Old Jun 05, 2011, 05:51 AM
atlantean is offline
Find More Posts by atlantean
Joined Jun 2011
Hi All, im new to the forum, I've just this weekend finished building my x650, the build itself went very well, all components were well made and fit together great,
My problem is the same I have seen a few other users have had, one of my motors (M3) isn't spinning and is just jittering on startup, I've tried plugging the motor into other ports on the ESC and the motor works fine. I've also tried swapping out the leads from the ESC to the FC to no avail.
The problem seems to be on the M3 ESC connection, has anyone managed to fix this issue?
I've just seen this post by TheGunMan and this is EXACTLY the issue im getting
Originally Posted by TheGunMan View Post
Hi,
I just finished with assembly of my X650
On a test run the motor3 does not spin, it shakes left-right but does not spin
I checked connections and they are all correct - any ideas?
thanks
P.S. Rotated the motors and same motor works on different port of ESC. The motor on M3 port of the ESC does not spin
P.S. there is video: http://www.youtube.com/watch?v=braQRTFKUBA
Daniel
:O)
atlantean is offline Find More Posts by atlantean
Old Jun 05, 2011, 09:18 AM
isojed is offline
Find More Posts by isojed
Netherlands, ZH, Ridderkerk
Joined Aug 2010
Daniel
:O)
Try to adjust the throttle sub-trim on the Tx.
I had an similar issue i.e. none of the motors would spin.
isojed is offline Find More Posts by isojed
Old Jun 05, 2011, 09:28 AM
Joined Jun 2011
Thanks or the reply, Unfortunately, I just tried this, and it didn't seem to help, it's only occurring on one channel on the ESC (M3)
Old Jun 05, 2011, 10:43 AM
moombe is offline
Find More Posts by moombe
Belgique, Région Wallonne, Wavre
Joined Feb 2011
Does any of you flying Y6 or hexa/octo with the XA FC do fly (sometimes) in cruise mode, or do you only use hover ? Looking at the vids in this thread it seems you do only hover - I'm wondering how does a 600/650-class Y6 or hexa behave in cruise...
moombe is offline Find More Posts by moombe
Old Jun 05, 2011, 11:08 AM
Andre6553 is offline
Find More Posts by Andre6553
Vulcan skyhook multirotor
Andre6553's Avatar
South Africa, GP, Pretoria
Joined Feb 2011
i will be flying a rc-carbon Y6 very soon got the Frame just waiting for some parts then im all ready.
Andre6553 is offline Find More Posts by Andre6553
Old Jun 05, 2011, 11:27 AM
TheGunMan is offline
Find More Posts by TheGunMan
United States, NV, Las Vegas
Joined May 2011
Daniel
:O)
Sorry to hear that you have same problem
Contact xaurcraft support - I had to send mine to China for replaceent
Good luck!
TheGunMan is offline Find More Posts by TheGunMan
Old Jun 05, 2011, 12:21 PM
seafarer is offline
Find More Posts by seafarer
Joined Feb 2004
m trying to hook up a copilot 2 to my 650 has anyone done this? can anyone think of any problems I might run into. Im trying to make this thing hands free for a camera so that I dont have to worry about flying the thing. If anyone has a better Idea Im open to them.
The software in the x650 is way better than the copilot II. It is redundant. the x650 in hover mode is much more stable than a helicopter with the CPII. Sell you CPII on ebay and buy something cool.
Nick
edit - Plus the x650 doesn't care if you fly next to trees or on overcast days. 2 things the cp2 suxs at.
seafarer is offline Find More Posts by seafarer
Old Jun 05, 2011, 12:33 PM
louisjp is offline
Find More Posts by louisjp
Joined Jun 2011
Originally Posted by boxhead916 View Post
how does cello tape work for blade balence, ok? i have a vimeo wait to finish, of USB connection and TX cal., one thing, with this new ESC, when i poke throttle, motors idle up and when i poke stick down, the ESC that burn`d up if i poked the thro stick up and back down to zero the motors would not stop, and this ESC seems different on xair configstation, the mast movements move crisper, the motor stops, i am all most ready to say i got a bad ESC, video coming up of battery plugged in, as soon as vimeo finishes its thing...
