Old Mar 26, 2012, 10:32 PM
ViperZ is offline
Find More Posts by ViperZ
This is my Nemesis....
ViperZ's Avatar
Canada, SK, Saskatoon
Joined Jan 2011
Mine with the 4s pack and G-25 is more nose heavy in CG, but I fly it that way anyway. I have tried moving the pack back to be more balanced at the CG point, but I prefer this plane more nose heavy.
ViperZ is offline Find More Posts by ViperZ
Old Mar 26, 2012, 11:35 PM
Moonbeam is offline
Find More Posts by Moonbeam
352nd FG Association
Moonbeam's Avatar
United States, GA, Decatur
Joined Mar 2004
Originally Posted by Marshal Dillon View Post
As a new pilot without anything to compare the PZ Jug to, it's testimonials like yours, Edge, that reinforce that the perma-grin that I experience while flying the Jug is not just the noob in me bleeding through. The plane just looks majestic in flight and handles so nicely. I really appreciate the lower altitude fly bys when you get a real good look at the Jug and hear the prop and motor singing. I've been bit hard by the Jug Bug. Good times!
+100!!!
I've got 127 flights on mine and STILL get the "Perma-Grin" everytime I fly it. I still say the P-47 and the Stryker Q are the best two flying Parkzone planes I've ever flown. (Closely followed by the P-51). And I've flown almost all of them.
Moonbeam is offline Find More Posts by Moonbeam
Old Mar 27, 2012, 01:46 PM
biggles2 is offline
Find More Posts by biggles2
Dark lord of the Sith
biggles2's Avatar
Joined Feb 2011
Parkzone Thunbderbolt camP-47Mahurin.wmv (5 min 10 sec)
Just thought i would share alittle vid of my tail mounted cam on my razorback.Think it got alittle buffeted by the prop but kinda like how it looks
biggles2 is offline Find More Posts by biggles2
Old Mar 27, 2012, 04:30 PM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
guys, would a Power 10 equivalent, ie the Hobby King G10 on 3-4S, be enough to power this plane?
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Mar 27, 2012, 05:13 PM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
Probably not
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Mar 27, 2012, 07:38 PM
V2rider is offline
Find More Posts by V2rider
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
I would say the 810kv version of the G10 would work. Turning an 11x8 apc it looks pretty close to stock figures. 61oz thrust, 25 amps, pitch speed of 60mph and mixed flight times of about 13 minutes. Stick a 4s in with the same prop and it should pull about 39 amps, give 98oz thrust with a pitch speed of 76mph, flight times drop to about 8.5 minutes. Figures are from ecalc with a 25c 3300ma pack.
V2rider is offline Find More Posts by V2rider
Old Mar 27, 2012, 07:51 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Cool thanks
I use it in a T28 now with 11.7 prop, but can use a 12" prop if wanted.
Very strong motor on 4S;
Old Mar 27, 2012, 09:33 PM
Marshal Dillon is offline
Find More Posts by Marshal Dillon
Joined Jan 2012
Originally Posted by Moonbeam View Post
I've got 127 flights on mine and STILL get the "Perma-Grin" everytime I fly it....
I've only got 120 flights to go to catch up to you, M-beam.
Marshal Dillon is offline Find More Posts by Marshal Dillon
Old Mar 27, 2012, 09:58 PM
md1963 is offline
Find More Posts by md1963
Ack!
md1963's Avatar
Maryland
Joined Feb 2011
Originally Posted by Retiredtech View Post
Would someone please answer netdudeuk's questions. More of us would like to know exactly where to measure the CG from, i.e. is the manual correct in the measurement being from the farthest most forward point of the wing where it meets the fuselage (root)?
RT
I thought I read somewhere in this thread that the graphic in the manual was wrong but the dimension was correct; in other words the CG is 60mm but it should be measured from the leading edge of the wing, and not where the wing root meets the fuselage at the mounting point. It's about a 12mm difference.
md1963 is offline Find More Posts by md1963
Old Mar 27, 2012, 10:06 PM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
Could be, however typically most CG measurements are at leading edge, measured from the point where the wing meets the fuse. This is because most wings leading edges generall sweep backward from the root to tip.
The point is with this plane 12mm will not be a lot of difference, especially when it's 12mm less. As I said, my plane is nose heavy and flies fine. With enough power anything will fly
Old Mar 27, 2012, 10:09 PM
md1963 is offline
Ack!
md1963's Avatar
Maryland
Joined Feb 2011
Originally Posted by 013531 View Post
Hey guys,
I thought I'd post some pics of my re-built P-47 following a nose in. New wings and fuze and my first go at airbrushing. Did some invasion stripes, colour on the cowl and rudder. I'm quite happy with how it turned out. Due to re-maiden it this weekend depending on the weather.
I've also fitted the Turnigy G25 870Kv motor and 60 amp Plush ESC. It seems the standard prop adaptor fits, but sticks out a bit further as the new motor is a little longer. Is this what others have experienced?
Darren
Nice job! I have the same motor/esc but I'm using the hardware that came with the G25 and it doesn't stick out so much. This configuration is pretty nose heavy on mine; I had to move the battery, RX, and elev servo aft to get the CG in range.
Old Mar 27, 2012, 11:12 PM
aquaanox is offline
Find More Posts by aquaanox
United States, MD, Rockville
Joined Feb 2010
how are folks mounting the key cams (808) on their p47. Any pics ?
aquaanox is offline Find More Posts by aquaanox
Old Mar 28, 2012, 07:03 AM
dav3uk is offline
Find More Posts by dav3uk
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Velcro/rip strip.....easy
Dave
dav3uk is offline Find More Posts by dav3uk
Old Mar 28, 2012, 01:32 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
The guys at our field have done it. I believe it was a 1100 kv E-flite Power 10
No speed demon but works just fine.
TripleW is offline Find More Posts by TripleW
Old Mar 28, 2012, 04:03 PM
copperbricks is offline
Find More Posts by copperbricks
You can't take the sky from me
copperbricks's Avatar
United States, OH, Cincinnati
Joined Aug 2011
Although you would need to use washers to bring the motor out a little further, I would think
copperbricks is offline Find More Posts by copperbricks
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 09:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
