Old Oct 22, 2010, 02:13 AM
jimaquo is offline
Find More Posts by jimaquo
Australia, ACT, Scullin
Joined Oct 2010
Tea Candle Race
G'day guys,
I'm new to the forums but just thought I'd tell you about my family's tea candle race.
Every year the men folk issue a challenge to build the highest performing race boat powered by a single tea candle. My father and uncles are all machinists of one type or another and the standards are pretty high. This year I have issued a challenge to the reigning champion (Dad) and am confident of my first win.
The rules are simple.
1) The boat is to be propelled by a single tea candle
2) No component of the boat may be commercially availible
3) The winner may not re-use last years vessel
Other than those restrictions, the sky is the limit.
This year I am building a small light weight in-line stirling engine with the hot cylinder over the candle and the cold cylinder inverted with the head thru the hull into the water.
I'm going with a multi-chined hull out of balsa with a split keel amidships to accomodate the cold cylinder heatsync. The rough drawings look good but I'm always open to suggestions
jimaquo is offline Find More Posts by jimaquo
Old Oct 22, 2010, 05:35 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Sounds like a great challenge! We need pictures....
You'll get a lot of help in the steam forum too:
http://www.rcgroups.com/steam-boats-656/
patmat2350 is offline Find More Posts by patmat2350
Old Oct 22, 2010, 06:35 AM
Capt.Crash is offline
Find More Posts by Capt.Crash
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
Yes...sounds like a lot of fun...got any pics of any of these boats?
Capt.Crash is offline Find More Posts by Capt.Crash
Old Oct 22, 2010, 07:56 PM
jimaquo is offline
Joined Oct 2010
unfortunately none with me. I'll get hold of Dad and see if he's got any floating around. I'm going to video this years race and throw it up on youtube.
I'll touch my sketches up and post some of them in the near future
Old Oct 22, 2010, 10:43 PM
MILLERTIME is online now
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
We want pictures.
MILLERTIME is online now Find More Posts by MILLERTIME
Old Oct 23, 2010, 09:08 PM
jimaquo is offline
Joined Oct 2010
Below is a rough concept drawing of my boat. It's not pretty but it's a reasonable representation of what I'm going for.
I'm a bit concerned with the flywheel being so high but I can't really find a better spot for it. If worst comes to worst though, I'll turn the cylinder head of the cold cylinder into a fin keel and drop some weight lower, it'll increase my drag but it means I can lose the ballast...
Suggestions?
Old Oct 23, 2010, 10:59 PM
MILLERTIME's Avatar
Joined Apr 2004
Very interesting.
Old Oct 24, 2010, 06:53 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Why can't the flywheel be on the input side of the reduction gear?
And do you need reduction? Every gear pair is a loss. What sort of speed (rpm) does the motor make? If high speed, a small prop running fast might be more efficient that a big prop running slow with reduction...
And of course you want minimum drag in the water... think of a racing scull (shell), not a deep vee displacement hull...
Old Oct 24, 2010, 07:20 PM
jimaquo is offline
Joined Oct 2010
Thanks Patmat,
Lowering the flywheel and taking it aft would work a treat. The hull is flat bottomed after the keel splits. Stirling engines can rev quite high bit have very little torque, especially at low rpm. Ideally I'd have a single cam running between both cylinders but I can't figure a way to do that with the height difference. Does anyone know the optimal prop shaft angle?
Old Oct 25, 2010, 01:58 AM
jimaquo is offline
Joined Oct 2010
Sorry for the disjointed English in the previous post, I was at work typing it out on my iphone.
Old Oct 25, 2010, 07:22 AM
tghsmith is offline
Find More Posts by tghsmith
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
as this is low power, high rpm set-up, hull drag will be your factor(you won't be getting on plane).. take a look at torpedo boats from the 1890s about as slippery as you can get and still keep the hull in the water.. have the lines of british harbor class boat that might work very well as a starting point, will try to post them later..
tghsmith is offline Find More Posts by tghsmith
Old Oct 25, 2010, 07:54 PM
jimaquo is offline
Joined Oct 2010
Thanks mate, that's brilliant. Funnily enough it looks very similar to what my build drawings came out like. I'm sure I can save myself a lot of time and squilla adjusting that hull to suit my needs instead though.
Old Oct 26, 2010, 02:11 PM
tghsmith is offline
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
as close as you can to a horizontial prop shaft will help(no wasted force pushing the bow up or down) think about placing the cold cyl. in a water cooled jacket inside the hull..
Old Oct 26, 2010, 06:17 PM
Shaun Hendricks is offline
Find More Posts by Shaun Hendricks
3 Blades to the Wind
Shaun Hendricks's Avatar
Atascadero, California, United States
I'd probably go for an alpha cycle stirling with the hot cylinder horizontal and the cold inverted and nose touching the water (but not displacing much water, drag can negate the power gains, unless you use a open/flooded compartment for cooling). This would eliminate all the cross cylinder gearing and if you used a toothed pulley as the common crank wheel, you could drive a nice double stern paddlewheel, maybe 3 paddles each side. That would be a very efficient drive train and would run forever on the candle.
Shaun Hendricks is offline Find More Posts by Shaun Hendricks
Old Oct 26, 2010, 07:59 PM
jimaquo is offline
Joined Oct 2010
I thought about that but the low down torque needed to drive a paddle wheel just isn't in the stirling. The 'L shaped alpha has always held some appeal but the issue of getting the power to the fluid has always been ugly
Alert NRC - MD Offroad Race Track - Great Fun Race this Sat bbecker Off-road Cars 0 Oct 19, 2010 08:03 AM
Whoops! WHOA ! TEA party leads to arrests... oh wait, those aren't TEA partiers ! D B Cooper Life, The Universe, and Politics 34 May 13, 2010 08:10 PM
Whoops! Light a Candle Don Sims Humor 0 Sep 05, 2002 07:54 AM
