Espritmodel.com Heli Air
Old Oct 25, 2010, 03:43 PM
Way to many airplanes!
Canada, QC
Joined Oct 2009
Are you sure your $11 caliper is accurate enough???
Seriously though, here's a decent trick I've learned from an old engineer. Before mesuring anything, he would always pick up a sheet of paper from a ream of 500 he had on his desk. He knew it was 20lb paper so the average thickness was 0.097mm. He would mesure the sheet, which would give him a quick idea if the caliper was still ok. Then, he would lightly pull the sheet slowly, literally wiping the caliper to make sure there was not anything left over from a previous mesurement. Close it back, then check the zero. And only then, mesure something! If you have 24lb paper available, then it's 0.12mm (even better). Sure enough, a sheet of paper is not a true calibration standard, but you should be very close (otherwise, your 500 sheet packages would simply not fit in the boxes, or in the printers trays). And wiping the caliper is not a bad idea either, particularly if you could have picked up grease, or any dirt from something else before.
From there, you can also do two things:
Pick up 10 sheets of standard 20lbs paper and you should get very close to 1mm. (10 sheets would be 0.97mm, but getting 1mm is pretty much normal)
Pick up a random bunch of sheets, mesure it, then divide my 0.097mm) and you should get the exact number of sheet you picked up.
Not that I'm thinking your $11 caliper is bad and mine is better... I didn't spent much on it either!
Back to the thread: Definitively look like I may install a motor in my original Sukhoi very soon, and I have a friend who has a Mustang who could get my second one soon.
RealGambler is offline Find More Posts by RealGambler
Old Oct 26, 2010, 10:44 AM
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
My $11 Cen-Tech caliper says: "accuracy of +/- 0.001" (0.03mm)"
Surely they wouldn't lie to me!
Even worse, my brother bought it and gave it to me!
My actual total cost was $40 gas money to his home.
My $40 Cen-Tech is extremely accurate!
Another tip:
Use a small pin to spread the J-B Weld on the inside hole of the pinion...After you drill it out with a #62 bit.
ps... Could someone do something about this garbage weather???
rc
RCBABBEL is offline Find More Posts by RCBABBEL
Old Oct 26, 2010, 10:57 AM
Canada, QC
Joined Oct 2009
I've installed one of my SP motor in my old Sukhoi (the noisy motor I got out of two of them)... Sadly though, it's not the plane I fly the most, and sure enough, as you said, weather is very SO-SO... So it will take a while before I truly rake a lot of fligths on it.
Weather wise, I went flying my XP earlier yesterday... Very gray sky, but almost no wind. First battery went fine. 20 second into the next battery, the sky opened without warning. I'm not talking drizzle here... One second nothing, next you're totally wet by the time you pack your things. So that's why I went home and decided to swap the motor on my old Sukhoi. I basically had nothing better to do.
BTW: I had felt the power wasn't there anymore, but it was still flying quite well. Pulled the old motor and tested it: it was getting very hot. So this thing was probably drawing more than 2 amps on it's own. Yeah for Hyperions.
Old Oct 26, 2010, 11:04 AM
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
If it wasn't for Hyperions, I wouldn't be flying ultra-micros!
Three cheers for Hyperion...
1.
2.
3.
rc
Underpowered planes Stink!!
Old Oct 26, 2010, 11:32 AM
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Kris... is offline Find More Posts by Kris...
Old Oct 26, 2010, 03:24 PM
Windsor, Canada, near Detroit
Joined Jul 2007
more details on brushes
Originally Posted by microheli View Post
Here is a MSR to compare
am not sure what to look at. am not even sure if it is brushed or brushless.
i have never seen the inside of 1 of these motors.
about the brushes, if any, i can't see them. how are the brushes placed? are they at 90 degrees to the rotor, or inclined?
meaning, are oriented in certain way that do better if turning on the way they do, so if reversing rotation they will not be so efficient?
if brushed, have you tested it for timing?
