Old May 08, 2012, 11:58 AM
DaxFX is online now
Find More Posts by DaxFX
Play tetris with my english
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
Originally Posted by Old Nick View Post
I am, about 30 flights so far with no problems. Am in UK so probably colder than where you are, may make a difference.
i emailed horizon and they told go ahead with no problem .. so im on,
DaxFX is online now Find More Posts by DaxFX
Old May 08, 2012, 12:13 PM
tengarang is online now
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
San Jose, California
Joined Aug 2010
Originally Posted by Hexperience View Post
Buddy code for HK P47 4 blade prop.
http://www.hobbyking.com/buddy.asp?c...C-12EFA861B3FA
DO you know whether if this will fit the stock parkzone motor shaft? Also will it fit on the power 25 shaft? both motors have similar shaft sizes I believe...
tengarang is online now Find More Posts by tengarang
Old May 08, 2012, 01:43 PM
DaxFX is online now
DaxFX's Avatar
Joined May 2008
i a looking for a reamer to my p47 trojan stinson carbonz yak. wich one do i nedd.
from 7mm to 10mm will be god?
Old May 08, 2012, 02:22 PM
Hexperience is online now
Find More Posts by Hexperience
devIAtion..one TX to bind them
Hexperience's Avatar
Canada, ON, Georgina
Joined Aug 2011
Just ordered them today so I'll try to remember to report back on that... but if anything it looks smaller which is good.
Keep in mind, these are 10x8x4 and would be too much draw for the stock esc... (I think... ) The HK p47 uses a 35a esc and a 750kv motor, I'll be using those props on a power25(870kv) and 40a esc.
Hexperience is online now Find More Posts by Hexperience
Old May 08, 2012, 03:24 PM
copperbricks is offline
Find More Posts by copperbricks
You can't take the sky from me
copperbricks's Avatar
United States, OH, Cincinnati
Joined Aug 2011
I might have to get in on those props, they look awesome.
copperbricks is offline Find More Posts by copperbricks
Old May 08, 2012, 03:34 PM
Bluhammer is online now
Find More Posts by Bluhammer
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
35 flights all stock with flaps and retracts (Eflite), no problems, if you don't count hitting a tree!
Blu
Bluhammer is online now Find More Posts by Bluhammer
Old May 08, 2012, 03:35 PM
papabatman is offline
Find More Posts by papabatman
Shut up and fly
papabatman's Avatar
United States, CO, Dacono
Joined Jun 2008
trees don't count your good
papabatman is offline Find More Posts by papabatman
Old May 08, 2012, 03:48 PM
Joined Aug 2011
Wooh, I 'm still good too! I flew into some bushes on a overshot landing. believe it or not the p-47 is almost too floaty for my field. I just have a corner baseball field to touch down in, or the grass.
Old May 08, 2012, 03:50 PM
Shut up and fly
papabatman's Avatar
Joined Jun 2008
bushes are free to, but the fence isn't lol
Old May 08, 2012, 03:59 PM
Joined Aug 2011
Yep. It floated right over the fence, with about 6 inches to spare. What sucks about landing in the corner is that by the time I realize I'm coming in too hot, or off, it's too late to pull out. I just try to start my run as far out as possible, and then skim it along the grass and touch it down. My dynam t-28 is easier, it drops a lot faster.
Old May 08, 2012, 04:16 PM
tengarang's Avatar
Joined Aug 2010
Hey bud...yeah i intend on using the same motor as you with 45amp turnigy and seperate bec.
anxious to hear about it.
regards
tengarang
Old May 08, 2012, 04:32 PM
BRAND X is offline
Find More Posts by BRAND X
Name brands compare me...Why?
BRAND X's Avatar
United States, NJ
Joined Feb 2012
Stock is a 5mm shaft.
BRAND X is offline Find More Posts by BRAND X
Old May 08, 2012, 04:53 PM
tengarang's Avatar
Joined Aug 2010
yeah ill run the experiment with ya...ordered mine too...the stock is getting low...
im thinking to run 4s...but with a 40-45 amp maybe abit much....might have to do 3s what do you think....now we are dealing with 4 blades rather than 2.
on the stock motor for the jug and stock prop, with a 2200mah 4s im drawing 39 amps...but this is a 950KV...so you figure a 870kv might help the amp draw situation....4 blade durafly is like a 10x8? guess we will see...more amp draw compared to the stock jug prop for sure!
Old May 08, 2012, 04:56 PM
DaxFX is online now
DaxFX's Avatar
Joined May 2008
5mm is the motor shaft not the prop adapter shaft.. anyway thanks i did ordered the metric 7,8,10mm
Old May 08, 2012, 05:24 PM
Joined Aug 2011
P25 3S 9.5x7.5 =~ 20 amps
P25 4S 9.5x7.5 =~ 32 amps
P25 3S 10x8x4 =~ 36 amps <-- This is what I'm going to try
P25 4S 10x8x4 =~ 54 amps
P15 3S 9.5x7.5 =~ 24 amps
P15 4S 9.5x7.5 =~ 39 amps
P15 3S 10x8x4 =~ 42 amps
P15 4S 10x8x4 =~ 63 amps
My main concern is the weight. I don't want to adversely effect the handling. It flys so great now, I don't want to mess it up. I was thinking about trying out 3S 3200's but I'm sure that will be too heavy and be a problem to fit in.
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 11:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 10:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 10:08 AM
