Old Sep 24, 2012, 11:23 AM
LICobra is online now
Find More Posts by LICobra
Warbird Enthusiast
LICobra's Avatar
Long Island, NY
Originally Posted by javier668 View Post
Hi LICobra, using your configuration, and the 3s 2200 mah lipo, how much time can you fly?
Regards!
javier....I typically set the timer for 5 minutes of "spirited" flying then bring her down...if I have to make an extra pass or two to land that's not a problem either.
LICobra is online now Find More Posts by LICobra
Old Sep 24, 2012, 11:35 AM
neck is offline
Find More Posts by neck
Jeremy-I'm crash proof!
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
Originally Posted by jdm2ner View Post
thanks guys i will be buying thi as i will be upgrading to the eflite 25
I have this motor mount. Worth every penny!
neck is offline Find More Posts by neck
Old Sep 24, 2012, 01:12 PM
Edge767 is offline
Find More Posts by Edge767
AMA 52726
Edge767's Avatar
United States, TX, Spring
Joined Jun 2005
I just completed flight 80 this weekend on my Jug, and when I logged the time, it turned out that I am averaging 6 minute flights overall. I use 2200 mah lipos, and I tend to manage the throttle quite a bit to keep the motor, ESC, and battery from getting too hot here in Texas. I have the alarm on my DX8 set for 6 minutes, and I typically land right around that time.
With that said, I was reminded why I love this plane so much. With flaps and gear down, it lands like a pussy cat. The club field has lowered the mower blades and now taxiing, takeoffs and landings are all easy without nose-overs. While I am really looking forward to the new Corsair, the Jug is still the reigning queen of my squadron.
Edge767 is offline Find More Posts by Edge767
Old Sep 24, 2012, 07:02 PM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
So what does it do that the stock mount doesn't?
jtaylor996 is offline Find More Posts by jtaylor996
Old Sep 24, 2012, 07:07 PM
DaxFX is online now
Find More Posts by DaxFX
AIMDROIX
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
320pilot, I liked the MOON SHOOT. take a look at my "T"
DaxFX is online now Find More Posts by DaxFX
Latest blog entry: Puerto Rico Drone Prix 2016
Old Sep 25, 2012, 12:49 AM
neck is offline
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
It's shorter so it allows a bigger or a longer motor to mount with modication to anything. I'd also say urn breakable. Break the firewall before you break this,
Old Sep 25, 2012, 02:23 AM
BramV is online now
Find More Posts by BramV
Nederland, FR, Sneek
Joined Jul 2011
Hello,
I've got a question, with what type of glue should i install the flap servo's?
Bram
BramV is online now Find More Posts by BramV
Old Sep 25, 2012, 05:02 AM
accel8or is offline
Find More Posts by accel8or
Mark Beltran
accel8or's Avatar
United States, CA, Westminster
Joined Dec 2010
Originally Posted by BramV View Post
Hello,
Bram
RTV Silicone
accel8or is offline Find More Posts by accel8or
Old Sep 25, 2012, 05:03 AM
BramV is online now
Joined Jul 2011
Oke, thanx
Bram
Old Sep 25, 2012, 06:16 AM
DaxFX is online now
AIMDROIX
DaxFX's Avatar
Joined May 2008
Hello,
Bram
im using servo tape with a drop of ca in the servo lips..
Old Sep 25, 2012, 06:22 AM
19000rpm is offline
Find More Posts by 19000rpm
Joined Aug 2009
Any silicone product will work, DAP, etc., and has the advantage of a good bond that will not pull the foam out when servo is removed. Unlike: CA or Epoxy that will pull out foam when the servo is removed.
19000rpm is offline Find More Posts by 19000rpm
Old Sep 25, 2012, 06:51 AM
javier668 is offline
Find More Posts by javier668
Chile, Araucanía, Angol
Joined Jan 2012
+10
Some glue can do the Job
Regards
javier668 is offline Find More Posts by javier668
Old Sep 25, 2012, 09:39 AM
scootrb4 is offline
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
I use Beacon Foam-Tac on everything... stick the surfaces together once or pull them apart and let it dry a little, then rebonds like contact cement. Leaves a little time for re positioning too.
scootrb4 is offline Find More Posts by scootrb4
Old Sep 25, 2012, 10:00 AM
Registered Crasher
Joined Feb 2011
I use the power 25 already, and I found no modification was necessary. It just bolts right up, and the prop to cowl spacing is perfect.
Is it lighter than the plastic piece?
Old Sep 25, 2012, 10:05 AM
Registered Crasher
Joined Feb 2011
So, I lucked out with my rebuilt P47 on Saturday. I had a brain fart and ended up taking off with a waaaaay nose heavy plane. I couldn't get it to climb, even on high rates, unless I maxed the throttle. It was a very short flight. It went over the dike and into the ground at a minimum of 60mph.
Broke the cowl, prop, and a servo arm. I need to reglue a wing tip, and there's a minor scuff on the belly (I wasn't using the included armor plate).
Um... huh?? I expected to find individual foam cells it went in so hard.
Since it went over the crown of the dike as it went in, I never saw the impact. But the down angle must have helped, and it must have gone in wings level.
Any other remarkable crash survival stories on other P47s?
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 09:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
