Old Jan 22, 2013, 04:39 PM
walter3rd is online now
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
im going to get a watt meter so i hope to be able to know whats going on there. how many amps can you put through the stock motor without harm? i rarely fly WOT so i was hoping it might work. thoughts?
walter3rd is online now Find More Posts by walter3rd
Old Jan 22, 2013, 06:37 PM
nageotte is offline
Find More Posts by nageotte
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
I did check the amps. It was fine, but I don't remember what it was and Since the plane is hanging in winter storage, I am not gonna check it again right now.
nageotte is offline Find More Posts by nageotte
Old Jan 22, 2013, 06:46 PM
bladeguy5 is offline
Find More Posts by bladeguy5
bladeguy5's Avatar
United States, MD, Waldorf
Joined Jun 2012
Has anyone mounted a go pro on the jug?
bladeguy5 is offline Find More Posts by bladeguy5
Old Jan 22, 2013, 07:05 PM
walter3rd's Avatar
Joined Aug 2012
i guess i was mistaken about the way the electronics function in these set ups. i was thinking that the esc was the limiting factor in allowing the motor to use a big prop. not that the esc was going to give it to much juice and kill the motor. still trying to figure this stuff out as i am quite new... thanks for educating me on this. would it be better to go smaller esc or bigger motor to turn a 4 blade? i am not looking for full time WOT just want to cruise around no more than 3/4 max with a 4 blade. thanks, walt. cool shirt i found too!.
Old Jan 22, 2013, 07:22 PM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
Nobody knows the limit on the BL15 motor, as parkzone doesn't provide any relevant specs. But experience here has shown that its probably less than 40A.
Experience also shows that once you get this plane in the air, you'll be using a lot more WOT than you thought you would
Personally, I think you need to get you draw below 40A at WOT for this motor. I would go over to eCalc.ch and plug in numbers for the jug. Use the pre-defined e-flite power 15 motor (they don't have the bl15 since no specs are available). Then start playing with propeller sizes and pitches to get your amps down, while keeping the pitch speed up and thrust to weight above 1.
If you're not attached to this motor, then buy the 710kv turnigy g25 motor and go for the hobby lobby 11" 4 blade prop. I think that's what people are using for that prop on this plane. Check the search function on this thread, and run those numbers through eCalc as well.
And do buy that watt meter.
jtaylor996 is offline Find More Posts by jtaylor996
Old Jan 22, 2013, 07:28 PM
Registered Crasher
Joined Feb 2011
Well, I think you want the amps down. If they stay high even if you have equipment that can handle it, you'll end up with short flight times.
The easiest way to do that is by selecting a smaller dia prop, or less pitch. Using a lower Kv motor will also do this, but at reduced performance with the same prop. Basically, just start trying things in eCalc.
Or, you can go the easy route and just use the stock setup with the E300 prop. Leaving your upgraded ESC in there won't hurt anything.
Old Jan 22, 2013, 08:56 PM
BlinkguY is online now
Find More Posts by BlinkguY
BlinkguY's Avatar
United States, NJ, Newark
Joined Nov 2005
I think even 40amps is too much to keep up with this motor... maybe around 35 with propper cooling
BlinkguY is online now Find More Posts by BlinkguY
Old Jan 22, 2013, 09:01 PM
nageotte is offline
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
The ESC will not force any current on the motor or from the battery. Both the battery and the ESC simply make the power available. The motor draws what ever current it needs. With a bigger prop or more pitch the motor must work harder(more current) But there is a limit to how much work it can do. If you exceed that limit on the motor, or ask for more current than the ESC or battery can provide, one of the three will fail. You need a motor that can do enough work, and an ESC and battery that will give the motor as much current as it wants. It is a matched system. Even a mismatch such as a much larger ESC than you need will eat into your efficiency and draw down the battery.
Old Jan 22, 2013, 09:49 PM
walter3rd's Avatar
Joined Aug 2012
thanks for this education. i apreciate all the guidence. i m going to run the stock setup for a bit with extra 300 prop that is on there now, but i know i want to go hobby lobby 4 blade at some point and thought the bigger esc was a must. i now see a bigger motor will be required as well. i am going to stay with 3 cell batts so that wont change. i will go to ecalc and try to figure it out there as well. watt meter is backordered! pain!
Old Jan 23, 2013, 06:49 AM
nageotte is offline
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
Walter, FYI the four blade comes set at a pitch of 10 and despite the advertising, the minimum Was about 6 or 7 with their pitch guage.
Old Jan 23, 2013, 07:20 AM
jdm2ner is offline
Find More Posts by jdm2ner
flying is everything
jdm2ner's Avatar
United States, FL, Hollywood
Joined Oct 2010
@ walter I run a Hobby-lobby 9.5x10x4 with a turnigy g25 710 kv an ice lite 75amp esc a castle 10amp bec on a 4s set up and i love it. its fast when i want it and i fly between 1/2 to 3/4 and at half im as fast as a stock set up at wot i have over 30 flights with this power set up and it runs great.
jdm2ner is offline Find More Posts by jdm2ner
Old Jan 23, 2013, 09:02 AM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Did you put that on a Wattmeter and see what you are pulling?
IndyMatt is offline Find More Posts by IndyMatt
Old Jan 23, 2013, 01:10 PM
Wild Deuce is offline
Find More Posts by Wild Deuce
Wild Deuce's Avatar
United States, WI, Appleton
Joined Nov 2012
Hi everybody! Another P-47 guy here trying to put a 4 blade prop on. I have a Durafly 10.5X7.5X4 blade that wont go past the threads on the stock adapter from PZ. Where can I find the compression type adapter that is just 5mm long period? I dont want to drill the prop....I wonder if the HL 5mm adapter would work? Thanks for any help you can give...
Paul
Wild Deuce is offline Find More Posts by Wild Deuce
Old Jan 23, 2013, 04:18 PM
copperbricks is offline
Find More Posts by copperbricks
You can't take the sky from me
copperbricks's Avatar
United States, OH, Cincinnati
Joined Aug 2011
you can get a prop reamer at any hobby shop. The size for PZ props is 8mm.
copperbricks is offline Find More Posts by copperbricks
Old Jan 23, 2013, 04:48 PM
Wild Deuce's Avatar
Joined Nov 2012
That's a great idea...ok 8mm on the smooth part behind the threads....thanks! When you ream a prop I'm guessing I need to rebalance...
Paul
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 09:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
