Old Jan 21, 2013, 09:21 PM
SG Mason Knives is offline
Find More Posts by SG Mason Knives
Canada, ON, Iroquois
Joined Mar 2012
I think my Sony Alpha 35 is just a little bigger than the handicam Its a great camera in the hand or on a tripod, but trying to hat mount it is challenging due the the mass of the lens sticking out the front. I have tried to mount it to every piece of head wear I have and the only thing that didn't out right fall from my head was my full face bike helmet. Even it would shift enough to interfere with my line of sight.
Maybe if I just made the PVC pipe camera rig and had him take an HD video the next time I could just pull a frame or two out for stills I don't find they have as good as quality as a still shot though
SG Mason Knives is offline Find More Posts by SG Mason Knives
Old Jan 21, 2013, 10:39 PM
ryramZ is online now
Find More Posts by ryramZ
Your Pilot Ryan
ryramZ's Avatar
United States, IN, South Bend
Joined Nov 2008
Originally Posted by bakon View Post
Has anyone used Gorilla glue on this plane?
Yes, works fine.
ryramZ is online now Find More Posts by ryramZ
Old Jan 22, 2013, 06:57 AM
walter3rd is offline
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
still waiting on hobby lobby to get some more 4 blades in for my jug. so in the mean time i ordered a apc 4 blader. i believe 10 inch span. i also ordered a 54 amp esc and i have a seperate bec i can use. im going with stock motor and 3 cell batts. waiting on a watt meter as well to come in. i hope this system will work as i patiently wait for hobby lobby to get more in stock. cant stand the look of the 2 blader. with this weather im just looking at my plane hanging in my office. i think i will fly her with extra 300 prop to start but really want a 4 on there eventually. any one use the apc 4 bladers? thanks, walt.
walter3rd is offline Find More Posts by walter3rd
Old Jan 22, 2013, 07:11 AM
nageotte is offline
Find More Posts by nageotte
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
I am with you Walter. I know that when it is flying you can't see it, but you sure can when it is hanging in the hanger! I want scale props! I don't care that it will fly slower or need a new ESC. I want scale props!
nageotte is offline Find More Posts by nageotte
Old Jan 22, 2013, 07:38 AM
Reco is offline
Find More Posts by Reco
RC Fanatic
Reco's Avatar
USA, NC, Greensboro
Joined Mar 2002
Always liked the JUG.
Reco is offline Find More Posts by Reco
Old Jan 22, 2013, 10:32 AM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
Walter, it's going to take more than an upgraded ESC to handle that much power. The problem is that even the much better made power 25 motors can only handle 44A of power. The little BL15 handles much less. If you keep running it at 54A it'll be toast in a short amount of time.
What pitch is the APC prop? I use an 11x9x4 APC prop that I cut down to 10" diameter. This only pulls 38A using the power 25 (870kv) motor.
jtaylor996 is offline Find More Posts by jtaylor996
Old Jan 22, 2013, 12:38 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
I originally wanted to get a 4 blade prop. Then I flew it on the extra300 prop. I no longer want to fly on a 4blade. I mean I still might get one and just throw it on there for static display. However the increased performance just by changing the prop and keeping everything else stock is impressive.
-Brian
kalmon is offline Find More Posts by kalmon
Old Jan 22, 2013, 01:48 PM
Edge767 is offline
Find More Posts by Edge767
AMA 52726
Edge767's Avatar
United States, TX, Spring
Joined Jun 2005
I store my planes in my bedroom nose-in against the wall, so I don't see the plane sitting around. When I do see it, it's only while on the bench at the flying club field. I prefer to see my plane up in the air, and it performs great with the two-blade so I honestly don't mind the two-blade prop. Like kalmon said, the Extra 300 prop is awesome on this plane and since I can't see the prop while it's flying, it doesn't bother me.
I know, to each his/her own, etc. More power to those of you who need a four-bladed prop on your Jugs. I won't be joining you (although I own four or five four-blade props that would work on these planes; I just won't use them). I prefer the two-bladed props on my models; they break less on the grass fields I fly from (due to the momentary nose-overs from time to time).
Edge767 is offline Find More Posts by Edge767
Old Jan 22, 2013, 02:11 PM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
Amen. why spend money on props. I am sometimes shocked how tough the two blades are. The four blades seem to break just looking at them.
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Jan 22, 2013, 03:41 PM
walter3rd's Avatar
Joined Aug 2012
jtaylor, what do you mean - that much power? im keeping everything stock just changing to a bigger esc for safety. can you explain?
Old Jan 22, 2013, 03:44 PM
Registered Crasher
Joined Feb 2011
By power in that instance I mean the amps. Putting 50A into that motor will get it too hot and it will throw a magnet. Both the ESC and motor need to be changed if you want to run a big 4 blade prop like the hobby lobby.
Old Jan 22, 2013, 03:48 PM
critter1340 is offline
Find More Posts by critter1340
2948 scale Combat
critter1340's Avatar
Maryland
Joined Aug 2004
Yes that is true. I had one go down in smoke with that 4 blade Prop and 4 cell Bat.
The magnet came lose and locked up the motor in flight. I did save the plane and she still flys but with a new motor and speed control.
critter1340 is offline Find More Posts by critter1340
Old Jan 22, 2013, 03:57 PM
2948 scale Combat
Maryland
Joined Aug 2004
http://www.rcgroups.com/forums/showt...2#post17269056
I got the P-47 Jan 2011 and she is still going
Old Jan 22, 2013, 04:08 PM
nageotte is offline
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
Walter, I adjusted the Hobby Lobby four blade to minimum pitch and it is fine with the stock motor and 3S. I use the 11" one, too. Not the shorter one. Looks better And. . .it has lots of power and speed. It is not a jet, but it is flying much faster than scale speed.
Old Jan 22, 2013, 04:22 PM
Buster1000 is online now
Find More Posts by Buster1000
United States, NY, Schenectady
Joined Sep 2009
Have you checked the amps for this set-up? Luckily, the P-47 is easy to dead stick and motors are cheap.
Buster1000 is online now Find More Posts by Buster1000
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 09:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
