Old May 10, 2011, 11:47 AM
tom6696950 is offline
Find More Posts by tom6696950
Michigan
Joined Dec 2008
Originally Posted by quad master View Post
when did you order your plates?
same place you got your www.quadframes.co.uk
tom6696950 is offline Find More Posts by tom6696950
Old May 10, 2011, 11:51 AM
quad master is offline
Find More Posts by quad master
UavRotorKing.com
United States, CA, Yorba Linda
Joined Sep 2010
Originally Posted by Jingchen View Post
Hi Jeff,
It's recommended that to remove the red power line of 3 pin cable from the 2 X450 ESC. each X450 ESC may outputs slight different voltage, that some of the regulators on X450 ESC will get warm because of the vol differs.
the X450 ESC may not supply enough power for servos, or if your RX and other devices draw a lot of current, i suggest you to use a third-part UBEC for the electric parts. and also cut the red line from X450 ESC.
so if we want to use our camera servos we need to cut the red line on the x450 esc on the 3 pin servo cable. and use a ubec for electrics part what is the ubec?
quad master is offline Find More Posts by quad master
Old May 10, 2011, 11:55 AM
Z06 Tony is offline
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
Did you end up selling your X650 Tom?
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
UavRotorKing.com
Joined Sep 2010
yeah i know we both got them at same place. when did you order them? last week on thursday or friday ? did you get the g10 or carbon fiber? graham talked me into the g10. i got the y6 and the heka it was very cheap so i ordered both he is working on the octo center plates
Old May 10, 2011, 11:59 AM
Michigan
Joined Dec 2008
No Tom
Old May 10, 2011, 12:01 PM
Michigan
Joined Dec 2008
i order at the same time and also got hexa y6 in G10 Tom
Old May 10, 2011, 12:17 PM
UavRotorKing.com
Joined Sep 2010
hey anybody have a heka mikrokopter the production company i work for is paying me to work on there mikrokopter I guess it falls all the time one motor will stop in mid flight random motors will do it. I have not flown it yet to verify but should be getting it this week. but when motor fails it crashes every time they said. it is extremley heavy to they have 2 4s 6000mah batterys, canon rebel t1 with lens weght about 2.5 pounds and the 3 axis camera mount weight about 1.5 pounds. i do not know the specs on the motors yet but i think the heka is overloaded
wiggysk10 is online now
Find More Posts by wiggysk10
United Kingdom, Weaverham
Joined Feb 2010
Ive just ordered a 450 frame from quadframes , can you recommend them?
wiggysk10 is online now Find More Posts by wiggysk10
Old May 10, 2011, 12:26 PM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
If a heka Mikrocopter engine fails and it crashes, the same will happen to the heka XA so that must surely say that a X8 is the way to go, and I thought Mikrocopter was the Rolls Royce (Cadillac ) of copters.
All it costs to go the X8 route is the 4 motors and the Esc. Minimal engineering work and following Delfin and other's engine mounts, should be a piece of cake.
I am going to start making my mounts soon. Will make it so that it takes the X450 and X650 motors and try it with the X450 motors before buying the X650 motors.
robone is offline Find More Posts by robone
Old May 10, 2011, 12:35 PM
Z06 Tony is offline
Z06 Tony's Avatar
Joined Sep 2008
There is a Mikrokopter forum but not sure what the web adress is. You will have better luck there getting your answers.
Site Sponsor
rfsalem is offline
Find More Posts by rfsalem
Joined Jan 2011
Does GroundStation work on Vista??
i am unable to connect to GS on vista. GS crashes when connected to XA thru first tab.....any one done it on Vista???
rfsalem is offline Find More Posts by rfsalem
Old May 10, 2011, 12:42 PM
Michigan
Joined Dec 2008
Yes Graham is very good guy Tom
Old May 10, 2011, 12:43 PM
UavRotorKing.com
Joined Sep 2010
i will do a test on a heka xaircraft I think there is not enough thrust on the mk heka to stay in the air. if a motor fails so i will take all the equipment (nearly 4 pounds)off and see if it can fly with prop/motor lost. thanks everybody for your help maybe. I will post a video of my x650 lifting the mk and towing it to the retired aircraft field lol
Old May 10, 2011, 12:50 PM
robone is offline
Joined Sep 2010
i I will post a video of my x650 lifting the mk and towing it to the retired aircraft field lol
This I have to see
Old May 10, 2011, 12:52 PM
Zirt57 is offline
Find More Posts by Zirt57
Zirt57's Avatar
Canada, ON, Cambridge
Joined Jan 2007
---Deleted---
Zirt57 is offline Find More Posts by Zirt57
Discussion Xaircraft X650 Quad Owners and Testers Thread Z06 Tony Multirotor Talk 459 Feb 07, 2014 03:54 PM
Discussion x650 Technical Documents Translation:XAircraft X650 LED Module infmetry Multirotor Talk 9 Nov 22, 2011 07:03 PM
Discussion WANTED:Test-Pilots for X650&Letter to XAircraft Pilots/The final namelist determined xaircraft Multirotor Talk 35 Jan 11, 2011 08:28 AM
Discussion X650 the new quad from XAircraft to be launched very soon bob.titus Multirotor Talk 558 Nov 20, 2010 12:33 PM
Discussion Official!!!!!! Parrot A.RDrone USA owners thread Quad_Addict Multirotor Talk 59 Oct 28, 2010 12:48 AM
