Old Jan 17, 2013, 09:54 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Originally Posted by Buster1000 View Post
Any amp draw data with the the stock motor and 4s lipos. My PZ 15 w/stock prop=28amps/325 watts. 10.5x9 e-flite=34amps/400 watts. This is static burst current/power.
The math doesn't work.... 28amps and 325watts??? That's 3 cells 11.6 volts, not 4s like you mentioned.
-Brian
kalmon is offline Find More Posts by kalmon
Old Jan 18, 2013, 03:37 AM
Buster1000 is offline
Find More Posts by Buster1000
United States, NY, Schenectady
Joined Sep 2009
-Brian
I apologize for not making this more clear...this is data with a 3 cell lipo. However, I am curious about the use of a 4 cell lipo and which props would be appropriate.
Buster1000 is offline Find More Posts by Buster1000
Old Jan 18, 2013, 10:52 AM
320pilot is offline
Find More Posts by 320pilot
320pilot's Avatar
Joined Mar 2009
Brownie 433 had a question ..Here is my setup for the Thunder Power LiPo. Note the wooden block at the end of the LiPo. When I insert this LiPo, (wooden spacer first) the P-47 is perfectly balanced..
I fly my P-47 without the landing gear. Hand launch, recover in long grass.
320pilot is offline Find More Posts by 320pilot
Old Jan 18, 2013, 02:30 PM
Christofer H is offline
Find More Posts by Christofer H
Joined Jul 2012
Winter - all mods done - cannot fly .
Now I have upgraded the P47 to have a 65 A ESC and also a separate SBEC
from Dimension Engineering delivering 3,5 A to the receiver what ever happens to the ESC /Motor...
Tried the setup on a 4 cell battery and yikes what a pull there is in it.
The 3 cell full throttle is the same as 4 cell throttle.
If the motor will survive it - who knows. Now I can at least bring the bird down in a safe manner even if the motor have gone...
Now - if the weather would be so king to let me try out all the goodies ..
But no - it is currently -15 C outside and 40 cm of snow.
Be glad the ones of you who live in a fly year around climate and stop complaining.
I guess I will take my Fun Cub with Skis on for a spin tomorrow
Only would like to have more skis to fir all the planes with them.
Good flying out there - Chris from Sweden.
Christofer H is offline Find More Posts by Christofer H
Old Jan 18, 2013, 03:05 PM
Joined Sep 2009
Chris, I feel your pain as I too, am suffering from lack of flying withdrawls. What prop are you using a 4 cell with and do you know the current pulled?
Old Jan 18, 2013, 08:51 PM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Time has come, flew her today and a wisp of branch caught the right wingtip swinging her around into some trees. She was about 40 feet up with no way to climb, smoked it several times with some rocks and got her down. The time has come to fill and remake her up, I have stripped all of the decals off the plane and will sand and fill her and then repaint. I already had a brand new wing. Need a new hatch and they are backordered! Going to fill, sand, and then paint the old to use for in flight videos.
Already have my mind set on making her Chief Ski U Mah
IndyMatt is offline Find More Posts by IndyMatt
Old Jan 18, 2013, 11:06 PM
walter3rd is online now
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
weathering has started!
i started on the weathering tonight. pastel dust in panel recesses, additional panel lines started and many many rivets!the top is close to done the bottom next. still waiting on the maiden...
walter3rd is online now Find More Posts by walter3rd
Old Jan 19, 2013, 07:34 AM
ForsheeMS is offline
Find More Posts by ForsheeMS
ForsheeMS's Avatar
United States, NC, Lexington
Joined Jul 2012
Walter, you are very talented (and patient)! I've followed along with your UM and full size T-28 and now the Jug. I love the detail you put into all your planes. Keep up the good work!
ForsheeMS is offline Find More Posts by ForsheeMS
Old Jan 19, 2013, 08:20 AM
walter3rd's Avatar
Joined Aug 2012
thanks! i love the details on these planes. all the little touches help to hide the fact its a foamy. on the ground she looks much more like aluminum now. with some good music playing i actually think its quite relaxing.
Old Jan 19, 2013, 09:21 AM
dbdukeboy is offline
Find More Posts by dbdukeboy
Newbe learning everyday!
dbdukeboy's Avatar
United States, OH, Parma Heights
Joined Aug 2012
Hey Walter , did you fill the panel lines in with something and did you use a sharply for the rivets?
dbdukeboy is offline Find More Posts by dbdukeboy
Old Jan 19, 2013, 10:19 AM
IndyMatt is offline
Indianapolis, IN
Joined Oct 2010
Yes, please share on the rivets! That looks fantastic!
Old Jan 19, 2013, 02:25 PM
walter3rd's Avatar
Joined Aug 2012
stock panel lines filled with pastel dust and a small paint brush. panel lines drawn and rivets with extra fine tip sharpie. small flexable metal ruler for straight edges. round 2 tonight for the bottom. i only had a larger size silver pen when i started the cockpit rivets. there too big. so im going to paint over those big silver rivets with flat black and get another fine tip silver sharpie.
Old Jan 19, 2013, 09:35 PM
walter3rd's Avatar
Joined Aug 2012
black cockpit painted to silver.
switched over the frame color from the stock black to silver. looks better and pops more. added antenna behind cockpit as well. looks nice.
Old Jan 20, 2013, 11:48 AM
Brownie433 is online now
Find More Posts by Brownie433
United States, WI, Milwaukee
Joined Sep 2008
Cool.
I was thinking about a foam block to help with CG.
Good tip.
It's 12 degrees out
I need mother nature give us a break - maybe 30 degrees and lower winds for a day
The snow is gone (for now), so I'm itching to fly.
Brownie433 is online now Find More Posts by Brownie433
Old Jan 20, 2013, 05:13 PM
IndyMatt is offline
Indianapolis, IN
Joined Oct 2010
How do you sand the Z foam smooth, it got a little fuzzy on me redoing the fuse. I got the dings filled with spackle, maybe need to get some finer sandpaper.
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 09:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
