Old Oct 21, 2010, 09:18 AM
krazy2 is offline
Find More Posts by krazy2
Joined Jun 2008
Question
OS FS 70 Surpass compression loss?
Hi, I have an os 70 surpass which seems to of lost compression.
It was always easy to hand start, just prime/choke, and a reverse flick and it would fire up, but sadly not any longer.
It seems to have little compression and will no longer fire by hand, it will fire using a starter and run at about 9.5k on a 13x7 prop (maybe 10k but a few clicks of peak is about 9.5k). It usually idles ok maybe a bit higher than normal but sometimes the revs will just splutter/drop a bit and it stops.
I could feel a bit pressure on the inlet side during the compression stroke so assumed the inlet valve is leaking a bit.
I removed the head to inspect, the inlet valve looked clean, cleaned up both valves, the exhaust had a bit of carbon on it but not to bad and put it all back together, couldn't tell much difference in compression still feel pressure in the inlet, thou fuel draw is better so think the exhaust valve is sealing better.
Still runs the same thou and wont fire by hand.
Bottom end looks perfect.
Reading the forums i'm reluctant to try lapping the valve, and I think its to old to find a new head.
Do you think it would be worth trying a new valve or is it more likely the seat will wear first?
Valve clearances were fine both before and after cleanup.
Thanks.
krazy2 is offline Find More Posts by krazy2
Old Oct 21, 2010, 10:15 AM
gwinhh is offline
Find More Posts by gwinhh
Beaumont tx
Put some soapy water around the head and see if it's leaking there. Do the same with the plug (and use a new gasket and plug). Are you sure the valve springs are good? Have you turned it over with the head cover off to see if it's leaking around the valves?
You did try a new plug, new fuel, etc. I'm sure.
Any strange noises that would indicate bad bearings? Did you fly in a dusty area?
You can always try to find a new head, either dealer or in the for sale forums.
howell
gwinhh is offline Find More Posts by gwinhh
Old Oct 21, 2010, 12:22 PM
krazy2 is offline
Joined Jun 2008
You get pressure coming out of the carb on the compression stroke, there is no leaks anywhere else.
Valve springs are good.
No strange noises, no dusty areas, any yes plug, fuel etc was tried first.
Old Oct 21, 2010, 12:31 PM
Broken Wings is online now
Find More Posts by Broken Wings
Broken Wings's Avatar
United States, FL, Cocoa
Joined Jan 2006
You could run a little more oil in your fuel and get better ring seal. I use 18-20% oil.
Broken Wings is online now Find More Posts by Broken Wings
Old Oct 21, 2010, 09:35 PM
jeffie8696 is offline
Find More Posts by jeffie8696
TEAM BOCA
jeffie8696's Avatar
United States, IA, Muscatine
Joined Oct 2009
If you turn the engine over to where the compression should start then pour some fuel or whatever in the intake/exhaust port then pull it through the rest of the compression stroke if it bubbles up you have leaky valves.
New springs may help as they do loose tension with use and it is most noticeable at the seat.
jeffie8696 is offline Find More Posts by jeffie8696
Sold OS FS Surpass 91. 115.00 shipped VampeD4 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 12, 2010 09:00 AM
Sold NIB OS Surpass FS-26 davew478 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 10, 2010 03:57 PM
Sold Match set of OS FS 70 Surpass II ***FREE SHIPPING*** stevster Aircraft - Fuel - Engines and Accessories (FS/W) 1 Oct 04, 2010 11:22 PM
For Sale OS FS 70 Surpass, Brand New, never used. flyfishing2782 Aircraft - Fuel - Engines and Accessories (FS/W) 7 Sep 22, 2010 08:45 PM
Sold 1 OS 70 fs 1 saito 65 FS riverlarry Aircraft - Fuel - Engines and Accessories (FS/W) 4 Sep 08, 2010 07:43 PM
