Old Dec 07, 2010, 04:15 PM
HELP I AM BEING SET UP!!
maukabud's Avatar
United States, OR, Deschutes
Joined Jul 2009
I've gotten the GWS micro gear puller...works great! A bit spendy, but hey what the heck, my 4Site has a new lease on life!
around 100 flights on the SP motor now...sounds even a little more "growly" then when new...and runnin' strong...likes it!
Three more SP motors on the way for me...that should keep both my 4S and mSr running all winter.
Bud, growly Bud
maukabud is offline Find More Posts by maukabud
Old Dec 07, 2010, 04:26 PM
R.C. Aviation Fanatic
Razors edge 29's Avatar
Canada
Joined Aug 2009
anyone figure out the thrust of this motor vs the UMP51 - suk xp motor?
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Dec 09, 2010, 10:28 PM
They took the bar
javelina's Avatar
Arizona
Joined Aug 2007
subscribed... (bought the micro puller, and a few of the SP motors for my UM's)
Great thread!
javelina is offline Find More Posts by javelina
Old Dec 09, 2010, 10:43 PM
Canada
Joined Aug 2009
I also bought a puller and am awaiting the pin vise mini drill to bore out the pinion to get back onto the motor shafts lol
heat doesnt work well
Old Dec 09, 2010, 11:02 PM
maukabud's Avatar
Joined Jul 2009
a standard manual fingertip type drill works fine...brass is soft.
Old Dec 09, 2010, 11:11 PM
Canada
Joined Aug 2009
i dont have any bit that small yet - but can prob borrow one from someone.
also - another issue i am having
some of the SP motor pinions are so close to the motor can that the puller plate wont fit between can and pinion. Even a par if thin needle nose pillers wont either
damn, damn, double damn
I built an UM Sumo and can't fly it - no motor
Old Dec 09, 2010, 11:13 PM
maukabud's Avatar
Joined Jul 2009
Huh that's strange...both of mine have plenty of clearance clarence...
ummm..not to insult yer intelligence...not putting them in backward are you?
EDIT: you could always start with the hacksawed penny trick...to get enough clearance (clarence) for the puller.
Old Dec 09, 2010, 11:16 PM
Canada
Joined Aug 2009
lol putting what in backwards?
the puller plate only goes on one way?
Old Dec 09, 2010, 11:24 PM
maukabud's Avatar
Joined Jul 2009
Yeah...guess it could only fit one way...lol...
see my edit above...if there's enough room between the can and pinion for a slotted penny to fit in you could start it that way...
But maybe you should use an American penny...it's not worth as much as a Canadien penny anymore...lol...and mostly zinc or something to boot.
Old Dec 09, 2010, 11:30 PM
Canada
Joined Aug 2009
LOL
I am not sure if even a penny would work - but i could try that trick
thanks for tip!
All i am trying to so is bring the pinion out further to fit a UM PZ gear box as i dont have any pz pinions to spare.
i know the SP pinion isnt 9 tooth, but i figured i'd try it in on the gear box anyways lol
Old Dec 09, 2010, 11:36 PM
They took the bar
javelina's Avatar
Arizona
Joined Aug 2007
probably been asked, but is there a source for the pinions (that will work with the PZ UM setups)? I'm going to reuse the pinion of my dead UM T-28 motor. Was hoping there was another source.
TIA,
-jav
Old Dec 09, 2010, 11:42 PM
Canada
Joined Aug 2009
the pz um motors have a longer shaft than the SP motors do
seeing that this is the case - which motor really has more muscle? lol
Old Dec 10, 2010, 06:20 AM
Way to many airplanes!
Canada, QC
Joined Oct 2009
The way the pinion is fixed on all these motors, SP or original, can give us a good idea of how cheap they are... With both types of motors, I got pinions all over the place. Sometime the shaft is protruding, sometime it's the pinion that is out a bit (that so great because the puller is much easier to align) and sometime they are flush.
I had one SP motor like Razor Edge where the puller barely fitted under the pinion as well... It's basically a lottery!
RealGambler is offline Find More Posts by RealGambler
Old Dec 10, 2010, 10:36 AM
Canada
Joined Aug 2009
fun eh mon amis?
I managed to get this one off, but it no work in pz gear box
I know this has been tried by others before but i thought I might get lucky for once lol.
Not soo much.
Will have to wait I suppose.
Old Dec 10, 2010, 04:29 PM
Canada
Joined Aug 2009
well i managed to get the pinion of the SP motor and found an older 9th PZ pinion, honed it out and stuck on motor shaft of sp motor with some JB.
Now the waiting game.
Discussion Blade MSR or Nine eagles solo Pro jtravel Coaxial Helicopters 2 Oct 18, 2010 06:45 AM
For Sale Nine Eagles Solo Pro II V5 Deluxe Kit (Price update) iflabs Aircraft - Electric - Helis (FS/W) 2 Oct 10, 2010 05:13 PM
Wanted Nine (9) Eagles Solo Pro - 'copter only. emarkay Aircraft - Electric - Helis (FS/W) 3 Oct 07, 2010 11:00 AM
Discussion Revell Proto MAX RTF/Nine Eagles Solo Pro RTF $69.99 at Tower Hobbies Firehawk989 Hot Online Deals 1 Sep 29, 2010 12:16 AM
Wanted Nine Eagles Solo pro radio flyerjs Aircraft - General - Radio Equipment (FS/W) 0 Sep 20, 2010 04:10 PM
