Old Oct 22, 2010, 02:30 AM
matyou is offline
Find More Posts by matyou
matyou's Avatar
Bay Area California
Joined Dec 2009
Question
30 dBi Grid Antenna
Hi,
I have been wondering what it takes to create a FPV plane that will be able to reach extreme distances. One of the 3 major challenges is the video feed besides RC and battery capacity. So to achieve such distances can a 30 dBi grid antenna be used? I understand that the beam width is only 5.3 degrees but can a antenna tracker system accurately point the antenna at the plane such that the plane will be in the narrow rf window?
matyou is offline Find More Posts by matyou
Old Oct 22, 2010, 02:32 AM
chancesAU is offline
Find More Posts by chancesAU
chancesAU's Avatar
Australia
Joined Apr 2008
Of course, also at over a mile, that small rf window opens up quite a bit.
chancesAU is offline Find More Posts by chancesAU
Old Oct 22, 2010, 07:12 AM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
5.3 degrees may well provide a wide window to fly in when you're miles out, but it's still only 5.3 degrees and means you'll have to keep your antenna locked on and pointing in exactly the right direction to a very high accuracy for the entire flight.
I'm not sure what the gain is on a normal satellite TV dish, but they're tricky enough to line up; just imagine how much harder it would be if the satellite were moving!
Antenna trackers are great (I use one), but the thing to note here is that although as a pilot you can cope with video degradation due to static or a weak signal, the antenna tracker which depends on a solid audio channel will not. That said, when you're miles out you should only need a successful data packet every 10, maybe even 30 seconds to keep it pointing on course.
Ian Davidson is offline Find More Posts by Ian Davidson
Old Oct 22, 2010, 07:19 AM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
in our experience the RF window doesn't open up considerably. moving the antenna 2 or 3 centimeters can be the difference between bad signal and perfect signal.
forget about using an antenna tracker for dish antennas far out, the antennas do not always need to be pointed at the plane to pick up the best signal
trappy is offline Find More Posts by trappy
Old Oct 22, 2010, 10:44 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
30 dbi dish antennas are really meant for point to point, not to track a moving target. At 5.3 degrees of beam, there is little servo resolution to keep you on target. If you can increase the servo resolution (ie gear it down), then this would be better and make this a much better scenario.
Two dishes pointed 3-4 degrees apart on a diversity controller would work great.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 22, 2010, 11:52 AM
matyou is offline
matyou's Avatar
Bay Area California
Joined Dec 2009
Old Nov 14, 2010, 11:49 AM
420choky is offline
Find More Posts by 420choky
Joined Sep 2010
antenna
-Alex
24dbi hypergain dish antenna,, 8 degree beam and a 14 dbi flat panel with a duo reciever 2.4 ghz ive gotten 2 miles out and 2200 ft up . today im gunna test the antenna traker on the flat patch and see how the 2 work together .. i dont trust the antenna tracker ..
420choky is offline Find More Posts by 420choky
Old Nov 14, 2010, 10:32 PM
420choky is offline
Joined Sep 2010
tested it
well it worked great.. forgot to set home on the tracker.. but once i did that it freaking got it.. couldnt wait till the fog went .. flew only depending on my gps and the hope my antenna worked then i got a break
THIS IS WHY.wmv (14 min 17 sec)
i went 5 miles out batt was so low i lost it
but that vid is processing
For Sale PS3 Titles.. DIRT and GRID $40 shipped rz22g Non R/C Items (FS/W) 2 Sep 25, 2010 12:29 PM
Discussion Antenna upgrade: windsurfer mod or grid antenna? kyle7119 FPV Talk 6 Jul 08, 2010 06:26 PM
Discussion 2.4 GHz 11 dBi Dual Diversity Antenna GallopingGhost FPV Talk 6 Nov 15, 2009 08:59 AM
Discussion Anyone ever use 23 dBi 900 Mhz. antenna Faro69 FPV Talk 7 Sep 04, 2009 05:11 AM
Discussion 2.4 GHz 9 dBi Rubber Duck Antenna omnidirectional G-unit FPV Talk 14 Oct 14, 2008 04:45 PM
