Old Nov 16, 2012, 01:22 AM
emeraldc is offline
Find More Posts by emeraldc
west coast flyer
emeraldc's Avatar
Joined May 2012
Originally Posted by BlinkguY View Post
great then...
how does the regular wheels perform on this bird while landing on grass? my t-28 always do the flip over thing... somebody told me about the p47 wheels are way better to land on grass... is that true.. i already ordered 3 pairs for my trojan and apprentice i think my wife is getting me the p47 for xmas, she wants me to get a retract full plane
The regular wheels are good on the grass.
I just added the retracts & flaps Love this plane, retracts make it way better for sure. Flaps are not really needed, but I like them
emeraldc is offline Find More Posts by emeraldc
Old Nov 16, 2012, 07:37 PM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Took her out again, doing high speed straifing runs in suburbia. Had a couple guys stop and watch She did it all today rolls, loops, hammerheads! She is definitely my favorite warbird! She just makes it all easy!
IndyMatt is offline Find More Posts by IndyMatt
Old Nov 16, 2012, 11:48 PM
quitcherbitchen is offline
Find More Posts by quitcherbitchen
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
I hope you gave Sububia hell.
quitcherbitchen is offline Find More Posts by quitcherbitchen
Old Nov 17, 2012, 10:14 AM
op1900 is offline
Find More Posts by op1900
USA, IL, Chicago
Joined Nov 2010
I see many of you guys are using 4s setup. Let's assume I have G25 motor installed, what is the preferred setup? I just want it to be most efficient as far as performance goes. Nice speed and enough power without sacrificing a flight time. Any advice in this matter would be greatly appreciated.
op1900 is offline Find More Posts by op1900
Old Nov 17, 2012, 11:37 AM
19000rpm is offline
Find More Posts by 19000rpm
Joined Aug 2009
This is what I did last year. I was working up from a Power 15 to a Power 25. It worked quite well. Plenty fast and reasonable Amp draw.
I spec'd the Callie Graphics for Hobbyzone. These are the prototype graphics. The numbers came out too large so I trimmed them down in the wing area. The production graphics are slightly smaller to fit over the wing and the thunderbolts slightly larger.
http://secure.hobbyzone.com/search/RAZ003.html
This time I used a different power system:
Eflite Power 25 (1250kV)
Eflite Pro 60A ESC
APC 10x6x4 prop (grey) painted flat black with Insignia yellow tips
2200mAh 30C 4S Eflite
The later model D's also had a fin on the vertical stab for additional yaw stability. The fin I used is a piece of creased file folder.
19000rpm is offline Find More Posts by 19000rpm
Old Nov 17, 2012, 12:32 PM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Looks great! I dig the exhaust stains!
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Nov 17, 2012, 02:19 PM
19000rpm is offline
Joined Aug 2009
Thanks. Just a bit of airbrushing.
Old Nov 17, 2012, 03:36 PM
Joined Oct 2008
I like the way you tapered the blue, and added a antenna also.. Cool! Im steeling that antenna Idea. Here is mine.
Old Nov 17, 2012, 03:53 PM
Edge767 is offline
Find More Posts by Edge767
AMA 52726
Edge767's Avatar
United States, TX, Spring
Joined Jun 2005
Wow! Great looking Jugs!
Edge767 is offline Find More Posts by Edge767
Old Nov 17, 2012, 04:25 PM
19000rpm is offline
Joined Aug 2009
You may as well steal the pitot tube on the right wing too. LOL
Thanks, Edge.
Old Nov 17, 2012, 05:42 PM
Joined Oct 2008
Thanks!
Thanks, Edge.
Will do!!
Old Nov 18, 2012, 07:21 PM
ufale is offline
Find More Posts by ufale
ufale's Avatar
Joined Nov 2010
I finally got the Eflite Power32 for my P47. I am going to be using it with an ICE 50 esc, and 3s 2600 batteries. If the bench test works out, I want to use it with the Hobby Lobby 4 blade prop. Has anybody fit this motor to this plane? If so, what is the best way to mount it? I was thinking of just fixing the stock mount to the firewall. If I do this, I think I will have to modify the cowling.
ufale is offline Find More Posts by ufale
Old Nov 18, 2012, 07:50 PM
19000rpm is offline
Joined Aug 2009
I haven't heard of anyone using bigger than a 25. Me being one of those that went that way.
Far be it from me to discourage the use of more power, but... Why a 32 on 3S
for a plane of this size? Just curious. It's a monster motor for this P47 and better suited, IMHO, to 4S or 5S, on a larger plane.
I think the length (1.9") is close to the size of the stock 15. You shouldn't need to alter anything except, maybe, mounting holes on the cowl.
Old Nov 18, 2012, 08:39 PM
copperbricks is offline
Find More Posts by copperbricks
You can't take the sky from me
copperbricks's Avatar
United States, OH, Cincinnati
Joined Aug 2011
I think some people have used the e-flite 32 with 5s.
copperbricks is offline Find More Posts by copperbricks
Old Nov 18, 2012, 09:07 PM
scootrb4 is offline
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
I used the 32 in a 1400mm nearly 5 pound plane on 5s.
I'm no expert but, it might be too much weight to power ratio for this wing area ...
I'm getting about 90mph out of a 4s 480 (10x10 prop) in this little plane.
scootrb4 is offline Find More Posts by scootrb4
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 11:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 10:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 10:08 AM
