Old Aug 27, 2012, 03:44 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
Agreed! I put 2 1/2 ounces of lead in the vyper nose to get the battery moved back. I really need to move that rudder servo.
going4speed is offline Find More Posts by going4speed
Old Aug 30, 2012, 05:54 PM
booboo71 is offline
Find More Posts by booboo71
booboo71's Avatar
United States, OH, Jefferson
Joined Jul 2010
My Yak seems to lack power. I have the Omega 130 and Castle Ice Lite 50 with a Zoar 13x7 using 3s Thunder Power 25c 2100 battery. Just watt metered it and it settled 360 watts and like 35 amps. Is this normal? I have a Zoar 14x7 I can try. Will that make much difference? Should i change the timing? Motrolfly it?
booboo71 is offline Find More Posts by booboo71
Old Aug 30, 2012, 06:02 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Did you do the Fixed Endpoints Throttle Setup for the ICE?
Also, I ran 130's on High Timing, Fast Acceleration.
Should be seeing like 420-500 Watts, 40-50A depending on prop and settings.
heritageflyer is offline Find More Posts by heritageflyer
Old Aug 30, 2012, 06:07 PM
racerxky is offline
Find More Posts by racerxky
Watts is where its at!
racerxky's Avatar
United States, WA, Seattle
Use the 14x7. More prop will pull more watts from the motor.
racerxky is offline Find More Posts by racerxky
Old Aug 30, 2012, 06:25 PM
booboo71 is offline
booboo71's Avatar
Joined Jul 2010
Thanks guys!
Old Aug 30, 2012, 07:38 PM
Joined Nov 2008
I only run a Xoar 13x6.5, has plenty of speed and power, on a Motrolfly. But flew it on a 130g also.
For me, proper setup first, then play with props for the feel you want.
Old Aug 30, 2012, 11:25 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
How well do your packs hold voltage under load? Low "C" packs or older packs won't hold high voltages under wide-open throttle, resulting in lower wattage......on a fully charged pack, under full throttle after 5 seconds, what is your voltage? Amps? Watts?
With full power from the ESC, on good batts, I'd expect more wattage?
Where are you located? What altitude?
Bivens is offline Find More Posts by Bivens
Old Sep 04, 2012, 09:45 PM
booboo71 is offline
booboo71's Avatar
Joined Jul 2010
Got it working better! Didnt watt meter it but I threw on a 14x7 and hooked the castle link back up. I didnt see the save settings button in the corner when switched it to high acceleration the first time. Now she will climb straight outta sight in no time at all! Rollers are smooth as glass with this plane! I was able to fix the leg on the landing gear too. I used some ca hinge material that came in a sheet and wrapped it tight while tacking and soaking it with ca then hit it with a black sharpie. It even held up to a bounce! Funny the other side never cracked.
Old Sep 07, 2012, 10:59 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
if the packs are holding ok can always prop up if amps and heat doesnt rise too high..
Never,ever can go wrong by motrolfly'ing it either.
Manta1 is offline Find More Posts by Manta1
Old Sep 07, 2012, 11:16 PM
3DHS 'native'
USA, TX, Spring
2815-950 on mine yet to fly...running a 13x6.5...hope its enough
Old Sep 22, 2012, 09:11 PM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Some fun with the yak
3DHS 46 Yak 55 Pilot Joe Smith (5 min 3 sec)
jsmith285 is offline Find More Posts by jsmith285
Old Sep 22, 2012, 09:38 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
how come mine doesnt fly like that
keithy4129 is offline Find More Posts by keithy4129
Old Sep 22, 2012, 09:40 PM
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
I'd Bet money it does.
Old Sep 22, 2012, 09:44 PM
Joined Aug 2010
lol, not with me at the sticks!
Old Sep 22, 2012, 10:15 PM
3DHS 'native'
USA, TX, Spring
wow...hope to maiden my yak tomorrow.
Discussion yak 55 M where sells this one ???? maikrotex 3D / Fun Fly Fuel Planes 1 Nov 07, 2010 09:23 AM
Found z RC4RS Aircraft - Electric - Airplanes (FS/W) 3 Oct 15, 2010 11:09 AM
Build Log Got parts from Hobby Lobby Yak 55, lets build a full fuse Yak 55 Lampatex Foamies (Scratchbuilt) 16 Jun 13, 2007 10:50 AM
