Old Nov 18, 2012, 08:12 PM
ufale's Avatar
Joined Nov 2010
Originally Posted by 19000rpm View Post
I haven't heard of anyone using bigger than a 25. Me being one of those that went that way.
Far be it from me to discourage the use of more power, but... Why a 32 on 3S
for a plane of this size? Just curious. It's a monster motor for this P47 and better suited, IMHO, to 4S or 5S, on a larger plane.
I think the length (1.9") is close to the size of the stock 15. You shouldn't need to alter anything except, maybe, mounting holes on the cowl.
I am basing my expectations mostly on a conversation that I read on this board: http://www.rcgroups.com/forums/showp...ostcount=12966 Now that I look at it, I guess I will need to use at least 4s. I might do it if I can get the battery to fit. I never like to take foam out of the fuse.
ufale is offline Find More Posts by ufale
Old Nov 19, 2012, 06:02 AM
Joined Aug 2009
4S will fit with a minimum of foam removed. Nothing that is going to effect the integrity of the fuse.
19000rpm is offline Find More Posts by 19000rpm
Old Nov 19, 2012, 08:56 AM
ufale's Avatar
Joined Nov 2010
I am also not sure that my 50 amp ICE esc will be enough. I might have to put in my 75 amp.
Old Nov 19, 2012, 09:14 AM
USA, IL, Chicago
Joined Nov 2010
Thanks 19000rpm!!!
op1900 is offline Find More Posts by op1900
Old Nov 19, 2012, 03:30 PM
Joined Aug 2009
A lot will depend on the pitch of your prop. You may well need a 75A at a high pitch. That's a guess. Rule is that as Volts go up Amp needs go down for any given set up. Check it out with your meter.
Old Nov 20, 2012, 09:17 AM
BlinkguY's Avatar
United States, NJ, West New York
Joined Nov 2005
hey guys.. i think my wife will buy me this plane for xmas... whats the battery from hobbyking you guys use with no mods needed or no CG changes.... i have a trojan PKZ and i use the 20C 2200mah and no issues at all... just plug and fly... now the 25C seems to be heavier and bigger... so since i do not own the plane yet i just want to know whats the biggest C rate and MAH capacity from turnigy are you guys flying with with no need to scoop foam out of it or without modding the CG... thanks a lot in advance
BlinkguY is offline Find More Posts by BlinkguY
Old Nov 20, 2012, 09:33 AM
Flying addicted and lovin it!
Fish99's Avatar
Canada, AB, Edmonton
Joined Jun 2010
I fly the Zippy 25 c or higher 2200 mah 3 cells. NO ISSUES, drop right in. You will need to build or buy (from HK Cheap) the little XT60 to EC3 adaptor. It's better than trying to solder on new EC3 ends to all your lipos or changing all your ESC's to XT60's.
Marlin
Fish99 is offline Find More Posts by Fish99
Old Nov 20, 2012, 09:38 AM
WarbirdFan66's Avatar
Germany, Berlin
Joined Feb 2012
I finally got the Eflite Power32 for my P47. I am going to be using it with an ICE 50 esc, and 3s 2600 batteries. If the bench test works out, I want to use it with the Hobby Lobby 4 blade prop. Has anybody fit this motor to this plane? If so, what is the best way to mount it? I was thinking of just fixing the stock mount to the firewall. If I do this, I think I will have to modify the cowling.
I use the power25 in my jug, plus the 11" 4-blader which works nice, but even i got a few smal cracks in the motormount after a little while. If i were you i would not trust the standard mount to much with that kind of motor, you might better go for the aluminum mount instead.
WarbirdFan66 is offline Find More Posts by WarbirdFan66
Old Nov 20, 2012, 09:47 AM
BlinkguY's Avatar
Joined Nov 2005
Marlin
thanks a lot.. i already have the adapter.. what version of the zippy you use? compact or regular?
Old Nov 20, 2012, 09:48 AM
Germany, Berlin
Joined Feb 2012
3s vs. 4s
True it works nice on 4S, and its fast...for a while, but lets face it, foamies like the Parkzonebirds are not build for the speed nor the forces you can squeeze out of a 4S pack.
If its only for a short time, everything is fine, but if you wanna enjoy your plane for awhile i would still choose the 3s version.
This setup is powerfull enough for some nice scale flying if you ask me, just my opinion.
Old Nov 20, 2012, 10:04 AM
Fish99's Avatar
Joined Jun 2010
Regular, is almost exactly the same size, and slightly lighter weight, than the stock lipo.
Old Nov 20, 2012, 10:27 AM
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Agreed! The aluminum mount from customRC.com rocks! I clipped, and broke a 12" prop on the runway,doing a high speed fly by(only down fall with a two blade) After landing safely, I inspected the motor, and mount before replacing the prop, and everything held strong! The motor was also fine due to the flex of the firewall.
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Nov 20, 2012, 01:39 PM
is now Feet Wet
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Turnigy 2700mah 3s fits without any foam removal, I now use these sized lipos in all my PZ stuff gives a nice boost in time or can be used to fuel a nice 4 blader.
Dave
dav3uk is offline Find More Posts by dav3uk
Old Nov 20, 2012, 01:45 PM
BlinkguY's Avatar
Joined Nov 2005
Dave
the CG still fine after that?
Old Nov 20, 2012, 02:39 PM
United States, NM, Las Cruces
Joined Jul 2012
I fly mine HARD with a 4s 2200 40c pack on the eflite power 25 1250kv motor and a 9x9 prop. Never had any problems at those speeds and no reinforcements of any kind have been used
erikc641 is offline Find More Posts by erikc641
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 09:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
