#1 Ok the amps bench tested on the ground would represent the amps being pulled when you would first apply full throttle and the plane is NOT moving because once it starts moving the motor/prop unload and then amps go down by how much not sure.
Thats why some even when rolling takeoff do not apply full throttle. #2 More amps does mean more heat. MY DX8 and stock PKZ with E-Flite 30A only pulls around 23A and the temps generaly stay around 85F. The max operating temps are generaly in the 100-120f with motor going higher. #3 Most esc rated amps specs are based on some X amount of air circulation so cold air does help the esc to stay cool. #4 You got awesome radio, you will luv as I luv mine. I got my temp sensor set for 100f #5 What happens with esc and bec is that the esc can handle a certain amount of heat and the some will shut down when the heat is greater then normal. What happens with BEC is that depending on the size of the main pack the bec also generates heat and this adds to the esc heat and may cause it to shut down earlier then a esc that did not have a bec. If you only swap the motor to a power 10 BUT kept the stock prop you will see improvement in performance ans should be good with the stock ESC. Since WOT is not applied all the time and should not even using the stock setup. |
Latest blog entry: Get Help by posting your SPM File
The most concerning thing about the E-Flite 30A esc is not really the esc amps BUT the limited BEC output. Even if its labeled as a Switching bec it is only good for 700mah YES 0.7A make sure you follow the servo amount recommendation other wise you're setup is going to be prone to brownouts.
Agreed, I had added one servo for bomb drop module and the addition of the TM1000 unit for my DX8 Telemetry would cause the RX to flash after a full battery flight imdicating lose of power. Must of been minor because never even notice it but still concerning. Then after talking to someone and they comment that I should realize the the TM unit also needs power to function ant that maybe I was excedding the BEC limits is when I looked into it and found out the limited output of this esc.
The funniest thing is that PKZ`s new plane P-47 comes with the same esc and you can also get functioning flaps (2 servo) and electric retracts for it so 2 more servo. I commented on that thread about the lack of BEC output and a representative responded by saying it was tested and worked fine. Not surprising that the TM unit would draw a little more power since its transmitting but owners still need to be aware if they opt to use the FLAPS or Retracts or both and the TM telemetry for those with the DX8. Oh well. |
United States, NJ, Frenchtown
Joined Mar 2003
But how many servos can you VIOLENTLY move at the same time ??
Not too many. Landing approach ? Only servo current will be the landing gear going down. Flaps are a momentary load. Most planes really do not pull a lot when sport flying. If you do go nutty & slam all you levers into the stops. You are nutty. You plane was NOT designed or built for that kind of servo load abuse. NOW you MAY get loss of plane control due to 1 or several overloads at once. Rich |
Joined May 2010
Fair point Rich, I guess we will just have to buy this beauty and find out. In fact, thats probably how Iīm going to slip it past my wife, "no dear, Iīm not buying another plane, itīs merely a brownout testingdevice" ;-)
Still, Iīll probably put a separate BEC in there anyhow. I like the fact that it enables you to control your plane even if the ESC burns/shuts down. A cheap Hobbyking 3A BEC actually saved my EF2000 a couple of weeks ago when an old ESC from Art-tech decided to shut down in mid flight. Resulted in a nervewrecking spaceshuttlestyle landing, since you only get one approach and one landingattempt. The plane was ok but it became painfully obvious why Sweden has no spaceprogram... |
Joined Mar 2003
You are correct.
The logic of 1 BEC chip overheating on the ESC, causes the ESC to totally shut down, should be avoided if possible.
Fact is, I am LONG overdue by several years, for a BEC shutdown on a ESC. If I buy only 1 really good 1, then I run the risk of a intermittant plug wire breaking, moving it from plane to plane. Crap. Why leave all that money to others when I croak. Since all my planes run HS-55s.........CHEAP,CHEAP. Even the guy below only uses 4 HS-55s. Rich |
Joined May 2010
I really like that it is such an easy upgrade. The Power 10 is a drop in replacement for the Parkzone 480 so it requires no spacers or additional hardware or other modifications. I have about 30 flights on my upgraded Trojan (Power 10, stock ESC and stock prop) and have had no problems with the ESC overheating. It is so nice to make a low and slow flyby only to go WOT for unlimited vertical until the plane is a dot in the sky, sweet :-)
Happy landings! /Robert |
| Thread Tools | |
| For Sale E-Flite 30A Pro esc NEW 33 bucks...shipped. | misplacedtexan | Aircraft - Electric - Power Systems (FS/W) | 3 | Sep 21, 2010 05:17 PM |
| Sold E-FLITE P-47 NIB with 30a ESC | Sammy70 | Aircraft - Electric - Airplanes (FS/W) | 3 | Oct 13, 2008 02:35 PM |
| Help! Wiring a Swtich into an E Flite 30A ESC | FlyJake | Electric Motor Design and Construction | 1 | Oct 01, 2008 02:10 AM |
| For Sale E-Flite 30A ESC | gp125racer | Aircraft - Electric - Power Systems (FS/W) | 6 | Dec 16, 2007 11:57 PM |
| Sold FS: E-flite 30A ESC | czechyour6 | Aircraft - Electric - Airplanes (FS/W) | 3 | Jun 22, 2005 06:11 PM |
