Old Jul 21, 2011, 08:46 PM
McKrackin is offline
Find More Posts by McKrackin
Incurable heli addict
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
My video came out pitch black...Wrong settings and it's dark outside
I'll try another one indoors when the lipo charges.
By the way...I used 1400mA of a 3300mAh pack in about 6-7 minutes.
That sound OK?
Also,one of the motors has a different sound.A clunky notchy sound...Not loud.Just different....That normal?
I'm a nitro guy and my bad motors usually sound BAD!!! lol
McKrackin is offline Find More Posts by McKrackin
Old Jul 21, 2011, 08:48 PM
AlPackin is offline
Find More Posts by AlPackin
AlPackin's Avatar
United States, CT
Joined Mar 2011
Originally Posted by McKrackin View Post
Totally disassembled
yeah, that's how they come ...
AlPackin is offline Find More Posts by AlPackin
Old Jul 21, 2011, 08:52 PM
Michael64 is online now
Find More Posts by Michael64
United States, TX, Thrall
Joined Feb 2010
If it sound like its ticking RUNNNNNNN!!!!!!!!!!!!!! anyway the noise is due to timing sometimes may be louder than other it causes no problems.
Michael64
Michael64 is online now Find More Posts by Michael64
Old Jul 21, 2011, 08:54 PM
AlPackin is offline
AlPackin's Avatar
United States, CT
Joined Mar 2011
call China, they'll get right right back to you
edit:
sorry, I can't say maybe somebody else can ...
Old Jul 21, 2011, 09:32 PM
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
Well,how's it look/sound?
Radio settings suggestions?
Second attempt at hover with my X650 Quadcopter (2 min 5 sec)
Old Jul 21, 2011, 09:36 PM
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
The rudder doesn't drift BUT...it wants to stay on a certain heading.
When I bump it back to the right,it returns to where it started and then stops right there....Weird.lol.....
That video was about 80% hands off by the way.
Old Jul 21, 2011, 09:53 PM
galexis is offline
Find More Posts by galexis
United States, GA, Atlanta
Joined Jun 2008
Decrease the boundary on the I: settings from 1000 to 500
galexis is offline Find More Posts by galexis
Old Jul 21, 2011, 10:08 PM
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
What purpose does that serve?
I'll do it but I want to know what that does.lol...
Old Jul 21, 2011, 10:17 PM
fajar is offline
Find More Posts by fajar
fajar's Avatar
Indonesia, Special Capital Region of Jakarta, Jakarta
Joined Jan 2011
You guys are awesome...IT FLIES!!!
I'll upload a video and you guys give me some tips.
This has been a rush job.
I didn't get it til noon and it was a bit harder to build than I expected.lol...Totally disassembled
congratulations! I'm sure you'll find it a lot easier than flying a cp heli. As always, do pre-flight check to see if everything stays put as it is supposed to be. Hope you'll have some spare blades handy coz that's what most likely broken during first flights.
fajar is offline Find More Posts by fajar
Old Jul 21, 2011, 10:37 PM
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
I'm still landing a bit rough.
I never land my CP's with the engine running but I still have a ton of energy in the 710mm blades so finesse is no problem.
Landing a FP is weird to me.
I adjusted the boundary in I from 1000 to 500 but still get that slow recoil from rudder input or yaw..Do I need to learn some new words now?lol....
Am I adjusting the right parameter?
Old Jul 22, 2011, 03:16 AM
quad master is offline
Find More Posts by quad master
UavRotorKing.com
United States, CA, Yorba Linda
Joined Sep 2010
just so you know always check your props for cracks if it has a tiny crack throw it away I have had a crash because prop broke in mid flight so be careful and have fun
quad master is offline Find More Posts by quad master
Old Jul 22, 2011, 04:08 AM
TeeJayBee is offline
Find More Posts by TeeJayBee
United Kingdom, Swansea
Joined Mar 2011
http://www.youtube.com/watch?v=2LJkH3ljcrg
Looking good there McKrackin
Next advise is......
Get out and fly it
Oh yes, if you're not used to fixed pitch beware of the wind, it takes effort to stop it's drift turning inot a rampage....
Wind gets under the discs (rotating blades), quad tilts away from wind, speed picks up in direction of wind, before you know it, it's completely out of control....
Try countering the drift with cyclic input, you may have to quickly adjust throttle down then up again (lowering throttle slows the discs which means the wind no longer catches under them) trouble is the quad will now want to drop so you've got to react quickly, basically what you're doing is try to get the side facing the wind to drop into the wind then give throttle to fight against the wind, doesn't always work out depending on the strength of the wind and your reaction timing
Have fun and give us more videos
TeeJayBee is offline Find More Posts by TeeJayBee
Reply With Quote  (Disabled)
Old Jul 22, 2011, 04:48 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Hexa setup
Glen...Jeff.. Josh...Jingchen...a bit of help needed, please.
Have been having trouble controlling this Hexa. Thought it was due to the wind, so waited until this morning when there was no wind. Well a small breeze about 5-10km/h.
Took it out and it would be hovering sort of okay and then it takes off to either the right or left, while not touching any stick. Had to fight to control it and had a few hard landings. Seemed like someone else had taken control with another Tx.
When I got back, decided to check all the settings. Am flying in + mode with motor settings as per Jeff's mixer config
All settings were okay except I found that I have been using the Attitude Settings still for X mode. Will this make that much of a difference ..do you think? And could this be my problem? Anyway, have corrected this.
Do you think the small gaps between the props is adding to the problem?
On the motor settings we have Pitch control on all motors whereas Roll is only on Motors 2,3 & 5,6. I am suggesting that I take Pitch control off motors 1 and 4 and that will make Pitch and Roll controlling only motors 2,3 & 5,6 and Yaw and Throttle to control all motors. Seems to me that it will be more balanced. Any thoughts
Cheers
Rob
robone is offline Find More Posts by robone
Old Jul 22, 2011, 05:05 AM
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
Pulled an all nighter on firmware updates.
Evidently I'm not nearly as computer literate as I once thought
Oh well.At least the sun is coming up and I can see to fly better
Thanks all.
That video saved my bacon.
Old Jul 22, 2011, 05:14 AM
Jingchen is offline
Find More Posts by Jingchen
Joined Jan 2010
Cheers
Rob
You have to turn the PID a bit. Since Hexa is more powerful that quad, so the P&D should be smaller than X650's.
X style settings can fly, but not very well If you use X650 +style, it also need to trim a little.
Jingchen
Jingchen is offline Find More Posts by Jingchen
Discussion Xaircraft X650 Quad Owners and Testers Thread Z06 Tony Multirotor Talk 459 Feb 07, 2014 02:54 PM
Discussion x650 Technical Documents Translation:XAircraft X650 LED Module infmetry Multirotor Talk 9 Nov 22, 2011 06:03 PM
Discussion WANTED:Test-Pilots for X650&Letter to XAircraft Pilots/The final namelist determined xaircraft Multirotor Talk 35 Jan 11, 2011 07:28 AM
Discussion X650 the new quad from XAircraft to be launched very soon bob.titus Multirotor Talk 558 Nov 20, 2010 11:33 AM
Discussion Official!!!!!! Parrot A.RDrone USA owners thread Quad_Addict Multirotor Talk 59 Oct 27, 2010 11:48 PM
