Old May 17, 2012, 09:55 PM
md1963 is offline
Find More Posts by md1963
Ack!
md1963's Avatar
Maryland
Joined Feb 2011
Hi all, I'm ready to try a 4S but I'm a little confused about what type as far as voltage, mAh, etc. I've got the G25 870kv with Plush 60A ESC, retracts and flaps, and plan to use a Extra 300 prop with the 4S. Currently I'm using 3S 2200 mAh 11.1V and getting 8-9 minute flights with the stock prop and about half that with the 300 prop. What type of 4S and 300 prop combination would get the same flight time (at least 8-9 min)? I'm not so concerned with more speed although a little more wouldn't hurt. I usually run at 75% throttle with a few WOT bursts. Thanks!
md1963 is offline Find More Posts by md1963
Old May 17, 2012, 10:00 PM
papabatman is offline
Find More Posts by papabatman
Shut up and fly
papabatman's Avatar
United States, CO, Dacono
Joined Jun 2008
4s big jump in speed also you would need 3300mah or so 25c. if your running 75% throttle you would be doing about 50% on 4s with some fast bursts. everything you have now looks good for a 4s set up. that is a big battery hope your good at landing lol just kidding move the battery back a bit should be fine
papabatman is offline Find More Posts by papabatman
Old May 17, 2012, 10:09 PM
DaxFX is online now
Find More Posts by DaxFX
AIMDROIX
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
Any 1 have try the 10x10e on stock setup?
DaxFX is online now Find More Posts by DaxFX
Old May 17, 2012, 11:09 PM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
Yes a 10x10e has been done, but so will your stock setup.
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old May 17, 2012, 11:50 PM
scootrb4 is offline
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
MD 1963, I have used the 2200 and even the 1800mah 4s with similar motor & esc in similar PZ birds. (T28 & Spitfire) The 1800mah turnigy nano tech 25-50C Weighs and sizes the same as the 3s2200. If you fly mostly 1/2 throttle with bursts of excitement you can fly 5-6minutes. This battery fits right in without any COG mod.
The 2200mah 4s is a little heavier and will require repositioning... You will want a smaller prop when you go up in voltage(higher rpms). Big props are for slower turning motors.
scootrb4 is offline Find More Posts by scootrb4
Old May 18, 2012, 12:15 AM
Shut up and fly
papabatman's Avatar
Joined Jun 2008
isn't the extra 300 prop 10.5x9 not that big same as a 10x10. 870kv motor on 4s should be well with in its limits. i have ran 4 blades with that motor on 4s. always check your watt meter to be sure.
Old May 18, 2012, 12:20 AM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
I tried the 10x10e on my power10 3s wildcat, It sure pulled and sped but it did tap the mila-amps
Old May 18, 2012, 12:29 AM
Shut up and fly
papabatman's Avatar
Joined Jun 2008
power 10 1100kv your at it's max there
Old May 18, 2012, 12:30 AM
neck is offline
Find More Posts by neck
Jeremy-I'm crash proof!
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
You guys with the 4s setup...post some pics. No idea how you got 4s in there.
neck is offline Find More Posts by neck
Old May 18, 2012, 12:36 AM
Shut up and fly
papabatman's Avatar
Joined Jun 2008
4s 4200mah
100amp opto esc
ubec in there to
Old May 18, 2012, 09:32 AM
Shut up and fly
papabatman's Avatar
Joined Jun 2008
i should mention all the foam i carved out too
Old May 18, 2012, 11:27 AM
Syner01 is offline
Find More Posts by Syner01
United States, NJ, Lodi
Joined Jan 2012
I don't have any pics right now but it is a direct fit for me (I only have 850, 1000, and 1300mah 4s though).
Syner01 is offline Find More Posts by Syner01
Old May 18, 2012, 02:04 PM
7rider is offline
Find More Posts by 7rider
7rider's Avatar
USA, CA, Mountain View
Joined Dec 2007
4s 4200mah
100amp opto esc
ubec in there to
Egads! High speed dives with that plane must be fun
No need to cut any foam with 4S 2200 batteries.
7rider is offline Find More Posts by 7rider
Old May 18, 2012, 02:27 PM
Shut up and fly
papabatman's Avatar
Joined Jun 2008
inverted low high speed pass too
Old May 18, 2012, 04:52 PM
md1963 is offline
Ack!
md1963's Avatar
Maryland
Joined Feb 2011
Many thanks for the help guys, I'll post the results...!
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 09:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
