Old Nov 19, 2010, 11:28 AM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Awesome
my msr motors have been good as well.
i might use SP motor in my MSR or in a scratchbuilt perhaps.
The 4-site looks temping as well, BUT UMX 300 looks better lol
Originally Posted by maukabud View Post
Didn't know that...but don't feel bad...I haven't had the best luck w/ HH motors either, excluding the mSR motor in the mSR...which I average about a motor every three months in the winter (when it gets heavy usage).
And...IMO...I am noticing more power w/ the SP motor...my heavy dawg 4S can actually hover for quite a few seconds on a fresh batt. Guess I got a "grade A" handpicked one. (RG)
Bud, grade A Bud
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Nov 19, 2010, 03:10 PM
PositivelyJoe is offline
Find More Posts by PositivelyJoe
add lightness
PositivelyJoe's Avatar
Big time Minneapolis, Good Ol' St Paul
Joined Oct 2007
how about a motor from a Syma S107 heli? replacement motors are only $4 and free shipping.
PositivelyJoe is offline Find More Posts by PositivelyJoe
Old Nov 19, 2010, 08:47 PM
hydro_pyro is offline
Find More Posts by hydro_pyro
Blade mSR freak
hydro_pyro's Avatar
Irish Hills - SE Michigan
Joined Jan 2010
maybe for an msr tail motor...
hydro_pyro is offline Find More Posts by hydro_pyro
Old Nov 21, 2010, 03:56 PM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
more on solo pro
today i flew at the local gym. i had the sp on my 22" Elf, which is a 120 sq in, 48 gr auw hi winger, 9% undercamber airfoil, 2mm depron. the prop was the 130/70 and i used 110 and 150 cells. the flying times were over 5 minutes without reaching lvc. the interesting thing is that the sp being more powerful still does not overload the tiny 110 mah cell.
the sp is breaking-in-it's now way more quiet, and the power is too much for this plane. if i am not very careful with the throttle, it climbs at 45-60 degrees with a small increase. i will have to go back to the clear end bell motor and the 160/70 prop, so the power is not too much.
phil alvirez is offline Find More Posts by phil alvirez
Old Nov 24, 2010, 08:14 PM
maukabud is offline
Find More Posts by maukabud
HELP I AM BEING SET UP!!
maukabud's Avatar
United States, OR, Deschutes
Joined Jul 2009
....and isn't that a beautiful thing!
Bud, :thumbup: Bud
maukabud is offline Find More Posts by maukabud
Old Nov 25, 2010, 02:13 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Too much power for a 48 gram plane?
Wow
Imagine the possibilities of the "always over weight" foams I build???
Lol
Oh yeah baby!
Old Nov 25, 2010, 05:52 AM
Joined Jul 2007
low wing loading
Wow
Lol
Oh yeah baby!
the key is low wing loading. my plane is 120 sq in and thin, 9% undercamber airfoil. this gives 0.4 grams per sq in and high lift.
with that low wing loading and high lift you need way less thrust.
Old Nov 25, 2010, 08:56 PM
rc crashburn is offline
Find More Posts by rc crashburn
SUPERB RC CRASH MASTER
rc crashburn's Avatar
Houston, Texas USA
Joined Aug 2004
I can understand where you are coming from if you are primarily flying indoors in a confined space.
The constant turning is easier (MORE FUN) if the speed is easy to hold in check.
Should be way less touchy on the throttle with the 130/70 prop swap.
Why not change the prop first before considering the motor change?
rc crashburn is offline Find More Posts by rc crashburn
Old Nov 25, 2010, 11:49 PM
Joined Jul 2007
dear sir: thank you very much for your advice. but am not flying just indoors. i fly mostly outdoors, and not turning constantly. i have tried the change that you suggest. i like to fly as slow as possible, and the combination of clear end bell motor and 160 prop, as supplied by the manufacturer, fits better my goals. likewise, the black end bell with the 130. thanks again for your intention to help.
Old Nov 26, 2010, 01:12 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Has anyone tried placing a 9 tooth UM pinion on the tail motor off a 120 SR to see what kinds of thrust it can generate?
Old Nov 26, 2010, 03:41 PM
maukabud is offline
maukabud's Avatar
Joined Jul 2009
There's an off-the-wall idea. You'd prolly be the first. I think you should try it.
Old Nov 26, 2010, 04:42 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Lol maybe
I have a bad one that I may be able to revamp perhaps.
Old Nov 26, 2010, 06:49 PM
maukabud is offline
maukabud's Avatar
Joined Jul 2009
Lol maybe
Dude. 10,172 posts and youv'e only signed up August '09??? I think you have "RCG-post-itus".
Old Nov 26, 2010, 06:56 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
I Am but I don't think that post count Is true.
Old Dec 01, 2010, 09:46 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
As he posted 2 hours after you posted the count number while now off by a couple of hundred was most likely right at the time...
livonia bob is offline Find More Posts by livonia bob
Discussion Blade MSR or Nine eagles solo Pro jtravel Coaxial Helicopters 2 Oct 18, 2010 06:45 AM
For Sale Nine Eagles Solo Pro II V5 Deluxe Kit (Price update) iflabs Aircraft - Electric - Helis (FS/W) 2 Oct 10, 2010 05:13 PM
Wanted Nine (9) Eagles Solo Pro - 'copter only. emarkay Aircraft - Electric - Helis (FS/W) 3 Oct 07, 2010 11:00 AM
Discussion Revell Proto MAX RTF/Nine Eagles Solo Pro RTF $69.99 at Tower Hobbies Firehawk989 Hot Online Deals 1 Sep 29, 2010 12:16 AM
Wanted Nine Eagles Solo pro radio flyerjs Aircraft - General - Radio Equipment (FS/W) 0 Sep 20, 2010 04:10 PM
