Old Oct 21, 2010, 12:42 AM
ChuckTseeker is offline
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
E-flite Habu 32 DF ARF
http://www.modelflight.com.au/produc...F-7612-10.html
Overview
E-flite takes ARF ducted fan performance and engineering to new heights
with the Habu 32 DF. Designed around the E-flite Delta-V® 32 80mm fan
unit and 2150Kv DF32 brushless motor, its hyper-efficient intake and exhaust
ducting allows this potent combo to produce large amounts of thrust when
powered with a high-C 6S Li-Po pack. And it does so without resorting to
drag-inducing cheater holes. The result is a sport EDF with exhilarating speed
that will give even experienced jet jockeys goose bumps.
As the first Platinum Series E-flite® ducted fan, the Habu 32 DF also boasts
a level of fit and finish that is every bit as impressive as its performance.
Its sleek fiberglass fuselage comes pre-painted and integrates the vertical
stabilizer. The fully-sheeted wings and horizontal stabilizers are reinforced
with carbon blade spars and covered with genuine UltraCote®. The control
surfaces are hinged for you. Just add the optional E-flite electric retracts (sold
separately), and you’ve got a sport jet that truly stands out from the crowd.
Features
Designed for a direct bolt-in fit for the E-flite Delta-V 32 power system
Wings and Stabilizers are removable using carbon blade spars and aluminum sockets for easy transport
Painted fiberglass fuselage and a vertical fin with high quality UltraCote covered wings and stabilizer
Designed to fit the E-flite 15-25 sized electric retracts
Fully sheeted wings and stabilizers
Flap Ready
Access hatch for the fan unit and a canopy hatch for easy battery access
Plastic cockpit deck
Specs list for EFL8075
Wingspan 40.5 in (1030mm)
Overall Length 49.5 in (1250mm)
Wing Area 392 sq in (25.3 sq dm)
Flying Weight 7.05 - 7.40 lb (3.20 - 3.35 kg)
Motor Size DF 32 Brushless Motor, 2150Kv
Radio 5+ Channel Radio system
Servos Micro Servos (8 required)
Trim Scheme Colors Ultracote - Deep Red, Silver, Pearl Charcoal
CG (center of gravity) 100-115mm back from the leading edge at wing root
Speed Control 80 Amp brushless
Recommended Battery 6S 22.2V 5000mAh 30C LiPo, 10AWG, EC5
Flaps Yes
Retracts Optional
Control Throw (Ailerons) Low: 7mm Up/Down, 10% Expo; High: 8mm Up/Down, 15% Expo
Control Throw (Elevator) Low: 8mm Up/Down, 10% Expo; High: 10mm Up/Down, 5% Expo
Control Throw (Rudder) Low: 15mm Left/Right, 5% Expo; High: 20mm Left/Right, 12% Expo
Control Throw (Flaps) 11mm take off and cross wind landing; 25mm landing
Approx. Flying Duration 4.5 minutes
Scale Sport Jet
Minimum Age Recommendation 14 years
Experience Level Advanced
Recommended Environment Outdoor
Assembly Time 10-15 Hours
Is Assembly Required Yes
nice looking upgrade here
cheers chuck
ChuckTseeker is offline Find More Posts by ChuckTseeker
Old Oct 21, 2010, 10:17 AM
kimhey is offline
Find More Posts by kimhey
kimhey's Avatar
nøtterøy, NORWAY
Joined Mar 2006
will it be easy to modify it to take a 90mm fan?
kimhey is offline Find More Posts by kimhey
Old Oct 22, 2010, 03:00 AM
like2fly! is offline
Find More Posts by like2fly!
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
Just seen this bird on heliplane
http://www.rcgroups.com/forums/showt...hlight=habu+32
There must be 10 of the smaller Habu's at my club, sometimes up to 5 in the air at once!
Sweet fly plug and play model it is, i guess the new one will be sweet also, parkzone/e-flite don't seem to get much wrong. I've been flying futaba since the beginning but got a spectrum radio also this year to take advantage of their sweet range of bnf models, mainly the micro helis and planes.
Alex
like2fly! is offline Find More Posts by like2fly!
Old Oct 22, 2010, 03:06 AM
neversommer is offline
Find More Posts by neversommer
neversommer's Avatar
Luzern/Switzerland
Joined Aug 2008
I loved my Foamie Habu!
This one looks even better and better!
I am sold to the razor sharp design and retracts and this black/Red design!
AMAZING COLORS! I love this red/black mix.
However what I am surprised is that a 80mm Fan needs a 5000mah 6s battery to fly for 4.5 minutes, when an ARC 3675/Wemotec 90mm Combo needs already 5000mah for 4.5 minutes flight time.
I did not like the high pitched sound of the foamie habu edf unit at all....After time it really got on my nerves and I just sold the plane.
However I will be using my own 80mm Power System...Sad they did not use the more commonly used 90mm for this size of the aircraft, would have been a lot easier to exchange the power unit.
Now I am looking into a powerful 80mm EDF Unit Set.
Regards
Neversommer.
neversommer is offline Find More Posts by neversommer
Old Oct 22, 2010, 03:48 AM
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
by the way, you posted this in foamies, but its fiberglass!
Old Oct 22, 2010, 03:52 AM
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
Regards
Neversommer.
well here's an 85mm fan to get you started
http://www.schuebeler-jets.com/index...=30&Itemid=115
I guess they'll bring out a parkzone foamy 80mm edf for this power system
http://www.horizonhobby.com/Products...ProdID=EFLDF32
http://www.horizonhobby.com/Products...ID=EFLM3032DFA
http://www.e-fliterc.com/Products/De...ProdId=EFL8075
Old Oct 22, 2010, 08:21 AM
Joined Dec 2007
Whoops
if you want to start another thread in the right section i'll lock this one, i just wanted to let the jet guys see this, as i thought it looked a beauty
cheers chuck
Old Oct 22, 2010, 09:07 AM
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
Here's the old thread:
http://www.rcgroups.com/forums/showthread.php?t=1308466
And here's a fan for more go:
http://www.espritmodel.com/index.asp...D&ProdID=13635
Alex
Old Oct 23, 2010, 09:25 PM
Joined Dec 2007
i'm closing this thread as it's in the wrong section and one was already going
cheers chuck
Article E-Flite's Super Airliner DF ARF Review pda4you Foamy EDFs 38 May 27, 2015 05:24 PM
Sold E-flite F-16 ARF 400 DF Jet (New In Box) Price bumped!!! wbrannies Aircraft - Electric - Jets (FS/W) 9 Sep 28, 2010 09:45 PM
Sold E-flite F-16 ARF 400 DF Jet (New In Box) Price bumped!!! wbrannies Aircraft - Electric - Airplanes (FS/W) 2 Sep 15, 2010 09:54 PM
Discussion E-Flite Habu II? southernmd_man Foamy EDFs 5 Sep 14, 2010 04:27 PM
