Old Jul 22, 2012, 12:05 AM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
Red is good but I have two 71's and an Osiris in red.
Oh and the vyper in red.
Are the 3DHS long arms required for the rudder on this bird?
Originally Posted by skarface View Post
Oh I would want blue too, your avatar is red so thought maybe you like red.
going4speed is offline Find More Posts by going4speed
Old Jul 22, 2012, 09:28 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Not too long. I'm in the inner hole on the 3dhs arm. You could easily just make a rudder arm from a scrap of plywood or carbon if you don't have the 3dhs arm or don't want to wait on ordering one. You may want extended throw on the elevator also.
This little plane will tie one up in a tumble with full throws...and has a really fast roll rate also...if you go full throw. You don't have to of course....
Bivens is offline Find More Posts by Bivens
Old Jul 22, 2012, 10:45 PM
6L6Amp is offline
Find More Posts by 6L6Amp
6L6Amp's Avatar
Northern Indiana
Joined Jan 2009
I used the stock HS-65 arms on all surfaces. Outer holes on the rudder and elevator. Second hole in on the ailerons.
6L6Amp is offline Find More Posts by 6L6Amp
Old Jul 22, 2012, 11:01 PM
3DHS 'native'
USA, TX, Spring
Cool thanks.
Old Jul 23, 2012, 08:30 AM
alfabeast is offline
Find More Posts by alfabeast
3D Addict
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
throws for yak 46-in
Cool thanks.
Outer hole on stock hitec long arms for ailerons. I can hold off the torque in a hover NP and it rolls like a drill bit at speed.
3dhs extended arm on rudder, outer hole - I could use a little more throw even yet for 3d. Have stripped a 5065mg though. I wish 3dhs would use larger rudder servos on the smaller planes.
3dhs extended arm on elevator, second hole in (plenty of throw)
Hope this helps!
alfabeast is offline Find More Posts by alfabeast
Old Jul 23, 2012, 09:18 AM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, FL, Bonita Springs
Joined Oct 2010
Hope this helps!
if you want a more powerful servo get some Savox SH-0255mg digitals.
3Daddict is offline Find More Posts by 3Daddict
Old Jul 23, 2012, 09:45 AM
3D Addict
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
savox
thx, i have the 1258tg's in my 71-in slick - will chk them out
Old Jul 23, 2012, 09:54 AM
3D Addict
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
savox vs hitec
here are the 5065 mg spec's - they are a little quicker, but the savox is 54 in-oz - this would be a great rudder servo!
23.6mm x 11.6mm x 24mm (0.92" x 0.45" x 0.94")
Speed @ 4.8V: 0.14sec/60
Speed @ 6V: 0.11 sec/60
Torque @ 4.8V: 1.8 kg-cm (24.99 oz-in)
Torquw @ 6.0V: 2.2 kg-cm (30.55 oz-in)
Weight: 11.9g (0.42oz)
Old Jul 23, 2012, 09:57 AM
6L6Amp is offline
6L6Amp's Avatar
Northern Indiana
Joined Jan 2009
Here's my throws with the stock arms (Futaba 8FG).
Rudder with stock arm, outer holes - end points at 140 and 132. Rudder is 1/8" from hitting the elevator in both directions.
Elevator with stock arms, outer hole. End points both at 140. I have 50 degrees up and down travel.
Ailerons with stock arms, second hole in. End points in the 130s on everything. I have 35 degrees up and down travel.
Old Jul 23, 2012, 10:02 AM
3D Addict
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
savox 0257
looks like the savox 0257 is the quicker of the line at .09 sec, so those on the rest of the surfaces and the 0255 on rudder works for me!
Old Jul 23, 2012, 09:46 PM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
Put 5 flights today on this little yak....lots of fun...
I'm gonna keep it in my truck for a week or so to fly at work, I'm really enjoying it recently since I've taken it out the past few days.
Old Jul 23, 2012, 11:29 PM
Vintauri is offline
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
Mines coming back out with a new Omega 130 up front. Our big WATTS fly in is this weekend so I hope to get some good flights on it there.
Vintauri is offline Find More Posts by Vintauri
Old Jul 24, 2012, 07:44 AM
3D Addict
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
prop for O 130
Try a Xoar 14 x 6 for 3s - nice balance of thrust and speed. APC 13 x 6.5 also, but slower spool up, not much.
Old Jul 24, 2012, 09:24 AM
3Daddict is offline
3Daddict's Avatar
Joined Oct 2010
they might be quicker slightly, but it is by no means a noticeable difference. The added torque of the 0255 if worth the minute loss of speed. You do need to get 6.0 volts to them.
Old Jul 24, 2012, 09:26 AM
Vintauri is offline
MN WATTS Master
Vintauri's Avatar
Joined Jul 2003
I'll have to order the Xoar. I'm pretty sure I have the APC on hand. Been so busy organizing the event I have not had much focus on my airplanes and what I need to order for them. Let's hope for a long fall!
Discussion yak 55 M where sells this one ???? maikrotex 3D / Fun Fly Fuel Planes 1 Nov 07, 2010 09:23 AM
Found z RC4RS Aircraft - Electric - Airplanes (FS/W) 3 Oct 15, 2010 11:09 AM
Build Log Got parts from Hobby Lobby Yak 55, lets build a full fuse Yak 55 Lampatex Foamies (Scratchbuilt) 16 Jun 13, 2007 10:50 AM
