Old Jun 04, 2011, 09:31 PM
rjarois is online now
Find More Posts by rjarois
rjarois's Avatar
royal oak, michigan
Joined Sep 2004
jingchen, glas to see your hammering the gps issues out......randy.
rjarois is online now Find More Posts by rjarois
Old Jun 04, 2011, 09:32 PM
Zirt57 is offline
Find More Posts by Zirt57
Zirt57's Avatar
Canada, ON, Cambridge
Joined Jan 2007
---Deleted---
Zirt57 is offline Find More Posts by Zirt57
Old Jun 04, 2011, 09:33 PM
Jingchen is offline
Find More Posts by Jingchen
Joined Jan 2010
Originally Posted by boxhead916 View Post
@Jingchen
i missing where that program is for looking at the gps. is it someting we can use?, the google earth was clunkey and i saw 9 for what i think was how mant sats, but i wont read chinese in this lifetime because im too old hehe, does google earth show if you have sat lock or just sats in the sky?
on the redo news, i put the new USB to the FC and AHRS, it seems to connect and behave normaly, ( as if i`d know what normal is) going to check GPS now...
also setting up video camera to show the dreaded battery plug in, and srceen shots of what i get on FC. should i wire up a switch between ESC and batt? yes i`ll find the highest rated amp and volts on get one of those switches that have low noise ie: no spark or arc. is the only reason no switch is use is failure in flight? yeah 20 years ago i could see that but now should not be a problem, any ideas collective mind?
In the ground station soft, the first number of 'GPS' section is telling the connected satellites. if you got 9, that's pretty well.
and here's the download link: http://www.xaircraft.com/wiki/images...Station_cn.zip
for the battery, it should be higher than 15C. but some brand battery do a 'discount' for you, it may be only 12C. so I suggest you to use a 20C battery.
and yes, you can solder a switch on the red wire.
Jingchen is offline Find More Posts by Jingchen
Old Jun 04, 2011, 09:37 PM
Jingchen is offline
Joined Jan 2010
Originally Posted by louisjp View Post
Hi there,
I recently just purchased a X650 and the aurora 9, i spent all of today building it, i uploaded all the new firmware and configured it. i have checked over and over to make sure it is built correctly and i am getting no movement from the propellers. The fan runs as well as the lights. i am really stuck...it is as if its not receiving any signal? please can someone help?
Thanks very much
first check what TheGunMan has suggested.
and the motor is still not going to spin, then use the subtrim on the radio to get the throttle down.
Old Jun 04, 2011, 09:39 PM
Norf is offline
Find More Posts by Norf
Fly low!
Norf's Avatar
VS , Germany
Joined Jul 2007
@ Jingchen :
New GPS sensors are looking interesting.
Please tell us your test results!!!
Im pretty exciting about results!!
To bad I cant test them But university and money does not allow any testing yet
too bad Im not ready with my sutdiing and earn some money......
Hope to hear from testers how the work on with the test units
Regards Norbert
Norf is offline Find More Posts by Norf
rjarois's Avatar
royal oak, michigan
Joined Sep 2004
cool, thanks jeff....randy.
Old Jun 04, 2011, 10:37 PM
daign is offline
Find More Posts by daign
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
I plan on using the X650c Landing gear on a Jakub frame. So far I have the following:
4x XA L1001C Landing Gear Plate Carbon Fiber
1x Pack XA L1003 Landing Gear Strut CNC Aluminum
4x XA L1004 Skid Pipe End Cap Rubber
2x XA L1005C Landing Gear Skid Pipe Carbon Fiber
1x XA L1006 Landing Gear Abutment CNC Aluminum
1x XA L1009 Landing Gear Fixer CNC Aluminum
Would anyone be willing to see if I'm missing anything on the landing gear to bolt up to a plate?
Appreciate it.
daign is offline Find More Posts by daign
Old Jun 04, 2011, 11:32 PM
Jairoblaster is offline
Find More Posts by Jairoblaster
The Master of Disaster
Joplin MO
Joined May 2009
Im trying to hook up a copilot 2 to my 650 has anyone done this? can anyone think of any problems I might run into. Im trying to make this thing hands free for a camera so that I dont have to worry about flying the thing. If anyone has a better Idea Im open to them.
