Joined Feb 2011
Video as promised of a successful GPS and position Lock today
*note this was my second attempt after my first report. Winds picked up so it was a little more drifty. Gusts were approx 10 - 15mph Overall the compensation for wind was EXTREMELY impressive Also attached GPS sat positions
on the wiki site as i finially got radio set up only to find camera servo dont work, and this:
GPS Functions Video for Flight Mode, GPS,Compass Function Introduction and Instruction:
Look at the Input8 on'RC' tab, and flip the 2-way switch you selected on your Radio to check the states. GPS Free Mode In this mode, the copter is under manual control. Position Hold Mode In this mode, the copter is under semi-manual control. After you released the pitch & roll sticks about 2 seconds, the copter will enter Position Hold Mode. And once you move the sticks, the copter is back to manual control. GoHome Mode In this mode, the copter is under automatic control. The copter will return to home where it take-off automatically. You still can control it in this mode, but the GoHome function may fight against you. the pics show no green mast for manual, green mast in middle is semi manual, and full green mast is gohome mode... should that be a 3 way switch? instead |
Joined Jan 2010
GPS News
No good news today.
The antenna samples arrived yesterday. But seems not perfect. And continue to find another more professional provider. We want to find an antenna that performance like the one we tested last week(removed from other device). In the meanwhile, we are working on the firmware. the antenna solution is to enhance the anti-interfere ability. and the new firmware also try to lower down the electromagnetic radiation if possible, but need to test. we walk with two feet now. |
Joined Feb 2011
What about a Sarantel omni-directional Geo-helix S-type active antenna |
Ironbridge (UK)
Joined Jan 2009
the reason I made the 170mm centre plate drawings for the hexa was to be able to retain the X650 cover and the 'stock' look. If you want 190mm ones I expect Graham could sort you out cheers Josh |
Ironbridge (UK)
Joined Jan 2009
| Thread Tools | |
| Discussion Xaircraft X650 Quad Owners and Testers Thread | Z06 Tony | Multirotor Talk | 457 | Feb 02, 2012 01:24 AM |
| Discussion x650 Technical Documents Translation:XAircraft X650 LED Module | infmetry | Multirotor Talk | 9 | Nov 22, 2011 06:03 PM |
| Discussion WANTED:Test-Pilots for X650&Letter to XAircraft Pilots/The final namelist determined | xaircraft | Multirotor Talk | 35 | Jan 11, 2011 07:28 AM |
| Discussion X650 the new quad from XAircraft to be launched very soon | bob.titus | Multirotor Talk | 558 | Nov 20, 2010 11:33 AM |
| Discussion Official!!!!!! Parrot A.RDrone USA owners thread | Quad_Addict | Multirotor Talk | 59 | Oct 27, 2010 11:48 PM |
