Old Jul 28, 2012, 09:50 PM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
Maiden went well today! I went 6min on my 3300 packs, which only used 1400mah each. I figure 9min ought to use up about 2700, or could I push it longer?
Landing was great with the flaps. It comes in fast, but smooth as butter! I just need a wider runway! Taking off is surprisingly difficult. I hopped a curb at one point, but took the altitude and ran with it. It think it put the prop out of balance, as all the motor mount screws were loose after the day.
The stock prop is terrible on the power 25. The E300 prop worked well enough.
I didn't try too many tricks, as I was keeping to short flight times. But I did pull off the most beautiful hammerhead I've ever done, as well as som nice tight rolls.
I was a little worried I had programmed way to much in to begin with, but everything worked fantastically. I started with slow flaps, ail/rudder mix, differential ail, expo, etc. I figured I'd get something wrong, but everything feels right so far.
jtaylor996 is offline Find More Posts by jtaylor996
Old Jul 28, 2012, 10:36 PM
scootrb4 is offline
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Congrats jtaylor on your successful maiden.
I know what you mean about over-programming a plane, I have learned to keep it simple initially.
She is great flyer
scootrb4 is offline Find More Posts by scootrb4
Old Jul 28, 2012, 11:53 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Hey guys. So with the stock setup on the P47, will i be able to use a 2200mah 20c lipo without hurting the battery?
electricrc68 is offline Find More Posts by electricrc68
Old Jul 29, 2012, 12:03 AM
DaxFX is offline
Find More Posts by DaxFX
AIMDROIX
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
2200mah at 20c will give you 44amps. You can calc yourself how many amps can drain your bateries. 20c meand 20 times the battery "C"apacity. So 2200mah converted into amps is 2200/1000 = 2.2amps multipli this by the 20c you get 44amp
DaxFX is offline Find More Posts by DaxFX
Latest blog entry: Puerto Rico Drone Prix 2016
Old Jul 29, 2012, 12:06 AM
Joined May 2011
Oh okay cool thanks. So the stock setup pulls around 30-35A right? (can't remember at the moment). So i think i should be fine with the 20c?
Old Jul 29, 2012, 12:18 AM
DaxFX is offline
AIMDROIX
DaxFX's Avatar
Joined May 2008
Stock setup will pull 25-26amps. So you are fine with 20c 2200mah. enjoy your p47
Old Jul 29, 2012, 12:51 AM
Moonbeam is offline
Find More Posts by Moonbeam
352nd FG Association
Moonbeam's Avatar
United States, GA, Decatur
Joined Mar 2004
Banged up my jug earlier this week after the motor (the new one with only 17 flights on it), crapped out forcing a very quick emergency landing. After touching down with a hung bomb preventing me from using flaps, she rolled into a curb before I could turn the thing. A friend & I were flying from an emtpy school parking lot that was HUGE! You'd think I coulda missed a friggin curb!
Didn't have room where I was at that point, nor time to line up a better approach. It was "land or crash...... NOW!", which wouldn't have been a big deal if I were over the grass area.
Damaged the right wing tip (already repaired), scuffed the cowling paint (also touched up), bent the right main gear (fixed that too!), but the motor is toast. I'll get with HH on that, but it was sounding "buzzy" on the last pass before it started suddenly losing power which forced an immediate landing. It now makes a very nasty sounding "grinding" noise. It's clear something came apart inside, but I can't get the grub screws out (without risking stripping them, which I guess really doesn't matter since it's shot), to look it over.
So I'm debating getting another stock motor, or an eqivalent aftermarket one. I'm not looking to make an F-16 out of the ole jug. It's stock speed with the Extra 300 prop was satisfying enough, that's really all I'm looking for. My brother found these two options (below). Are any of you using one of these two motors or have an idea if they'd be adequate? (One review mentions the PZ P-47, but not that he actually put it on THAT airframe. Just a speed comparison).
http://www.hobbypartz.com/86mb92-3020-950kv.html
Moonbeam is offline Find More Posts by Moonbeam
Old Jul 29, 2012, 01:15 AM
Joined May 2011
Okay cool thanks!
Old Jul 29, 2012, 10:25 AM
320pilot is offline
Find More Posts by 320pilot
320pilot's Avatar
Joined Mar 2009
Maidened my P-47 yesterday.
Flew it with no landing gear (except tail wheel). Stock motor, prop, Esc and a 3S-2100-25C TP LiPo.
Hand launch was easy, though it felt a little tail heavy in the air with the CofG at 60 mm. Not as stable in pitch, I thought as my Sea Fury. I still want to put some invasion stripes on the upper wing, to help with orientation at a distance. Maybe a yellow cowl, too.
I will fly it with hand launches, and no gear a bit more, play with the C of G then put in the E-flite retracts.
When I cut the power, to land in the long grass it settled pretty quickly..not much float like the Sea Fury. 6 minute flight with stock prop/motor/Esc took 655 mAh out of the 2100 LiPo. That was flown at 1/2 throttle, so power to spare.
My friend who threw the maiden toss, said it felt big to throw ( he has the PZ P-51)
320pilot is offline Find More Posts by 320pilot
Old Jul 29, 2012, 12:37 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
What's everone's favorite CG for the plane?
thanks
brushless55 is offline Find More Posts by brushless55
Old Jul 29, 2012, 05:52 PM
Bluhammer is offline
Find More Posts by Bluhammer
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
I've read this whole thread and have been a Bolt pilot for quite awhile now, but was very surprised this weekend. My friend Tom just rebuilt his Bolt with all new airframe, ESC, and motor. No flaps or retracts.
What surprised me is that he put in a 870kv P-25 and a after market 30A ESC!
I assumed the P-25 would need more of a ESC and CG adjustment.
When I put my watt meter on it only pulled 22A WOT static. I forget the watts but I'm sure it was less then 270. Anyway, with normal CG (2100mah 30C 3S) it flew great. With the stock prop it pulls a nice strong vertical, way better then my stock motor P-47. I'm very impressed with the P-25 performance, and expected more draw on the system. I'm up for one now.
Blu
Bluhammer is offline Find More Posts by Bluhammer
Old Jul 29, 2012, 08:16 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
Moonbeam, you broke a magnet loose
JDMJim is offline Find More Posts by JDMJim
Old Jul 29, 2012, 08:31 PM
320pilot is offline
320pilot's Avatar
Joined Mar 2009
Flew some more this evening
Did my first solo hand toss, it climbs out very sedately initially at WOT, then picks up speed. I pitch it up about 15 degrees as I toss it..
I moved the CofG forward a mm or two, seemed to fly better.
Not as nimble in the air as my Sea Fury though.
They did the second cut in our field, so now we have to line up to hit a winrow on landing...
Old Jul 29, 2012, 09:23 PM
10AE is offline
Find More Posts by 10AE
Georgetown IN
Joined Jul 2010
I am not familiar with those, but I have flown the G15 in a PZ P47. It works great IF you get a good one. They are tempting at $27 or so, but cross your fingers when you buy them....
10AE is offline Find More Posts by 10AE
Old Jul 29, 2012, 09:47 PM
copperbricks is offline
Find More Posts by copperbricks
You can't take the sky from me
copperbricks's Avatar
United States, OH, Cincinnati
Joined Aug 2011
I've been using a g15 with an extra 300 prop for a while. Pulls around 35 amps, and is only a little bit faster than the stock motor with the same prop. Another option if you wanted a brand name motor wouldbe an e-flite power 15. Both Motors are 950kv, same as stock. The G15 is available from Hobbyking.
copperbricks is offline Find More Posts by copperbricks
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 09:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
