well, try a longer takeoff run on the Supercub...I jumped from a Micro to this...So you could imagine my learning curve altho it wasn't that bad...There's nothing like the satisfaction of watching your plane get up on the front wheels before it lifts up....But practice these techniques on your Supercub
Anyone that has flown a 4 channel plane before can "fly" this plane. The trick is getting it into the air and back down on the ground again.
I had the pleasure of watching ryramZ fly his at NEFI in 2011 and his take offs and landings were simply amazing. Nice smooth take off runs with an easy climb to altitude. 100 ft roll outs on the mains before the tail settled to the ground on landings. Touch and goes where the plane rolled along on the mains before lifting off again. Made me jealous. Also made me practice more. Practice, practice, practice. Then practice some more. |
Again, those our very kind words and I truly appreciate them. Hopefully I'll get the pleasure to fly with you and your brother again. Always a great time in Muncie, the best flying sites in the world.
So finally did maiden today and this is what I found
Flies well Not overly impressed with power but has stock prop so that'll have to change Rolls good Landings arent overly hard Flaps work well to keep nose up Damn tail wheel came off again on landing. Came off first time I tried to maiden and I though I fixed it Anyone else have issues with tail wheel.? Also how do you guys compare this to power vs t28? |
Latest blog entry: Estes Rubber Band Condor gets powered...
United States, NJ, West Deptford
Joined Jan 2012
3 cell Propellor Recommendations
OK so I've given up on getting my EFlite 25 to run on 3 cells. tried all suggestions/recommendations from the power forum, its either a motor or ESC problem but thats for another day. From what I read here I'm ordering the suggested Tunegy 25 870kv and have 60amp ESC. Want to fly on 3 cell 2200 & not get into buying more batteries (4s) or adding weight. Seems most prop recommendations are 4 blade & 4 cell setup. How about recommedation for 3 cell and not needing to rip up the sky. just looking to get into the air with a "safe" prop. However, in the spring will probably consider getting more exotic once I get a few flights under my belt. I hope to order prop(s) when I order motor.
What works for you 3 cell flyers? thanks Leon |
Still can't figure out why the Eflite Power 25 is not working for you though, as there is no reason it should not work with a 3 cell lipo. What is it about it that is "not working" for you? Good luck with what ever choice you make. You'll love this plane though, she is a great flyer. Marlin |
Joined Jan 2012
my bad, need suggestions for 2 blade prop.
should have mentioned I want to go with a 2 blade prop for now, I have flown but electric is new to me, I'm switching over. Does that mean I'm Bi ??? LOL By spring should have a better feel for plane & will probably be doing the extras (4 blade prop, flaps & retracts). As far as getting motor to run, have been trying different suggestions from this site for over a week. It just does not want to recognize a 3 cell battery. No power to motor with 3c, have tried rebinding several ways, even to new blank model on TX. I can just change batts from 3s to 4s and the 4s works. All batts fully charged. The 60A ESC is susposed to be self detecting between 3/4 cells & no setup for it in manual. I don't own a 2200mah 4s Actually borrowed one for expermentation. Have several 3s. just got a watts meter & dont know how to work it yet. & dont want to buy a bunch of props. Figured someone here has something that works.
Thanks again. |
ok the extra 300 prop is a 10.5x9x2 on the same set up ecalc has your max amps @ 29.66 and your pitch speed @ 68.
watt meter is very easy to use. just plug it inline between the esc and the battery. all its going to tell you is the max watts or amps you are pulling this way you know if the motor can handel the prop you are using. just remember that you will sumtract 15-20% of the static number because the prop will on load in the air and draw less. hope this helps. here is the the ecalc link use it. its a strart and you can try different prop sizes without having to buy them. http://www.ecalc.ch/indexcalc.htm |
| Thread Tools | |
| Discussion World Models p47 1.20 | dards | Fuel Warbirds | 1 | Oct 20, 2010 10:55 AM |
| Discussion E-Flite P47 or Parkzone Corsair?? | Gobstopper | Electric Warbirds | 13 | Dec 02, 2009 09:37 PM |
| Discussion New Parkzone p51 or Greatplanes P47 | casedit | Electric Warbirds | 5 | Sep 01, 2009 09:08 AM |
