Espritmodel.com Heli Air
Old Mar 04, 2011, 05:53 PM
McCleary.11's Avatar
United States, OH, Delaware
Joined Mar 2006
Looking into buying one of the alternatives to the E-flite retracts, and I was wondering if the HK/CS retracts include the adjustable axles like the E-flites do? Might just bite the bullet and put the money down for the E-flites...
Edit: To answer my own question, yes I need to buy them. Du-bro makes some.
McCleary.11 is offline Find More Posts by McCleary.11
Old Mar 04, 2011, 06:06 PM
NEVER GIVE UP!
Brooklynstar23's Avatar
Brooklyn, NY
Joined Nov 2010
Am I missing something in regards to removing the spinner nut? I put a 2.5 mm hex driver in to get leverage the same one I use on my parkzone corsair and it's on there so tight it actually bent the hex driver!!! What gives?
Brooklynstar23 is offline Find More Posts by Brooklynstar23
Old Mar 04, 2011, 06:15 PM
AMA 884978
hillbille's Avatar
United States, CA, Barstow
Joined May 2007
It's like your wife or GF (or anyone using the standard prybar lug wrench in most cars!)trying to loosen the lug nuts from a wheel after the tire shop guys put them on with air impact wrenches!! LOL!!
It was assembled with a machine - tight - and you need to be very careful taking it off!! Might break the prop if you are not careful too! I used a pair of slip joint pliers on the aluminum backing and a small phillips screwdriver to break mine loose.
Hillbille
hillbille is offline Find More Posts by hillbille
Old Mar 04, 2011, 06:17 PM
GEEBEE Can't WAIT!
perschek's Avatar
USA, OR, Seaside
Joined Dec 2010
Nope I had the same problem, bent a hex driver and a small screwdriver.
I found the stock landing gear works great but the L bent part into it and loosten it. Or a screwdriver just slightly smaller than the hole otherwise it will bend.
perschek is offline Find More Posts by perschek
Old Mar 04, 2011, 06:21 PM
GEEBEE Can't WAIT!
perschek's Avatar
USA, OR, Seaside
Joined Dec 2010
WELL BOYS
It's been fun, going on active duty for a few months, no airplanes :-( well not unless I can fly the armys shadow 500 or something but thats not happening :-(..
Hope you guys enjoy yourselves, can't wait to hear what you all have to say about the Hawker Hurricane!! Should be out long before I get home.
Have fun, FLY SAFELY, SEND THOSE LETTERS TO CONGRESS! see AMA website, it's easy all over the internet, send one from you and then forward to all family and friends!
http://www.modelaircraft.org/aboutama/gov.aspx
Sorry if this has already been posted here, just want to make sure you guys get your e-mail letters in to help the hobby out.
Ben
Old Mar 04, 2011, 06:28 PM
Jimmy
Jimmy1159's Avatar
United States, NJ, Highland Lakes
Joined Oct 2008
Good Luck P, Gods Speed
Jimmy1159 is offline Find More Posts by Jimmy1159
Old Mar 04, 2011, 06:41 PM
NEVER GIVE UP!
Brooklyn, NY
Joined Nov 2010
Hillbille
LOL dude this thing is NOT coming off!.....I remember how difficult was to get my PZ Corsair's prop off the first time but this is just insane...ill give it a rest for now....going to paint the guns and servo protectors in the meantime...and i just finished positioning my ar7000 in her cant wait for the maiden
Old Mar 04, 2011, 06:42 PM
NEVER GIVE UP!
Brooklyn, NY
Joined Nov 2010
Originally Posted by perschek View Post
WELL BOYS
Ben
Good luck to you and thank you for your service to our country!
Old Mar 04, 2011, 06:45 PM
Joined Mar 2011
Quick question. I have the Dx5e for now and tried the Y-harness trick to enable retracts and flaps. Unfortunately, they are opposite of each other. When I bring the landing gear down, the flaps go up, and vice-versa.
Is there a way to get them to work together? Flaps down, gear down. Flaps up, gear up.
Thanks in advance.
_jocko_ is offline Find More Posts by _jocko_
Old Mar 04, 2011, 06:46 PM
Lilienthal's Avatar
Littleton, CO
Joined Nov 2010
Good luck Perschek and thanks for your service.
Lilienthal is offline Find More Posts by Lilienthal
Old Mar 04, 2011, 07:16 PM
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
Thanks in advance.
Try unplugging the retracts, cycle the switch and then plug them back in. If that doesn't work it looks like the retracts and servo is looking for different signals. If that is the case you may be able to use a servo reverser on the flaps to get them in sync with the gear. http://www.horizonhobby.com/Products...ProdID=EXRA325
V2rider is online now Find More Posts by V2rider
Old Mar 04, 2011, 07:51 PM
Joined Mar 2011
Thanks.
I'll give that a go but see a 6 channel TX in the near future.
Old Mar 04, 2011, 08:28 PM
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
Thanks.
If you have even thought of going to bigger planes take a look at the E-Flite T-34 RTF. Comes with the DX6i and is a real sweet flying plane. Retracts are not an easy option but can be done.
Old Mar 04, 2011, 08:40 PM
Joined Mar 2009
Be safe Perschek and my thanks too.
MikeSawicki is offline Find More Posts by MikeSawicki
Old Mar 04, 2011, 09:05 PM
Electric since 1990
Foamaholic's Avatar
East Central Ohio, United States
Joined Jun 2004
Have a good tour and take care.
Foamaholic is offline Find More Posts by Foamaholic
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 09:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
