Old Oct 17, 2012, 05:06 PM
scootrb4 is online now
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Flew lots of touch and goes this AM. This plane was the winner. Of the 3 warbirds I brought this was hands down, the easiest T&Gs... like she was on rails with too much power and having too much fun.
scootrb4 is online now Find More Posts by scootrb4
Old Oct 17, 2012, 05:08 PM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
Originally Posted by skypan12 View Post
If I change the motor to the Hacker A30-12XL V2
http://www.aero-model.com/Hacker-Bru...-A30-12XL.aspx which is 700 KV rather than the 900kv A30 10XL V2 do you think that would work better for this set up?
Switching to the APC 4-blade would be a plus as far as safety is concern with a hot set up as you say it is one piece and a little more robust, and it being 11X9X4 and cutting it down to the 10X9X4 would that set up be little better?
I do not have ecalc and run Mac so I dont know if I can get ecalc to work, any input would be helpful on this.
eCalc is a web page, I'm running it on linux, and I've done it on my iPhone previously. It'll probably work on your mac:
http://www.ecalc.ch/motorcalc_e.htm?ecalc
Running the numbers for the APC cut to 10", with the motor Papabatman suggests, looks like a pretty dang good setup.
9.32min runtime. 25A (!!), .83 thrust/weight. The pitch speed is a little low, though, at 65mph.
For that prop, it may be better to go with the G25-710kv motor. You still get 6.7min flight, but the pitch speed goes up to about 72mph, pulling 33A, but with a 1.0 thrust to weight.
The point is, go play with the numbers until you get something you're happy with.
jtaylor996 is offline Find More Posts by jtaylor996
Old Oct 17, 2012, 05:25 PM
skypan12 is online now
Find More Posts by skypan12
Northern IL
Joined Sep 2006
Originally Posted by papabatman View Post
ok, the numbers look better with this motor ya? well then do you think 3S or 4S for batt? I will be using the CC BEC also.
skypan12 is online now Find More Posts by skypan12
Old Oct 17, 2012, 05:43 PM
papabatman is offline
Find More Posts by papabatman
Shut up and fly
papabatman's Avatar
United States, CO, Dacono
Joined Jun 2008
here is the thing you have to figure out what it is you want your bird to do. if you want a 4 blade and a 10 pitch on 4s then this would be safe. on 3s with a smaller prop and pitch not so great. there are so many great choices for a 4 blade set up buried in this thread. for fun try a search on motors and 4 bladed props see what others have done
papabatman is offline Find More Posts by papabatman
Old Oct 17, 2012, 09:16 PM
ww2birder is offline
Find More Posts by ww2birder
too many planes
ww2birder's Avatar
United States, MI, South Lyon
Joined Sep 2012
Originally Posted by quitcherbitchen View Post
I try to stay away from the....Repeat. Papa's advice is sound. The watt meter is a must. And If you own more that a dozen(flyable) planes then I guess I am a Crack Pot.
The HL 4 bladed prop is amazingly durable. The blades flex quite a bit and take quite a lot of punishment. The Prop on 3s sounds like a window fan as it goes by. When you get into 4s now your into uncharted waters.
ww2birder is offline Find More Posts by ww2birder
Old Oct 17, 2012, 10:43 PM
kingleh is offline
Find More Posts by kingleh
Joined Sep 2012
Can someone run the numbers on my setup..
Power 32 - 60amp esc - 2500 4S
I ran a 12x10 prop but also tried a 12x12.. The 12x12 was very similar in performance to the 12x10. Bat was pretty warm though..
I went back to the 12x10 but would like to know what the numbers say..
kingleh is offline Find More Posts by kingleh
Old Oct 18, 2012, 12:17 AM
Shut up and fly
papabatman's Avatar
Joined Jun 2008
not good to big of prop 72 amps on a 12x10 go to a 12x7 for 55 amps
Old Oct 18, 2012, 12:32 PM
RunninKurt is offline
Find More Posts by RunninKurt
Accidental Kamakazi
RunninKurt's Avatar
United States, TX, Houston
Joined May 2012
Thanks for this post! My buddy has a PZ Corsair, and it flies nice, but I dont want to buy the same plane as him. When shopping other PZ planes, my biggest interest is T&Gs (Im a prior Navy guy)
Seeing videos of the BF109 being so tipsy, your comment sparked my interest in this plane.
RunninKurt is offline Find More Posts by RunninKurt
Old Oct 18, 2012, 02:19 PM
Shut up and fly
papabatman's Avatar
Joined Jun 2008
touch and goes are a blast with the p-47 plus retracts big winner here
Old Oct 18, 2012, 02:43 PM
scootrb4's Avatar
Joined Nov 2011
I try not to mention other birds in a model specific thread but since we are making a direct comparison I'll make the exception.
The three warbirds I brought out for T&G practice were the PZ P47 and Spitfire, both with Eflite retracts, and the Dynam bf109. Dynam because all warbirds need retracts.
I flew figure 8s with the landing strip on one leg of the X part, touch and go...
As I said the P-47 was the hands down most stable & easiest of the 3, the Spit was a close second and the 109 a lagging 3rd. Each plane ranks relative to the width of it landing gear. This was no big surprise. My opinion is this plane does the best T&Gs even compared to tricycle gear planes like the T-28 trainer.
However tomorrow I maiden a Corsair which may upset the ratings
Old Oct 18, 2012, 06:34 PM
jdm2ner is online now
Find More Posts by jdm2ner
flying is everything
jdm2ner's Avatar
United States, FL, Hollywood
Joined Oct 2010
has anyone ever try the durafly p47 prop
jdm2ner is online now Find More Posts by jdm2ner
Old Oct 18, 2012, 07:32 PM
hillbille is offline
Find More Posts by hillbille
AMA 884978/KK6NKY
hillbille's Avatar
United States, CA, Barstow
Joined May 2007
Pulls way too many amps for the stock motor. It does work with a modded motor of 870kv or lower and a bigger than stock ESC.
I fly one on my PZ Spitfire with the G-25 870 HK motor. It's okay and looks great in the air but it's no speed demon and if antthing is slower than stock set up and it is an AMP hungry prop!
Hillbille
hillbille is offline Find More Posts by hillbille
Old Oct 18, 2012, 07:48 PM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
It's also super weak. Breaks just looking at it.
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Oct 18, 2012, 10:18 PM
jdm2ner's Avatar
Joined Oct 2010
thanks guys. I bought the Turnigy G25 Brushless Outrunner 710kv with the hobby lobby 11x10x4 i have lower the pitch to about 7 on a 4s an im at 41.79 amps. thats what ecalc tells me i just have to get the motor and test. will see what she pulls in the air.
Old Oct 18, 2012, 11:06 PM
Ducati Mechanic is online now
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Guys,
Just a heads up! I just finished my build, and with a 820kv Torque motor/ airboss 45amp, swinging the Hobby lobby 4 blade(set at 11x10),It pulls 900 watts at 70+ amp, and that was with my tired old 4s 2200 turnigy 30c packs. This setup pulls 750watts at 5amp swinging a 13x6xoar, So I plan on pitching it back to 11x8, and I'll report back.
Ducati Mechanic is online now Find More Posts by Ducati Mechanic
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 11:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 10:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 10:08 AM
