Old Jun 08, 2011, 01:16 PM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Originally Posted by GGoodrum View Post
Actually, they have it exactly backwards. It is always better to have the battery leads as short as possible, and add length to the motor wires, if need be. In fact, with most ESCs, if you have to extend the stock battery leads at all, you should add caps, to the ESC end.
This became readily apparent to me about 4-5 years ago, when I was helping a guy do an RC-controlled blimp. This thing was fairly large (the bag was 20 feet long...), and had four motors that were spaced 6-8 feet apart. Initially, we had the ESCs co-located with the motors, and ran long battery wires back to the packs. This never worked, and we ended up frying several controllers. Finally, we tried moving the ESCs close to the packs, and ran 6-foot wires out to the motors and the problems went away.
-- Gary
Thats probably why I fried the one ESC.
Rob
robone is offline Find More Posts by robone
Old Jun 08, 2011, 01:23 PM
Joshbb is offline
Find More Posts by Joshbb
Ironbridge (UK)
Joined Jan 2009
Rob
I dont think so imho
Joshbb is offline Find More Posts by Joshbb
techcapsule is offline
Find More Posts by techcapsule
United States, LA, New Orleans
Joined Feb 2011
Originally Posted by zirt57 View Post
Where did you get the price list? Please post!
- Jeff
I'll email it to you as I'm not sure they want it out just yet. You can PM me
techcapsule is offline Find More Posts by techcapsule
Old Jun 08, 2011, 01:27 PM
topgearuk is offline
Find More Posts by topgearuk
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
-- Gary
+1 On this
Battery wires as short as possible, but ok to extend motor wires. I had this very same thing a few years ago for my EDF's where the ducted fan motor is at the back and the batteries are at the front.
topgearuk is offline Find More Posts by topgearuk
Old Jun 08, 2011, 01:28 PM
robone is offline
Joined Sep 2010
XAircraft X450 ESCs.
- Jeff
Jeff
If I used the TURNIGY Plush 18amp Speed Controller orHobbyking SS Series 18-20A ESC , would that be okay. Its a lot cheaper. $12 vs $23
Rob
Old Jun 08, 2011, 01:34 PM
Zirt57 is offline
Find More Posts by Zirt57
Zirt57's Avatar
Canada, ON, Cambridge
Joined Jan 2007
---Deleted---
Zirt57 is offline Find More Posts by Zirt57
Old Jun 08, 2011, 01:41 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
For multi-copter use, I don't think we'll come near the 30" battery lead length. Even the 16" motor lead would be hard to exceed in most cases. For my hex, I think I'll just measure things out and extended whichever set of leads is the simpliest. Either way I won't exceed either length. So...what's the cell limit of the XAircraft ESCs?
Vantasstic is offline Find More Posts by Vantasstic
Old Jun 08, 2011, 01:47 PM
robone is offline
Joined Sep 2010
You should be able to. You will have to program it so I would suggest getting the programming card (a lot easier). There are some settings you will have to do in the XAircraft configuration for the FC. Check the first page of this thread as Jingchen posted a link to how to do this.
- Jeff
I saw that, but does that only apply if you are using another ESC and the X650 motors?
Just checked and the "Output 1- 4 change to 3-4ms" is not possible now. So (not having done this before) I assume that this could be changed in the programming card, if required or maybe not necessary because different motor?
Rob
Old Jun 08, 2011, 01:54 PM
Zirt57 is offline
Zirt57's Avatar
Joined Jan 2007
---Deleted---
Old Jun 08, 2011, 02:25 PM
seafarer is offline
Find More Posts by seafarer
Joined Feb 2004
Well, I can't replicate the problem I had with the motor so I'm going to pretend it never happened ;-)
Nick
seafarer is offline Find More Posts by seafarer
Old Jun 08, 2011, 02:37 PM
robone is offline
Joined Sep 2010
It applies to ESCs other than XAircrafts. You should still be able to use X650 motors or even aftermarket motors. I haven't used different ESCs myself but others here have.
- Jeff
This is my proposed setup for the X650 X8:
All costs ignoring postage etc.
8xDT700 motors - $88
8xTURNIGY Plush 18amp Speed Controller - $95
Total Cost $183
Larger thrust per motor (or am I wrong)
or
4xX650 motors - $132
5xX450 ESC - $115
Total Cost - $247
I already have the other parts.
Sounds like a no brainer to me. Saving in my money = 30 cups of coffee at Starbucks. Problem....Just to get the FC to talk to the Turnigy ESC's.
So, needing help....what changes have to be made to the settings:
1. ESC start Throttle should be changed to over 1000us?
2. Anything else
Rob
Old Jun 08, 2011, 02:49 PM
robone is offline
Joined Sep 2010
Originally Posted by topgearuk View Post
+1 On this
So the positioning of the ESC on the X450 is wrong. The ESC should be mounted on the plates? and near the battery.
Does it really make that a big difference?
Old Jun 08, 2011, 02:50 PM
Andre6553 is offline
Find More Posts by Andre6553
Vulcan skyhook multirotor
Andre6553's Avatar
South Africa, GP, Pretoria
Joined Feb 2011
Total Cost $183
or
5xX450 ESC - $115
Total Cost - $247
2. Anything else
Rob
Rob give andy (sid3ways) a shout he has similar problems to get the motors running with the HK Blueserries ESC. maybe he can help
edit
Changed the esc start timing canot tell you the values as i dont have a usb cable to hook up and and look now.
Andre6553 is offline Find More Posts by Andre6553
Old Jun 08, 2011, 03:06 PM
seafarer is offline
Joined Feb 2004
Just did some tests, so for those interested
x8
8x x650 motors
2 x x650 esc boards
mkTR camera mount
OSD and video downlink
Canon t2i w/16mm zenitar lens
AUW 3600 grams
at 50% throttle pulling about 20 amps for each side. Top motors pulling 20, bottom motors pulling 20. This is about the same as when I was running it as an x4 at about 1800 grams (obviously only 4 motors pulling 20 amps)
Cheers,
nick
Old Jun 08, 2011, 03:10 PM
Zirt57 is offline
Zirt57's Avatar
Joined Jan 2007
---Deleted---
Discussion Xaircraft X650 Quad Owners and Testers Thread Z06 Tony Multirotor Talk 459 Feb 07, 2014 02:54 PM
Discussion x650 Technical Documents Translation:XAircraft X650 LED Module infmetry Multirotor Talk 9 Nov 22, 2011 06:03 PM
Discussion WANTED:Test-Pilots for X650&Letter to XAircraft Pilots/The final namelist determined xaircraft Multirotor Talk 35 Jan 11, 2011 07:28 AM
Discussion X650 the new quad from XAircraft to be launched very soon bob.titus Multirotor Talk 558 Nov 20, 2010 11:33 AM
Discussion Official!!!!!! Parrot A.RDrone USA owners thread Quad_Addict Multirotor Talk 59 Oct 27, 2010 11:48 PM
