Old Jan 11, 2011, 10:25 AM
quad master is offline
Find More Posts by quad master
UavRotorKing.com
United States, CA, Yorba Linda
Joined Sep 2010
who
who is from cnchelicopter. i thought i read that somebody on this works for cnchelicopter.
i was thinking about the foam tape thing is too much foam a bad thing?
i don't like the little foam blocks
i am planning on doing my first flight today hopefully it is a success (nervous). i can fly the 450 just fine but still nervous for flying my baby.
any tips you guys?
zirt57 thanks for backing me up on the spell check my wife and i laugh about it. i know i am bad at it but thanks
quad master is offline Find More Posts by quad master
Old Jan 11, 2011, 10:30 AM
UavRotorKing.com
Joined Sep 2010
[QUOTE=Pjtyros;17060771]Nice one Paul, I did the following video yesterday but it was gusty and toooo cold.
I tend to use cruise mode all the time as there is too much wobble in hover mode. Quite pleased so far, I find orientation a real problem too so I have fitted a carbon rod with an orange ball, helps quite a bit. I did some stills as well and these were quite reasonable. I will post some pictures later.
Gps with position hold and return to home will be most welcome.
Cheers
Paul
how long is your flight time with that setup?
Old Jan 11, 2011, 10:48 AM
Pjtyros is offline
Find More Posts by Pjtyros
Bournemouth UK
Joined Sep 2010
[QUOTE=quad master;17071232]
Cheers
Paul
I tend to run the lipo's singly and I have not done any testing in this area yet but 2200 is ok for about 6min + so I could easily get 12+ mins running the two in parallel.
Paul
Pjtyros is offline Find More Posts by Pjtyros
Old Jan 11, 2011, 11:19 AM
Zirt57 is offline
Find More Posts by Zirt57
Zirt57's Avatar
Canada, ON, Cambridge
Joined Jan 2007
---Deleted---
Zirt57 is offline Find More Posts by Zirt57
Old Jan 11, 2011, 12:41 PM
Paul@SCC is offline
Find More Posts by Paul@SCC
Chalfont St Giles, Bucks, UK
Joined Jan 2007
Originally Posted by Joshbb View Post
Hi Paul, Interesting about the foam, did you notice any more motor ticking?
Hi Josh. Not really.
thanks for sharing the video. It did not look like you got much altitude, could you maybe take it higher next time and see what you think about it?
On my first lipo I did get a little higher, that's when I grabbed a couple of photos. The poor quad was getting chucked all over the place. Once I got the pics that's was it for higher altitude flying for me.
Originally Posted by Michael64 View Post
Paul not bad video not perfect but alot better than mine anyway, it may be just me but even with the flying around hover mode looked smoother than cruise mode the horizon stayed straight. Would it be possible to get the settingss you are using even in the wind it was not as bad as mine. Thinking maybe the AHRS or controller thats not quite right maybe just a thought.
Michael64
Hi Michael. For me I prefer Hover mode. I do not have to worry about the quad banking over. In cruise you lose a lot of the correction wobble but you get more of the unlevel horizon, this is where a good tilt and roll camera platform will come in handy.
On the settings. I'm just using the latest updates from Xaircraft in + mode.
The only numbers I have changed are in the camera tab to get my shutter switch tuned.
In your post you say v 1.2 and on the video v1.21???
Hi Paul.
1.2 was the firmware I was using in the videos that Tony had linked to. I'm now using 1.21 in the vid from yesterday, BTW I put two packs through the quad and no glitches.
I am wondering if it is any better in + mode, I have only ever used X mode, what do you guys think?
Paul
There is one good way to find out.
Paul@SCC is offline Find More Posts by Paul@SCC
Old Jan 11, 2011, 01:00 PM
Zirt57 is offline
Zirt57's Avatar
Joined Jan 2007
---Deleted---
Old Jan 11, 2011, 01:51 PM
Paul@SCC is offline
Joined Jan 2007
props
Dont understand all the number stuff but they look good and I want a set. How much and where/when can they be purchased.
