Old Oct 11, 2012, 11:52 AM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
Originally Posted by neck View Post
You really think it's a radio brand thing? Wow.
No, it's just that the spectrum receivers have a very picky voltage tolerance, and then they brown out. Has nothing to do with radios or brands. It just happens that spectrum brand receivers all have this problem. Just a coincidence
The Hitec SPC thing powers the optima receivers off a huge range of voltages, so it won't brown out. You still need to power your servos, but if those brown out, it won't crash your plane, since they don't take 10s to reboot
jtaylor996 is offline Find More Posts by jtaylor996
Old Oct 11, 2012, 12:38 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Originally Posted by Dora Nine View Post
Coulda swore mine came with the linkages. I think I just had to order the struts for the retracts.
Yup, mine came with flap kit, AND since I'm a Cheap Charlie, I just went ahead and used the existing struts, too -- five minutes with the Dremel and we were good to go, using HK retracts!
tracknoob is offline Find More Posts by tracknoob
Old Oct 11, 2012, 01:03 PM
Dora Nine is offline
Find More Posts by Dora Nine
The sky is my playground.
Dora Nine's Avatar
United States, NH
Joined May 2005
Originally Posted by Razors edge 29 View Post
All my gear finally arrived; ready to start building now
Do i glue the h stab into place?
Depends on how often you think you'll be replacing it. I glued mine.
Dora Nine is offline Find More Posts by Dora Nine
Old Oct 11, 2012, 08:30 PM
jdm2ner is offline
Find More Posts by jdm2ner
flying is everything
jdm2ner's Avatar
United States, FL, Hollywood
Joined Oct 2010
I glued mine too
jdm2ner is offline Find More Posts by jdm2ner
Old Oct 11, 2012, 08:49 PM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
I used a few dabs of foam safe hot glue, for the vertical stabs, and servos.. Holds well, but easly removable.
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Oct 12, 2012, 06:35 AM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Thanks guys
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Oct 12, 2012, 06:59 PM
Joined Oct 2008
Received my customRC motor mount, and just dry fitted it. The Turnigy mount works perfect with a torque 2814T/820, after you push the prop shaft threw. The factory cowl screw holes, even line up.
Old Oct 13, 2012, 03:01 AM
papabatman is offline
Find More Posts by papabatman
Shut up and fly
papabatman's Avatar
United States, CO, Dacono
Joined Jun 2008
nice
papabatman is offline Find More Posts by papabatman
Old Oct 13, 2012, 04:25 PM
jdm2ner is offline
jdm2ner's Avatar
Joined Oct 2010
well here she is with the hobby-lobby 4 blade prop
Old Oct 13, 2012, 05:06 PM
skypan12 is online now
Find More Posts by skypan12
Northern IL
Joined Sep 2006
Sure looks Good!
skypan12 is online now Find More Posts by skypan12
Old Oct 13, 2012, 05:16 PM
ufale is offline
Find More Posts by ufale
ufale's Avatar
Joined Nov 2010
Looks great. I have this prop, but I dare not use it with my power25. I will have to wait until I get a power32.
ufale is offline Find More Posts by ufale
Old Oct 13, 2012, 05:19 PM
jdm2ner is offline
jdm2ner's Avatar
Joined Oct 2010
I use the power25 870kv with a 4s and she is fast faster than the stock 2 blade setup
Old Oct 13, 2012, 05:26 PM
Northern IL
Joined Sep 2006
why not? I am going to set mine up with the Power25 and the HL 4-blade and run on 4S is there some reason why you are not going to run this prop with the Power25?
Old Oct 13, 2012, 05:30 PM
ufale is offline
ufale's Avatar
Joined Nov 2010
The specs list this motor as only capable of 40amp continuous current. I think I will go over that this 11 inch prop.
Old Oct 13, 2012, 06:00 PM
Mitchie is online now
Find More Posts by Mitchie
Mitchie's Avatar
Canada, QC, Gatineau
Joined Jan 2011
No way! I'm running a power 15 with the HL 11" prop at 10" pitch. It flies great at 1/2 throttle, and will take short bursts of wot with no ill effects. I'm running 50amp Ice lite and had static tested with a 54 amps at wot, going down to 45. If you unload the prop, then you are within the safe zone of the esc unless you always flying at wot. It'll fly great at 1/2 to 3/4 throttle, and no over amp. If you want to go fast, put an extra 300 prop. The HL prop isn't a lot faster than the original, but the prop pulls like a tractor. (gets looks at the flying field too)
Mitchie is online now Find More Posts by Mitchie
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 09:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
