Old May 16, 2012, 02:26 PM
neck is offline
Find More Posts by neck
Jeremy-I'm crash proof!
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
Originally Posted by quitcherbitchen View Post
Why?
Not really the place to discuss this... P47.
neck is offline Find More Posts by neck
Old May 16, 2012, 02:30 PM
DaxFX is offline
Find More Posts by DaxFX
AIMDROIX
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
Originally Posted by DaxFX View Post
How the jug flyes with pz corsair 3blade prop? I just buy 1 for my trojan but endup on my jug.
Back to topic !! Anyone?
DaxFX is offline Find More Posts by DaxFX
Latest blog entry: Puerto Rico Drone Prix 2016
Old May 16, 2012, 02:39 PM
ddog343 is offline
Find More Posts by ddog343
ddog343's Avatar
United States, WI, Oconomowoc
Joined Feb 2011
I flew my Maiden with the Corsair 3 Bladed Prop.... Vid's up on my blog...
I also built as an airframe only kit, so I used a Apprentice motor... Flight was great and very "scale" I broke the Corsair Prop as I taxied back...nose over
Changed out to a Mas 11x7x3, and been lovin it since. I'm also running a 60amp esc. Hope this had helped, GdLuck
ddog343 is offline Find More Posts by ddog343
Old May 16, 2012, 03:31 PM
malden86 is offline
Find More Posts by malden86
malden86's Avatar
San Antonio, TX.
Joined Feb 2009
A friend of mine flys his stock P-47 with the 3 bladed prop from the Parkzone BF-109 and it flys great. It seems to be very efficient with this set up, he gets around 8 minutes flight time on a 3s 2200 battery.
malden86 is offline Find More Posts by malden86
Old May 16, 2012, 04:19 PM
DaxFX is offline
AIMDROIX
DaxFX's Avatar
Joined May 2008
Yea looks kinda weak prop. Since i run mine from solid paviment i never had a noseover. Knocking wood on.
I will test on my megameter and post result.
I like the look. Not a 4 blade but at least looks much better than stock.
Old May 16, 2012, 04:41 PM
ddog343 is offline
ddog343's Avatar
Joined Feb 2011
Ck out my post , this thread #10951, I posted my wattmeter readings, might help
Old May 16, 2012, 08:11 PM
DaxFX is offline
AIMDROIX
DaxFX's Avatar
Joined May 2008
Could you quote that post please. I read the forum on tapatalk in my iphone and dont know how to go to a specific post.
Old May 16, 2012, 10:16 PM
jimmyzrx is offline
Find More Posts by jimmyzrx
jimmyzrx's Avatar
United States, MO, Joplin
Joined Apr 2012
Congrats on the successful "deadstick ldg" Always good for a couple of skipped beats... Here's some of my Watt Meter readings... I'm flying with an Apprentice replacement Mtr so the readings will be very simular. Also I'm running a 60Amp Emax ESC.
Stock 2blade ......9.5x7.5 ....249.5watts ....... 20.9 Amps -in-Flight
Corsair 3blade ......9x7.5x3 .....292.4watts ....... 25.2 Amps "
MAS 3blade .......10x7x3 .....284.9watts ........ 23.5 Amps "
MAS 3blade .......11x8x3 .....399.5watts ........ 34.5 Amps "
MAS 3blade .......11x7x3 .....370.3watts ........ 34.4 Amps -Static/Bench
I've continued to fly with the MAS11x7x3 through-out all last season. Just dosn't look right flying this warbird on a 2blade prop..too me anyhow... Also I fly exclusively off grass and I fine the Master AirScrew 3 bladed props to be exceptionaly durable....real hard to break, you gotta really be trying... Anyway hope this helps you...
here you go
jimmyzrx is offline Find More Posts by jimmyzrx
Old May 16, 2012, 10:33 PM
DaxFX is offline
AIMDROIX
DaxFX's Avatar
Joined May 2008
Originally Posted by jimmyzrx View Post
here you go
Yes but those are from ecalc. Not real test?
Old May 16, 2012, 11:18 PM
jimmyzrx is offline
jimmyzrx's Avatar
Joined Apr 2012
this is post 10951 sorry if its not the one you needed
Old May 16, 2012, 11:26 PM
DaxFX is offline
AIMDROIX
DaxFX's Avatar
Joined May 2008
Dont worried. Thanks.
I will test tomorrow to have a real results.
Old May 17, 2012, 05:20 AM
Hexperience is offline
Find More Posts by Hexperience
devIAtion..one TX to bind them
Hexperience's Avatar
Canada, ON, Georgina
Joined Aug 2011
The person who posted those said it was from a watt meter. I was the one who posted the ecalc results.. Which were very close by the way. Good to know ecalc is accurate.
Anyway, I've broken 2 corsair props on nose overs.. Grass field and more than 2 blades don't mix.
Hexperience is offline Find More Posts by Hexperience
Old May 17, 2012, 09:13 AM
ddog343 is offline
ddog343's Avatar
Joined Feb 2011
Dax, only the last test was "Static/Bench" the others are "In-Flight".... Sorry bout the delay, was out flyin...
Old May 17, 2012, 09:30 AM
ddog343 is offline
ddog343's Avatar
Joined Feb 2011
Hex, when you get a chance, try a Mas 3xProp... I've been flying the F4f, Corsairs, and the Jug on those props and have yet to brake one on landing... That's including 3 gear-up landings with the Jug... Strange happenings a couple days back, after a week of rain here, my grass was as long as it ever gets. I flew the Corsairs through 6 paks, with only a taxi nose over... Then I cut the grass the next day, flew the Corsairs again and couldn't keep em standing... 3 batteries and 10/12 nose overs...
Can only attribute that to not being able to cut the grass as short as I normally do.
Anyhow, cannot recall ever breaking a Mas 3x prop on a landing.... unless it was in a tree!
Old May 17, 2012, 10:07 AM
anj4de is offline
Find More Posts by anj4de
Bavaria, Germany
Joined Nov 2008
HK 4-blader anybody?
Hi guys
I just repaired my Jug...only minor stuff...and put a new prop on. I used the HK 4 bladed prop that usually comes with their Durafly war birds. Quick measurements showed 34A at the start, after about 20sec it came down to 28A or so. The battery was a bit old already. Has anybody flown that combo already? I have the stock motor in it but a 60A ESC with a 5A external BEC in mine.
cheers
Uwe
anj4de is offline Find More Posts by anj4de
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 09:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
