Old Feb 06, 2013, 04:12 PM
Edge767 is offline
Find More Posts by Edge767
AMA 52726
Edge767's Avatar
United States, TX, Spring
Joined Jun 2005
Originally Posted by PittSpecial View Post
Got this new model about two weeks ago and had to pick it up at Palmetto, Florida which was approximately 160 miles away. I bought it here in the classifieds knowing well that I was going to use this trip to visit my oldest daughter that lives in Tampa, Florida while on the way to pick the model so, it worked in all accounts.
Missing was the Motor, however, the ESC, all servos and Flaps were configured with flap servos pre-installed.
Early this morning, I finally got around to finish the model by installing a brand new Park Zone 15 Brushless motor (950Kv) and I thought to myself, why not make it look as scale as possible so, I found a bag with at least (Quantity 6) Grand Wing Servo (GWS) 4-Blade (10 X 8 X 4) Plastic "Electric" Propellers. I had to hone them to the propeller adapter that I used (Great Planes Propeller Adapter that comes with the GD600 gearbox). Honing out the inner Propeller Hub took patience since you can easily over-heat the Propeller Hub and deform it, if you do not STOP and allow the hub to cool while drilling.
Using a spare Spektrum AR500, and my Spektrum DX7 the model was activated for the first time at the wee hours of early morning around 3:00am Eastern. I was pleasantly surprised on the smooth Propeller power run up using the Black molded 4-Blade GWS Propeller. No vibrations or wobble.
I used Minwax Water Based Polycrylic to protect the paint and decals and it worked like a charm. The maiden was super scale and that GWS 4-Blade provided lots of punch in the thrust department and air speed was pretty impressive as well.
Best of all the landing was spectacular with full flaps (Flaps on Gear switch). Model touched down super slow and like watching the full size! That 4-Blade really helps provide thrust during landing.
Welcome to this thread, Carlos! The P-47D is one of the most perfect RC planes I've ever owned and flown. The E-Flite retracts for this one are bulletproof. I've got hundreds of flights/landings on mine with nary a glitch, and others here can testify to their strength and robustness.
I look forward to your videos, photos, etc. I literally just read through all your blog entries today; cool stuff!
Edge767 is offline Find More Posts by Edge767
Old Feb 06, 2013, 04:17 PM
stoopidmonkey is offline
Find More Posts by stoopidmonkey
Flight Risk AMA # 986105
stoopidmonkey's Avatar
United States, CA, Escondido
Joined Oct 2011
on board footage of the crash
Ouchy I had a funny vibration as well as we can see through the video. Oh well Corsair and Mustang here I come.
Parkzone P-47D CRASH!!!! (2 min 55 sec)
stoopidmonkey is offline Find More Posts by stoopidmonkey
Old Feb 06, 2013, 04:18 PM
dav3uk is offline
Find More Posts by dav3uk
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
A few pictures of my early morning setup work and at the field.
Hey Carlos welcome to the Jug club, long time no hear.....she is a keeper for sure. I rate her above the Spit as the best PZ plane yet.
Look out in July as I am coming over your way and bringing the Spit with me....
Fly safe and have fun
Dave
dav3uk is offline Find More Posts by dav3uk
Old Feb 06, 2013, 04:55 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Be careful that setup can pull 40amps and the stock ESC is rated for 30 and the motor 34.
It does look nice though!
-Brian
kalmon is offline Find More Posts by kalmon
Old Feb 06, 2013, 05:03 PM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
A new airframe is only $100 if you give up on that one.
Don't pull on sticks at all if you don't know where the plane is or its orientation (wait until it comes out of the sun before doing anything).
The vibration is definitely coming from the motor on the video, as it goes away when you pull off the throttle. My guess is mount bolts, prop balance, or bearing.
jtaylor996 is offline Find More Posts by jtaylor996
Old Feb 06, 2013, 05:04 PM
Registered Crasher
Joined Feb 2011
-Brian
Where did you find a specification on the BL15 motor?
