Old Jan 04, 2013, 10:24 AM
dav3uk is offline
Find More Posts by dav3uk
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Originally Posted by jtaylor996 View Post
No, you'll burn the motor up (eventually). That pulls 50+ amps. This is even correcting for the fact that the hobby lobby 11" is really 10.875".
You could try it, but the point of checking this stuff out to make sure you're not over the stated limits of your equipment.
You could try a motor rated for higher current, but you'll just end up at with no decent run times. You could pitch the prop back, but once you go away from 10" on the HL prop you have to break the locking tabs off, and just trust friction to hold the pitch into place (so: not good).
Like I said before, I use the APC 11x9x4 prop, cut down to 10". This works well for me and my 870kv motor.
Only at the stock 10 inch pitch. you can bring the pitch back and get it below 40a and that works just fine, thats how I did it. Its variable prop so use it to your advantage and dial in as much as you need.
Just dont be tempted to pop the prop on stock and spin it up as it will draw 50 ish amps and the motor wont take that for long.
Dave
dav3uk is offline Find More Posts by dav3uk
Old Jan 04, 2013, 11:55 AM
Redhood is online now
Find More Posts by Redhood
Redhood's Avatar
United States, MN, Odin
Joined Aug 2010
P-47n
My latest mod. I added spacers to the wing near the fuselage and clipped the wing tips. Thanks to Callie Graphics for the decals. I test flew the wing on another fuselage before I finished it and it flew great. A few paint apps yet and she'll be ready.
Redhood is online now Find More Posts by Redhood
Old Jan 04, 2013, 12:44 PM
dbdukeboy is offline
Find More Posts by dbdukeboy
Newbe learning everyday!
dbdukeboy's Avatar
United States, OH, Parma Heights
Joined Aug 2012
What do you mean by clipped the wings and what does that accomplish. I have a long winter ahead of me and want to do some mods on mine.
dbdukeboy is offline Find More Posts by dbdukeboy
Old Jan 04, 2013, 01:00 PM
Redhood's Avatar
Joined Aug 2010
The wing tips on the P-47 N were squared off slightly. Republic put a spacer near the fuselage to add fuel tanks to extend it's range. It was developed to escort B-29s in the Pacific. For the model it rolls a bit faster but otherwise it flies the same.
Old Jan 04, 2013, 01:19 PM
bayoubengal is offline
Find More Posts by bayoubengal
United States, LA, Baton Rouge
Joined Nov 2009
Originally Posted by WarbirdFan66 View Post
i have to agree with *dav3uk*, she flys very nice and the belly landings work fine...put the protectors on the belly and your good to go. I have flown mine for quite some time as a belly lander, and if the grass i short enough even a 4-balded prop is not problem, never had any problems with the cowl or the prop for that matter.
(if you like check out my video....jump to 2:25 for the landing)
http://www.youtube.com/watch?v=PqjAsf6Msoc
And im also a big fan of the flaps, you dont need them but they make landings slower and easier, the extra weight is negligible and totaly worth it if you ask me
Thank you for the advice and the video.
bayoubengal is offline Find More Posts by bayoubengal
Old Jan 04, 2013, 04:05 PM
pr0ject42 is offline
Find More Posts by pr0ject42
CEL abuser
USA, CO, Denver
Joined Dec 2010
Is that a vario prop or a durafly prop with the hub painted? Nice looking plane!
pr0ject42 is offline Find More Posts by pr0ject42
Old Jan 04, 2013, 04:17 PM
dav3uk is offline
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Here is the belly of mine, its getting a bit worn but I just keep touching up with Sharpie.
I dont have the clear skid plates on as I chucked them out when I first got the plane thinking I would only land on the wheels..............sometimes they dont cut the grass for ages.......lol
It probably does 30% on the belly now.....
Old Jan 04, 2013, 05:47 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Note about the Gyro:
I still think that it is not needed on this plane but here you go, the best option would be this:
AR635 RX
A new spektrum AS3X full range RX designed for park sized aircraft.
-Brian
kalmon is offline Find More Posts by kalmon
Old Jan 04, 2013, 06:10 PM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
I saw that in the VisionAire thread. What really sucks about that is that it's an RX, and only works with spektrum stuff... no thanks!
jtaylor996 is offline Find More Posts by jtaylor996
Old Jan 04, 2013, 06:11 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Unless that's exactly what you are looking for, of course....
tracknoob is offline Find More Posts by tracknoob
Old Jan 04, 2013, 06:27 PM
BlinkguY is online now
Find More Posts by BlinkguY
BlinkguY's Avatar
United States, NJ, Newark
Joined Nov 2005
hahaha... lucky you!!! ill buy it with my eyes closed if its spektrum brother... you bet on it!
BlinkguY is online now Find More Posts by BlinkguY
Old Jan 04, 2013, 06:28 PM
BlinkguY's Avatar
Joined Nov 2005
that was funny
Old Jan 05, 2013, 12:27 AM
walter3rd is online now
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
does anyone have the MRrc sound system in this plane? wondering if it fits without a bunch of drama? does it affect flight times and is it heavy enough to cause the plane to fly noticably different? thanks. heres my baby now!
walter3rd is online now Find More Posts by walter3rd
Old Jan 05, 2013, 06:34 AM
jdm2ner is offline
Find More Posts by jdm2ner
flying is everything
jdm2ner's Avatar
United States, FL, Hollywood
Joined Oct 2010
for all those talking about a gyro for this plane check this out
http://spektrumrc.com/Products/Defau...rodID=SPMAR635
coming out in late jan
jdm2ner is offline Find More Posts by jdm2ner
Old Jan 05, 2013, 07:02 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
beat 'cha to it.
look six posts up
Nothing wrong with spektrum stuff. That said it works with JR as well.
Futaba FASST and DSMx are both multipath freqency agility communication. Thumbs will cause a crash 10,000 more times than any of either of their radios.
-Brian
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 11:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 10:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 10:08 AM
