM
Steve H. is offline
Find More Posts by Steve H.
Zebulon, NC
Joined Aug 2000
Gerald used them in a Skimmer glider last weekend with a direct drive speed 400 and I think a 6x4.5 prop? He said they were just warm so you might be OK if your zagi is stock.
Steve H. is offline Find More Posts by Steve H.
Old Jun 28, 2001, 08:33 AM
Steve McBride is offline
Find More Posts by Steve McBride
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
Actually they are marked as 700mah but I am not so sure they are not the same as Sanyo 720's (marked 'HR' on bottom - any ideas?)
You can get a good 3-4 Amps from them and even push to 5 amps but the voltage takes a nose dive above that.
I use them on my Astro 010 projects (8 and 10 cell packs). They seem to work great and take a lot of abuse.
Direct drive speed 400 on 6.5x4 is waaaay too much for these AAA cells - perhaps they were the AA cells?
Good luck!
Steve
Steve McBride is offline Find More Posts by Steve McBride
Old Jun 28, 2001, 01:56 PM
I have no friends
Joined Dec 1996
Yes, they are the AAA size and say 720mah on them.
I'm not sure about the 'HR' I'll check them tonight and see for sure.
Old Jun 28, 2001, 02:06 PM
Agra, Oklahoma
Joined Feb 2000
Hmm - I didn't know Energizer started listing them as 720mah. I knwo the Panasonic cells are 720's, but the Energizer Accu cells that I have delt with are marked as 700mah and cannot handle more than 4-5 amps without dropping serious voltage.
I suppose they would run a 400 direct with that prop, but the power would be way down comared to an AA cell or a 600AE.
I'm betting you are actually using Panasonic cells, not that there would be a huge difference.
Good luck and have fun!
Steve
Old Jun 29, 2001, 12:44 AM
Steve H. is offline
Zebulon, NC
Joined Aug 2000
Good luck!
Steve
Nope, they were the AAA cells, maybe he will see this post and reply.
WTB Maxell 700 AAA Cells Mowman Aircraft - Electric - Airplanes (FS/W) 1 Nov 11, 2002 03:36 AM
FS: 30) Maxell AAA cells @.60 ea. *SOLD* Al P Aircraft - Electric - Airplanes (FS/W) 4 Aug 26, 2002 10:05 AM
Wingo/SoarStar with Maxcell AAA cells = Thermal ! joemi Parkflyers 5 May 25, 2002 03:37 PM
Are Maxell 700mAh NiMH AAA Cells Good for E-Flight? Dave Hederich Power Systems 94 Dec 08, 2001 08:48 PM
Need motor with 10 oz thrust from 7-720NiMH AAA cells hoppy Electric Plane Talk 4 Nov 11, 2001 11:21 PM