Paul (pjtyros) What servo are you using on your tilt compensation and is it performing smoothly?
Cheers
Paul
Old Jan 11, 2011, 02:24 PM
Joshbb is offline
Find More Posts by Joshbb
Ironbridge (UK)
Joined Jan 2009
Originally Posted by zirt57 View Post
OK Josh, here it is:
Sorry, no English sub-titles.
- Jeff
Thanks Jeff your a star.
they tested on the equivalent of a 4s battery so you cant really compare it to previous tests which were at 11.1v A wasted opportunity to directly compare maybe?
they had it up to 170 watts which gave 1.1kg thrust, they did not hold it there long because of the motors melting though. grams per watt at that thrust =6.47
at 610g thrust was at 75 watts & 8grams per watt... and 4800rpm
510g thrust at 60 watts, 8.5 grams per watt
Joshbb is offline Find More Posts by Joshbb
Old Jan 11, 2011, 03:24 PM
Z06 Tony is online now
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
Cant believe they did not test the CF and stock props back to back. Wonder if they are gonna start selling CF props now.
Z06 Tony is online now Find More Posts by Z06 Tony
Site Sponsor
Old Jan 11, 2011, 03:45 PM
UavRotorKing.com
Joined Sep 2010
hey you guys i did my first flight under 1.21 flight control and 1.10 on AHRS plus style and 3 cell battery. it seems like helicopter is way too sensitive to my controls throttle is fine it just pitch,yaw, roll, controls seems too sensitive. anybody have any suggestions. before i try to mess around with settings i don't want to make problems worst.
thanks Glen
Old Jan 11, 2011, 03:49 PM
Paul@SCC is offline
Joined Jan 2007
thanks Glen
Glen. Try adding some expo on your radio. I would leave yaw/rudd as it is.
Be careful. When I added expo to Hover mode it was OK but when I flicked into cruise it felt far to slow to respond.
Old Jan 11, 2011, 04:06 PM
UavRotorKing.com
Joined Sep 2010
what does expo do i never used that? (i have a jr radio xp6102 ) how much expo should i try? could it be that i am just a beginner all again ? it definitely more sensitive than my 450 trex
Old Jan 11, 2011, 04:33 PM
Paul@SCC is offline
Joined Jan 2007
Glen. It makes your sticks less sensitive . Get to your expo setting and dial in + 25% give it a try.
What mode are you testing, hover or cruise??
I think this is the quick way to get the feel that you like. Probably the best way would be to adjust the figures in the Xaircraft tools. I'm sure one of the gurus will be able to assist you with that.
Old Jan 11, 2011, 05:44 PM
UavRotorKing.com
Joined Sep 2010
i am testing hover which is channel five off right ? switch down hover thanks paul who are the gurus ?
Old Jan 11, 2011, 06:03 PM
Eternalflight is offline
Find More Posts by Eternalflight
"I want more air time!"
Eternalflight's Avatar
Joined May 2008
Quad Master,
what radio do you have?
Ken
Eternalflight is offline Find More Posts by Eternalflight
Discussion Xaircraft X650 Quad Owners and Testers Thread Z06 Tony Multirotor Talk 459 Feb 07, 2014 02:54 PM
Discussion x650 Technical Documents Translation:XAircraft X650 LED Module infmetry Multirotor Talk 9 Nov 22, 2011 06:03 PM
Discussion WANTED:Test-Pilots for X650&Letter to XAircraft Pilots/The final namelist determined xaircraft Multirotor Talk 35 Jan 11, 2011 07:28 AM
Discussion X650 the new quad from XAircraft to be launched very soon bob.titus Multirotor Talk 558 Nov 20, 2010 11:33 AM
Discussion Official!!!!!! Parrot A.RDrone USA owners thread Quad_Addict Multirotor Talk 59 Oct 27, 2010 11:48 PM