Old Feb 06, 2013, 06:42 PM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Well I ordered my new graphics from Callie, got the new G25, and will be reaming out the 4 blader for use. Now I just need to sand her down smooth and get her ready for paint. I have all the dings patched just need to get all smoothed out and ready to go.
IndyMatt is offline Find More Posts by IndyMatt
Old Feb 06, 2013, 08:41 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
I used the Power15 specs. They (BL15 and power15) are both 15 sized 950kv motors. I'm sure there are small differences however for a load calculation this is definitely close enough.
http://www.e-fliterc.com/Products/De...odID=EFLM4015A
Type: Brushless outrunner motor
Bearings or Bushings: One 5 x 14 x 5mm Bearing, and One 5 x 11 x 5mm Bearings
Wire Gauge: 16
Recommended Prop Range: 10x613x6.5
Voltage: 7.414.4V
RPM/Volt (Kv): 950
Resistance (Ri): .03 ohms
Idle Current (Io): 2.00A @10V
Continuous Current: 34A
Maximum Burst Current: 42A (15 sec)
Cells: 812 Ni-MH/Ni-Cd or 3-4S Li-Po
Speed Control: 4045A brushless
Weight: 152 g (5.4 oz)
Overall Diameter: 35mm (1.40 in)
Shaft Diameter: 5mm (.20 in)
Overall Length: 50mm (1.90 in)
-Brian
Old Feb 06, 2013, 08:47 PM
GhostStone is offline
Find More Posts by GhostStone
Soli Deo Gloria
GhostStone's Avatar
United States, IN, Fort Wayne
Joined Jan 2012
Make sure to share some pictures with us. Can't wait to see your finished Jug!
GhostStone is offline Find More Posts by GhostStone
Old Feb 06, 2013, 09:09 PM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Thanks!
Here are a few more at the RC Club! Just look at the wind Sock, Dead Calm!!!
PittSpecial is offline Find More Posts by PittSpecial
Old Feb 06, 2013, 09:15 PM
Justwingit is offline
Find More Posts by Justwingit
We got some flyin' to do!
Justwingit's Avatar
United States, TX, Fort Bliss
Joined Apr 2012
Looks like a perfect day for a maiden....I'll bet it flew like it was on rails
Justwingit is offline Find More Posts by Justwingit
Old Feb 06, 2013, 09:48 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
John,
It did more than that! Did not need any trim adjustment what-so-ever and it went exactly where I commanded it to go! Those Flaps are just wonderful and the model slows down very well without any extreme pitch affects such that I did not need to provide any Elevator adjustment after deployment of the flaps! The landing with those flaps made me look like a Pro RC Flyer as it touched on its mains so slow that it did not have a chance to tip over on the propeller!
A few pictures showing the AMP, WATTS and VOLTAGE under load measurements from tonight.
Estimated:
Actual Results = VIDEO:
Park Zone P-47 Thunderbolt using GWS 4-Blade 10 X 8 X 4 Propeller with Stock power system 02-06-2013 (1 min 59 sec)
Old Feb 06, 2013, 09:55 PM
BlinkguY is offline
Find More Posts by BlinkguY
BlinkguY's Avatar
United States, NJ, Newark
Joined Nov 2005
are you using stock motor?
BlinkguY is offline Find More Posts by BlinkguY
Justwingit's Avatar
Joined Apr 2012
Did I hear you right, when you said it was pulling 36 amps at full throttle? Shouldn't be that bad as it'll unload in the air, right ?
That model's just screamin' for some weathering details and so forth...very nice
Old Feb 06, 2013, 09:56 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Measured Read-Outs!
In case you missed what I yelled in that Video
1/2 Throttle: 9-Amps / 11.87 Volts / 108 Watts
3/4 Throttle: 23.5 Amps / 11.16 Volts / 255 Watts
FULL: 36 Amps / 10.5 Volts / 376 Watts
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 09:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
