Old Sep 19, 2012, 08:49 AM
nageotte is offline
Find More Posts by nageotte
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
Yes
Originally Posted by kalmon View Post
I don't have that motor but I think I've seen this one referenced a couple times.
If it performs even half as good as it looks it will be great!
-Brian
It's main attaction is the looks. But I fly with the stock motor, bigger ESC and set to minimum pitch and I love the heck out of it!!
You can tell it's a four blade even in flight. Check the photo. Does that look real or what?! I also have a retractable tail wheel on it.
nageotte is offline Find More Posts by nageotte
Old Sep 19, 2012, 10:01 AM
scootrb4 is offline
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
I fly with a 2 blade. Once I start it up you can't count the blades.
The main attraction is the speed I get on the low passes from the 4s motor combo.
And with 4s & a 10x10 prop she performs aerobatics from a stall
Fun plane in any configuration!
scootrb4 is offline Find More Posts by scootrb4
Old Sep 19, 2012, 05:30 PM
copperbricks is offline
Find More Posts by copperbricks
You can't take the sky from me
copperbricks's Avatar
United States, OH, Cincinnati
Joined Aug 2011
what motor do you run with that? Mine is pretty zippy on a g15, 10x10, and 3s
copperbricks is offline Find More Posts by copperbricks
Old Sep 19, 2012, 06:06 PM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
I have the 480 plus from headsuprc running on 4s with a 60a eflite . It has been a fun set up. Going on about 70 flights now.
Old Sep 19, 2012, 06:10 PM
neck is offline
Find More Posts by neck
Jeremy-I'm crash proof!
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
Man are you guys sure you are running 4s on this plane? LOL.
I thought it was nose heavy with the 3s 3300's and a G25 I'm running. I can only imagine how nose heavy with a 4s setup.
neck is offline Find More Posts by neck
Old Sep 19, 2012, 07:58 PM
ww2birder is offline
Find More Posts by ww2birder
too many planes
ww2birder's Avatar
United States, MI, South Lyon
Joined Sep 2012
I use a turnigy 36 42 1100 motor with a castle 54 and the plane has a good power to weight. I also use the standard 2200 lipo batteries everybody has in their hobby box. I ordered a four bladed scale prop from Hobby Lobby and the speed control gets a little warm..... But looks so cool!
ww2birder is offline Find More Posts by ww2birder
Old Sep 19, 2012, 09:11 PM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
Hobby lobby also has a 9" 4 blade that should be ok on this plane, and should draw much less amps than an 11".
This is why I cut my APC 11x9x4 down to 10"...
Check out the ecalc numbers if you're getting things too hot. Those matched my observed current draws spot on.
jtaylor996 is offline Find More Posts by jtaylor996
Old Sep 19, 2012, 09:38 PM
too many planes
ww2birder's Avatar
Joined Sep 2012
the Hobby Lobby 9" prop does work better but the 11" prop looks better. Did you balance it and round the edges?
Old Sep 19, 2012, 11:13 PM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
I use the 2200 4s in the stock position and balance was not an issue. Flies as on rails Like a hi-speed metrolink
Old Sep 20, 2012, 09:31 AM
Registered Crasher
Joined Feb 2011
Yeah. First, I make a quick jig out of a hunk of wood with a shaft in it, and mounted it to my drill press. I put in a mill (like an enormous dremel bit), and then carefully milled the ends off to the correct length.
My jig needs serious re-doing, however. I need to put a 8mm shaft in it, and some better clamping.
Once it's all setup to the correct length, just round over/taper the edges. It takes way longer to balance an APC prop than it does to cut it down. It seems the blade with the 11x9x4 writing on the front is always very heavy.
I still need to paint it. Someday.
It's been very durable, as I've nosed it over many a time by now. Also did a lawn dart after a takeoff. Still perfectly straight!
In my experience, the parkzone props balance really well out of the box, unlike the APC.
Old Sep 20, 2012, 03:05 PM
benj38 is offline
Find More Posts by benj38
United States, IL, Marseilles
Joined Jul 2012
Maidened the P-47 this morning. What a sweet flying plane. The winds were gusting around 18 MPH in late morning, but the Jug handled them with no problem.
Sure looks awsome on a low pass with the gear tucked up. Glad the guys on here persauded me to go with the E-Flite retracts. They preformed flawlessly. I LOVE it
benj38 is offline Find More Posts by benj38
Old Sep 20, 2012, 05:30 PM
javier668 is offline
Find More Posts by javier668
Chile, Araucanía, Angol
Joined Jan 2012
Welcome to the P47 fan club jejeje
javier668 is offline Find More Posts by javier668
Old Sep 20, 2012, 05:58 PM
kingleh is offline
Find More Posts by kingleh
Joined Sep 2012
Well just flew my Thunderbolt with new setup.!!!... I have not seen alot of RC planes fly because i am semi new to the hobby.. But this thing is pretty awesome and smokes anything i have seen fly on power, speed and climb...
I went big with the E-Flight Power 32, 60amp ESC and 2500mah 4cell 30c.. Paired with a Extra 300 prop.. I plan to try a 10x10 prop next and will see what my amp is.. I think it should be fine though..
Man this thing is a beast in the sky.. Covers some ground very quickly..
Here is a lil vid my buddy took..
ParkZone Thunderbolt Boss-Hoggin with Power32 motor (0 min 28 sec)
old VS new
I just bolted the motor mount to the firewall and got rid of the original plastic spacer..
This setup is a bit shorter then stock but i thought that would help the CG.. I trimmed the underside of the cowl a little and pushed it back about 6 or 7mm.. You can see the original screw holes still..
I located the ESC as far back as possible also and "bridged" it across for cooling..
In the end the CG came out very close and when i add flaps that should help also... I have the E-Flight retracts and they are very sweet!!!
kingleh is offline Find More Posts by kingleh
Old Sep 20, 2012, 08:39 PM
Registered Crasher
Joined Feb 2011
Just make sure you have enough down and right thrust without that plastic motor mount. You may need some shim washers.
Old Sep 20, 2012, 09:37 PM
ForsheeMS is offline
Find More Posts by ForsheeMS
ForsheeMS's Avatar
United States, NC, Lexington
Joined Jul 2012
Just picked up a new Jug this afternoon. Went ahead and got the E-Flight retracts and flap servos. Got everything together but the retract lead is about 4" too short to plug into the receiver. Guess another trip to the LHS in the morning. Can't wait to fly this thing!
ForsheeMS is offline Find More Posts by ForsheeMS
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 09:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