thanks
phil alvirez is offline Find More Posts by phil alvirez
Old Oct 26, 2010, 05:15 PM
microheli's Avatar
Joined Jul 2006
with description
microheli is offline Find More Posts by microheli
Old Oct 26, 2010, 05:33 PM
Joined Jul 2007
great details
with description
thank you very much. terrific details.
now, do you think that the motor has some advance timing?
is there a way to check it?
can it be changed?
if rotating the other way (like on a pusher), do the brushes work fine? i can't see exactly how they fit, that's why i ask. still, for what i can see, i think that the springs are made for the motor to turn on certain direction, and not the other way. just an impression.
regards
Old Oct 26, 2010, 06:56 PM
Did you commit aviation today?
turboparker's Avatar
East Bethel, MN USA
Joined Jul 2009
Originally Posted by RCBABBEL View Post
......ps... Could someone do something about this garbage weather???
rc
RC,
It's been raining here since Saturday. 50 MPH winds w/driving rain today. At least if it wasn't raining, I could fly my carbon fiber stunt-kite that's designed for extreme winds. Just got my big shortwave transmitting antenna up for my Amateur Radio station (another expensive hobby of mine). Wasn't planning on a wind-test so soon. Hope the antenna survives...
Joel
turboparker is offline Find More Posts by turboparker
Old Oct 26, 2010, 07:27 PM
Joined Jul 2007
weather
Another tip:
rc
perhaps because i have spent the past 20 years here, i can tell you about weather.
the place where i live is called 'The City of Windsor', but i think the name is missing something: i think it should be called "The City of Winds-or Storms'.
we have the most fantastic array of winds, turbulence, storms, rain, hail, snow, ice, thunder, lightning, fast moving fronts (am missing something?) that anybody could dream of. sometimes i can't fly for over a month. then we have several days of great weather-the kind i like: no wind! but then i get so tired, flying every day...on the bright side, it gives more time to design, build, get into the net and find out about all the terrific things all you great guys are doing.
and it may help us to appreciate more the good weather when it happens.
Old Oct 27, 2010, 09:23 AM
Joined Jul 2007
solo pro and similar
i think it will be great if we bring data regarding not only the solo pro, but the other motors that are similar, like the clear and black end bell, the msr and whatever, in the 8.5mm class, so we can compare them.
by the way, just as the solo pro is being called SP, perhaps could save time typing if we call the clear and black end bell C and B
that is :
solo pro: SP
clear end bell: C
black end bell: B
and of course: mSR
Old Oct 27, 2010, 09:57 AM
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Phil,
Are you referring to the Blade mSR heli motor?
rc
Old Oct 27, 2010, 09:59 AM
Canada, QC
Joined Oct 2009
and of course: SMR
Do you mean mSr? or is it a different motor?
And here we go, RCBabbel beat me to the punch again
Old Oct 27, 2010, 10:19 AM
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Walkera 4#3 's Stock Motor Carbon Brush Upgrade
Back in my Walkera days, I was going through brushed motors like chewing gum.
Check out what EQMOD came up with.
Pretty impressive!
http://www.rcgroups.com/forums/showthread.php?t=940227
rc
Old Oct 27, 2010, 10:49 AM
Joined Jul 2007
posts 27-28
yes, guys. I got mixed-up with the alphabet soup.
the blade msr
i changed it on the post.
Discussion Blade MSR or Nine eagles solo Pro jtravel Coaxial Helicopters 2 Oct 18, 2010 06:45 AM
For Sale Nine Eagles Solo Pro II V5 Deluxe Kit (Price update) iflabs Aircraft - Electric - Helis (FS/W) 2 Oct 10, 2010 05:13 PM
Wanted Nine (9) Eagles Solo Pro - 'copter only. emarkay Aircraft - Electric - Helis (FS/W) 3 Oct 07, 2010 11:00 AM
Discussion Revell Proto MAX RTF/Nine Eagles Solo Pro RTF $69.99 at Tower Hobbies Firehawk989 Hot Online Deals 1 Sep 29, 2010 12:16 AM
Wanted Nine Eagles Solo pro radio flyerjs Aircraft - General - Radio Equipment (FS/W) 0 Sep 20, 2010 04:10 PM
