Espritmodel.com Heli Air
Old Sep 20, 2012, 09:58 PM
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
Got a guy that showed up with a Wildcat using Habu running gear last weekend....now that was cool!
JDMJim is offline Find More Posts by JDMJim
Old Sep 20, 2012, 10:07 PM
Addicted to Warbirds
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Originally Posted by kingleh View Post
Well just flew my Thunderbolt with new setup.!!!... I have not seen alot of RC planes fly because i am semi new to the hobby.. But this thing is pretty awesome and smokes anything i have seen fly on power, speed and climb...
I went big with the E-Flight Power 32, 60amp ESC and 2500mah 4cell 30c.. Paired with a Extra 300 prop.. I plan to try a 10x10 prop next and will see what my amp is.. I think it should be fine though..
Man this thing is a beast in the sky.. Covers some ground very quickly..
Here is a lil vid my buddy took..
http://youtu.be/2Fm4Ptgj-7Y
old VS new
I just bolted the motor mount to the firewall and got rid of the original plastic spacer..
This setup is a bit shorter then stock but i thought that would help the CG.. I trimmed the underside of the cowl a little and pushed it back about 6 or 7mm.. You can see the original screw holes still..
I located the ESC as far back as possible also and "bridged" it across for cooling..
In the end the CG came out very close and when i add flaps that should help also... I have the E-Flight retracts and they are very sweet!!!
SWEET low pass there. What prop are you running with the G32?
scootrb4 is offline Find More Posts by scootrb4
Old Sep 20, 2012, 10:41 PM
St. Louis
Foambird's Avatar
USA, MO, Ballwin
Joined Mar 2010
The Eflite retracts are terriic, no apologies.
They are not quite "drop-in" and need to be carefully adgusted but once dialed in they are the way to go.
Foambird is offline Find More Posts by Foambird
Old Sep 21, 2012, 04:50 AM
The sky is my playground.
Dora Nine's Avatar
New Hampshire
Joined May 2005
What's needed for to mount the H-L four blade prop to the Power 25? Anything extra?
Dora Nine is offline Find More Posts by Dora Nine
Latest blog entry: A good watch...
Old Sep 21, 2012, 05:10 PM
Joined Sep 2012
King that thing really rips! I can't believe how fast it climbs into the clouds.
Cicio is offline Find More Posts by Cicio
Old Sep 22, 2012, 08:43 AM
flying is everything
jdm2ner's Avatar
United States, FL, Hollywood
Joined Oct 2010
to many pages to read what do i need to to convert it to a 4 blade prop and what prop?
jdm2ner is offline Find More Posts by jdm2ner
Old Sep 22, 2012, 01:11 PM
Joined Sep 2012
ExTRA 300
kingleh is offline Find More Posts by kingleh
Old Sep 22, 2012, 01:12 PM
Joined Sep 2012
Originally Posted by jtaylor996 View Post
Just make sure you have enough down and right thrust without that plastic motor mount. You may need some shim washers.
The firewall has the slant for the thrust balance.. The motor mount was symmetrical..
Old Sep 22, 2012, 04:33 PM
ufale's Avatar
Joined Nov 2010
I am working on putting electronics in a new P 47 airframe. I am using this setup: extra 300 prop, eflite power 25, and castle ice 50 amp, 3s 2650 40c (for now). I got the following numbers: 33.9 amps and 400 watts. I ordered the Hobby Lobby 4 blade, and I think it should be well within the limits of my esc.
ufale is offline Find More Posts by ufale
Old Sep 22, 2012, 10:22 PM
scootrb4's Avatar
Joined Nov 2011
Research your motor and see what the amperage limit is.
Old Sep 23, 2012, 08:05 AM
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Power 25 870kv:
Continuous Current: 31 - 40A
Maximum Burst Current: 44A (15 sec)
-Brian
kalmon is offline Find More Posts by kalmon
Old Sep 23, 2012, 08:31 AM
scootrb4's Avatar
Joined Nov 2011
Originally Posted by kalmon View Post
Power 25 870kv:
-Brian
ufale wrote = I got the following numbers: 33.9 amps and 400 watts. I ordered the Hobby Lobby 4 blade, and I think it should be well within the limits of my esc.
I was thinking the 4 blade may bring the amperage draw above acceptable levels for this motor?
Old Sep 23, 2012, 08:42 AM
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
I agree, I just posted the specs for it.
Actually the Power32 770kv would probably be the best choice. Only 10g heavier and rated for 50amps continuous and 60amps burst.
-Brian
Old Sep 23, 2012, 09:40 AM
R.C. Aviation Fanatic
Razors edge 29's Avatar
Canada
Joined Aug 2009
Mine isn't built yet
I am waiting in parts
Ordered p15
40 amp EsC
Extra 300 prop
And full metal digital servos
Will be using flaps as well on an external ubec
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Sep 23, 2012, 10:11 AM
jdm2ner's Avatar
Joined Oct 2010
well i just bought this p47 yesterday. got the eflight retracts and installed the flaps using hs65 thaywork great. i also bought he razor back ki and the hobby lobby 4 blade waitting on those to come in
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 09:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
