United Kingdom, Weaverham
Joined Feb 2010
Ironbridge (UK)
Joined Jan 2009
its just a shame That Mr Peng or whoever made the decision to save a few dollars by not sending out a couple of test units and not using the better U-blox chipset is probably going to spend a lot more dollars fixing it. |
United Kingdom, England, Barrow-in-Furness
Joined Oct 2009
Back to hover mode
Ironbridge (UK)
Joined Jan 2009
No, Have a read of the data sheet, you can change some configuration messages after the u-blox lea- 5s has booted; via config_0 (although that pin does not seem to be connected), There is also a battery maintained ram memory . However there is no on-board flash memory so that means configuration settings have to be loaded into the chip from elsewhere every time it boots up. Some of the issues I currently see are about free memory in the gps module and the delivery of the messages to the chipset. Using the Lea 5H would have saved them and us a lot of hassles and cost them a lot less in the long run I suspect |
Bill Davenport AMA 28141 |
Latest blog entry: Disclaimer For All Purchases From...
Just a random note, finally got around to getting the Quanum onto the XL Y6. Haven't weighed it yet but it has some girth.
![]() Motors: 6x AVRoto 2814 ESC: 6x HK Blueseries 30A Props: APC 11x4.7 top and bottom Lipo: Turnigy 4S 5800mAh (30C) Hovering @ 21amps. 3.5 amps per motor to hover something so heavy is very impressive. Getting down to the MK3538 amp range for half the price on the AVRotos.I will run the bottom motors on 12x3.8 props as Josh did and check my findings.
Deviating from all the GPS talk... Has anyone managed/needed to balance there motor's?? I tried but really couldn't tell... My blades are balanced but when I'm videoing from my camera I'm getting a fair amount of vibration being picked up and I can't seem to isolate it! It doesn't appear to be effecting the way the quad flies and photo's come out a majority of the time fine with a high shutter speed, but video I'm getting lots of jello.
I've tried 3 different camera's and all suffer with varying degree's... Has anyone any suggestions? |
Ironbridge (UK)
Joined Jan 2009
nice build are you running the escs at 16khz? ps. I ran 12x38 on top not bottom.
I retightened them and it cured it, worth a check. |
Canada, QC, Greenfield Park
Joined Jun 2009
I know I reported early on of my GPS not locking issue with my X450 frame. I also posted on RCG and Jingchen that adding a torroid to the FC lead helped and I can now get satellite locks. I haven't done much to try altitude, position, and RTH yet so can't comment much on that. Jingchen told me they will look into it and it appears more folks are having issues. I'm sure it'll get worked out in the long run. I was ready to send my GPS back for refund until after the torroid helped. I'll continue to hope for the best so this gets worked out to everyone's satisfaction. I thank those with more knowledge than me (Joshbb, etc) who are working to help identify issues too.
Latest blog entry: Transplanting a Spektrum Dx4E Rf Deck...
i have been too busy to do a check maybe tonight will get to finish eletric check... |
| Thread Tools | |
| Discussion Xaircraft X650 Quad Owners and Testers Thread | Z06 Tony | Multirotor Talk | 457 | Feb 02, 2012 01:24 AM |
| Discussion x650 Technical Documents Translation:XAircraft X650 LED Module | infmetry | Multirotor Talk | 9 | Nov 22, 2011 06:03 PM |
| Discussion WANTED:Test-Pilots for X650&Letter to XAircraft Pilots/The final namelist determined | xaircraft | Multirotor Talk | 35 | Jan 11, 2011 07:28 AM |
| Discussion X650 the new quad from XAircraft to be launched very soon | bob.titus | Multirotor Talk | 558 | Nov 20, 2010 11:33 AM |
| Discussion Official!!!!!! Parrot A.RDrone USA owners thread | Quad_Addict | Multirotor Talk | 59 | Oct 27, 2010 11:48 PM |
