Old Mar 03, 2011, 07:26 PM
ryramZ is offline
Find More Posts by ryramZ
Your Pilot Ryan
ryramZ's Avatar
United States, IN, South Bend
Joined Nov 2008
Originally Posted by Brooklynstar23 View Post
Has anyone tried these batteries?
http://hobbyking.com/hobbyking/store...dProduct=16692
Also how much flight time am I looking at with 2200mah 25c zippy battery? mixed throttle flying of course, i hope its not less than 5 mins
Yes except I got mine from the USA warehouse and there turnigy not zippy. They seem long. They are 70 grams heavier than the stock battery but being longer, the weight was spread out. Cg did not seem to be affected at all no trimming was needed and the plane seemed to respond well to the extra weight. It was very windy. The price is right don't be scared.
ryramZ is offline Find More Posts by ryramZ
Old Mar 03, 2011, 08:15 PM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Well I am officially a part of the family now, I have my Wildcat and now my P47 can't wait to try her out!
IndyMatt is offline Find More Posts by IndyMatt
Old Mar 03, 2011, 08:21 PM
hillbille is offline
Find More Posts by hillbille
AMA 884978/KK6NKY
hillbille's Avatar
United States, CA, Barstow
Joined May 2007
Lubrication. Do not use any oils or "grease" on your retracts. Oil and grease attract and collect dirt, sand and grime and will cause undo wear on exposed moving parts. Do NOT use GRAPHITE either!! Graphite is conductive and will short out and destroy your retract!! LOL!!
I suggest using a lithium grease - very lightly applied using a toothpick or such to any areas seen to be "rubbing" or binding. Less is good as only enough is needed to lubricate the part and not so much that it is scraped up or piled up. Wipe away any excess.
Hillbille
hillbille is offline Find More Posts by hillbille
Old Mar 03, 2011, 09:09 PM
TMO is offline
TMO
Find More Posts by TMO
TMO
TMO's Avatar
Stonington, Ct.
Joined Nov 2001
I agree. I would call lubrication a last resort before a phone call to hh customer service. If you do it, do it as hillbille describes.
(It really doesn't need it, and if you get stuff caught up in there (like I do all the time- dust, pebbles, bits of grass) I just hit it with some canned air. Mine sound like a rock crusher, but they sounded that way out of the box and I can't hear it when I'm on final when the gear's coming down anyway.)
Hillbille
TMO is offline Find More Posts by TMO
Old Mar 03, 2011, 09:47 PM
kbuzz1 is offline
Find More Posts by kbuzz1
kbuzz1's Avatar
United States, PA, Greensburg
Joined Dec 2010
Yes as a matter fact I did do a little coloring - used a silver sharpie to cover the black plastic of the retract.
Hillbille
This airplane should come with a silver sharpie. I've touched up little scrapes, colored gorilla glue after repairs (pretty cool, actually looks like a weld line), and best of all I hit up all the panel lines with a double coat and the subtle difference in hue adds a nice shadowing effect. Highly recommended.
kbuzz1 is offline Find More Posts by kbuzz1
Old Mar 04, 2011, 12:24 AM
Need2Fly is offline
Find More Posts by Need2Fly
USA, AZ, Phoenix
Joined Feb 2011
Well I did my maiden flight yesterday and all went well.
I flew three times, two with the stock battery and one with a lightermax 2200 15c.
I have the stock ESC with a CC BEC, a power-15, flaps and retracts.
I set the CG at 60 from the panel line closest to the fuse. With this CG I did not have any type of nose over issues. When I did the CG as shown in the manual it wanted to nose over on the black top in front of my house. The flying field is dirt and I did not need to use up ele while taxing. I used the stock prop even though I bought the extra 300 one. I hope the 300 works better, I thought the stock prop seemed a little slugish.
I love the flaps for landing it slows down nice. I set the timer for 8 min count down and had lots of battery left after the flights. I did some WOT but not alot as I wanted to get use to the plane. I need to get some more and bigger batteries, I think I'll try the 3300s.
All in all a great plane that flys great, just need more time to fly.
Need2Fly is offline Find More Posts by Need2Fly
Old Mar 04, 2011, 12:25 AM
Gotlieb is offline
Find More Posts by Gotlieb
3D and slope Pilot in training
Gotlieb's Avatar
Port Elizabeth South Africa
Joined Nov 2010
Heee heee ordered mine yesterday....
Soon i will have all the Parkzone planes >
Gotlieb is offline Find More Posts by Gotlieb
Old Mar 04, 2011, 04:05 AM
James321 is offline
Find More Posts by James321
James321's Avatar
UK
Joined Nov 2009
Originally Posted by TFOA View Post
When I got back to the bench, I took the prop of to check it and low and behold it was a 12.5 X 8.5. What power! What performance! Too bad it sucked the electrons outta the 2200 pack so fast LOL
I'd be surprised if that wasn't the ESC starting to die running that prop!!
James321 is offline Find More Posts by James321
Old Mar 04, 2011, 09:54 AM
bcomo is offline
Find More Posts by bcomo
Texas
Joined Oct 2006
Nevermind. I found the answer to my question.
bcomo is offline Find More Posts by bcomo
Old Mar 04, 2011, 12:37 PM
Olias is offline
Find More Posts by Olias
Pushin' the Limits
Olias's Avatar
Bellingham,WA.
Been wanting to get one myself for touch ups as it's been mentioned a couple times now and seems to work well. Can you tell us what brand exactly as I know not all sharpies are foam friendly. And if there's a particular name/brand/model# or what ever of the particular silver that would be great (if needed). Thanks
-B
Olias is offline Find More Posts by Olias
Old Mar 04, 2011, 01:54 PM
perschek is offline
Find More Posts by perschek
GEEBEE Can't WAIT!
perschek's Avatar
USA, OR, Seaside
Joined Dec 2010
Sharpie Metallics Silver :-)
Only one kind of silver sharpie I'm aware of, works great for touch-ups on stock color
perschek is offline Find More Posts by perschek
Old Mar 04, 2011, 02:26 PM
fionabalogna is offline
Find More Posts by fionabalogna
Well experienced novice
fionabalogna's Avatar
Minneapolis
Joined Mar 2007
......and rule the world!!!
fionabalogna is offline Find More Posts by fionabalogna
Old Mar 04, 2011, 02:50 PM
TMO is offline
TMO
TMO
TMO's Avatar
Stonington, Ct.
Joined Nov 2001
Testors part# 2548C
(TESR2079 in the trade)
"Testors Enamel Paint Marker Metallic Silver"
It's a gloss, but you can't tell. This is a Paint Marker, not an Ink Pen.
BTW, sharpies work too, and indeed on this foam, they are safe.
-B
Old Mar 04, 2011, 02:59 PM
Olias is offline
Pushin' the Limits
Olias's Avatar
Bellingham,WA.
Originally Posted by TMO View Post
Testors part# 2548C
Thanks guys. BTW...where do you get a "Testors" paint marker at? The LHS?
-B
Old Mar 04, 2011, 03:10 PM
V2rider is offline
Find More Posts by V2rider
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
-B
Lhs, or Micheals or A.C. Moore, or whatever they call your local arts and crafts store.
V2rider is offline Find More Posts by V2rider
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 09:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