@louisjp, i have same TX and RX, is there a red led lit on RX?
Hi, yes the red led it lit on the RX?
louisjp is offline Find More Posts by louisjp
Old Jun 05, 2011, 01:10 PM
pughy is offline
Find More Posts by pughy
United Kingdom, Merthyr Tydfil
Joined Mar 2011
gps
can we use the u-block centre software like xaircraft ? i have down loaded the software, it will connect but no info on screen
pughy is offline Find More Posts by pughy
Old Jun 05, 2011, 01:13 PM
Joshbb is offline
Find More Posts by Joshbb
Ironbridge (UK)
Joined Jan 2009
not yet
Joshbb is offline Find More Posts by Joshbb
Old Jun 05, 2011, 02:33 PM
Drone Minds is offline
Find More Posts by Drone Minds
@saradroneminds
Drone Minds's Avatar
United Kingdom, York
Joined Apr 2011
undercarriage
Does anyone know if we can buy the undercarriage shown here:
Drone Minds is offline Find More Posts by Drone Minds
Old Jun 05, 2011, 02:48 PM
boxhead530 is offline
Find More Posts by boxhead530
AMA 965811, FAA FA3MTYYYCK
United States, CA, Chico
Joined Nov 2010
so, anybody have the problem of when on usb power, and throttle poke starts motors and tho poke down wont stop motors? and camera servo would be real jumpy and noisey
the first ESC did that and it fried when i put battery on, the second ESC when under USB power would start AND stop, and camera servo was quite and smooth????
the first thing everyone said is battery in wrong, but different actions of config station and motors tells me something was wrong with 1st ESC-A4...
i thought camera servo was jumpy because of low power and no camera weight on board, and jumpyness was just noise that people talk about digatal servos having...with the new ESC there is none of that, from motors stopping to a very smooth servo travel slider controlled and aircraft hand held pitched and yawed now is smooth servo action...
yeah, i found and tried u-center, and its not for the this version of GPS equipment, but with the forth comming part and firmware update it will
boxhead530 is offline Find More Posts by boxhead530
Old Jun 05, 2011, 03:17 PM
Zirt57 is offline
Find More Posts by Zirt57
Zirt57's Avatar
Canada, ON, Cambridge
Joined Jan 2007
---Deleted---
Zirt57 is offline Find More Posts by Zirt57
Old Jun 05, 2011, 03:20 PM
Zirt57 is offline
Zirt57's Avatar
Joined Jan 2007
---Deleted---
Old Jun 05, 2011, 03:30 PM
seafarer is offline
Joined Feb 2004
Guys with one motor not spinning. I had that happen yesterday. One of the 8 motors would twitch instead of spinning. I powered down reset everything, same problem. I goosed it enough for it to be at 50% plus throttle and it came back to life, and worked fine after that. It's worth a try.
Nick
Discussion Xaircraft X650 Quad Owners and Testers Thread Z06 Tony Multirotor Talk 459 Feb 07, 2014 02:54 PM
Discussion x650 Technical Documents Translation:XAircraft X650 LED Module infmetry Multirotor Talk 9 Nov 22, 2011 06:03 PM
Discussion WANTED:Test-Pilots for X650&Letter to XAircraft Pilots/The final namelist determined xaircraft Multirotor Talk 35 Jan 11, 2011 07:28 AM
Discussion X650 the new quad from XAircraft to be launched very soon bob.titus Multirotor Talk 558 Nov 20, 2010 11:33 AM
Discussion Official!!!!!! Parrot A.RDrone USA owners thread Quad_Addict Multirotor Talk 59 Oct 27, 2010 11:48 PM