Jairoblaster is offline Find More Posts by Jairoblaster
Old Jun 05, 2011, 12:30 AM
boxhead530 is offline
Find More Posts by boxhead530
AMA 965811, FAA FA3MTYYYCK
United States, CA, Chico
Joined Nov 2010
@ Jingchen, i have the google one from before, still cant read it he he, i found the ucenter, but could not connect, tonight when i used the google mapped xairstation it showed 6 and woud flash a 5...so should i plug a battery in this quadcraft and see if it works this time? heres an vid:
ESC leds and prop bal. (6 min 10 sec)
boxhead530 is offline Find More Posts by boxhead530
Old Jun 05, 2011, 01:21 AM
Joined Nov 2010
now for a bigger place, ovoville air corps, i feel in my bones the the first esc was bad, the config station just acted funny, slow, and as soon as i plugged new esc to config station it was quick, the servo for camera did not do ANY jumping around either, now i know one thing has nothing to do with the other, but the power all comes in thru esc to the FC, and ahrs, feedsback to esc...that the esc blew with 11.4vdc and just seemed strange with 5vdc, now i would have never seen the difference if it worked the first time. the main difference was how the tx would not stop motors under USB and the new esc will stop the motors using USB. other thing i just noticed is the camera servo being quite, and smoother moving when moving pitch of the x650, and when i used the slider it would be jumpy, now is is very smooth when the slider control from TX.
i was afraid to plug battery in, i`ll admit that, coming from a back ground of fabrication and assembly of space craft, i know which end of a driver screws he he
in those short moments, i saw how i`ll need a buzzer or batt led or get fpv gear that shows battery drain rate...
lift off, cuz i could not wait for a answer ond leds. (5 min 14 sec)
now alls left is the crashin...he he
Last edited by boxhead530; Jun 05, 2011 at 01:23 AM. Reason: seeing the vids, i`ll learn to slow down movment, have more light...sorry
Old Jun 05, 2011, 01:31 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Originally Posted by Jingchen View Post
these solutions are the possible solution by now, the final solution will come out about 7~10days later after the antenna was arrive at our test pilots.
Jingchen...Thanks
Rob
robone is offline Find More Posts by robone
Old Jun 05, 2011, 03:41 AM
Joshbb is offline
Find More Posts by Joshbb
Ironbridge (UK)
Joined Jan 2009
boxhead916 and everyone:
try to keep you videos short for Jingchen! it takes a lot of time and effort to watch the videos in China! I suggest you keep them to less than a couple of minutes if you can
Joshbb is offline Find More Posts by Joshbb
Old Jun 05, 2011, 03:51 AM
Joshbb is offline
Ironbridge (UK)
Joined Jan 2009
Hi Randy
I think the motor mounts look great
I would definitely use steel bolts on them though, especially the 2 main ones through the alloy arms!
I would also use steel bolts and nuts through the spacers on the motor mount too. I dont think nylon bolts will take the stresses for sustained periods and the threads may strip.
Your motor mounts would work for an X8 or y6 with square arms. let me know if you have any spare I want to make a small Y6 with x450 motors
cheers
Josh
Originally Posted by rjarois View Post
josh, when i was building up, i thought af that.....i really think its strong. i will swap out the 4 gear bolts for steel ones when i fly my camera. before the frame fails, i think the arms will. can i ask you...whats your opinion on the motor mounts, would you swap out for steel bolts?? the G-10 mount fits came out better than i figured, that's why i used them, and also this is gonna be for very gentle camera flying. i greatly value the input of the seasoned multi-rotor fellas, as i am just a noob. randy.
Old Jun 05, 2011, 05:21 AM
louisjp is offline
Find More Posts by louisjp
Joined Jun 2011
Originally Posted by TheGunMan View Post
Hi,
Can you confirm that the FC is getting signal from the receiver /from the configuration software/. If the bars are moving when you play with the sticks your receiver is working fine
Thank you very much for all your help.
can you confirm how we would do this?
louisjp is offline Find More Posts by louisjp
Old Jun 05, 2011, 05:50 AM
Drone Minds is offline
Find More Posts by Drone Minds
@saradroneminds
Drone Minds's Avatar
United Kingdom, York
Joined Apr 2011
I just got a gps and compass module, can someone tell me what I have to do to get them to work? I mean ignoring the current problems discussed above, do I just plug them in or do I have to install any software directly to the GPS. I'm mostly interested in the go home function, which I think works okay from reading this thread, butwhat is the setting called to add this to my radio - i.e. in the xAircraft configuration software which of the dropdown menu items is for Go Home?
Drone Minds is offline Find More Posts by Drone Minds
Latest blog entry: Drone Speed Gun Shootout
Discussion Xaircraft X650 Quad Owners and Testers Thread Z06 Tony Multirotor Talk 459 Feb 07, 2014 02:54 PM
Discussion x650 Technical Documents Translation:XAircraft X650 LED Module infmetry Multirotor Talk 9 Nov 22, 2011 06:03 PM
Discussion WANTED:Test-Pilots for X650&Letter to XAircraft Pilots/The final namelist determined xaircraft Multirotor Talk 35 Jan 11, 2011 07:28 AM
Discussion X650 the new quad from XAircraft to be launched very soon bob.titus Multirotor Talk 558 Nov 20, 2010 11:33 AM
Discussion Official!!!!!! Parrot A.RDrone USA owners thread Quad_Addict Multirotor Talk 59 Oct 27, 2010 11:48 PM
