Old Oct 20, 2010, 03:30 PM
gpsnow is offline
Find More Posts by gpsnow
Joined Aug 2010
Build Log
Building a Hexacopter with out a controller - Only with gyros - about 50 Pics
After reading quite a bit I ruled out a tricopter and a quad copter because of no redundancy.
My criteria that I wanted for my first multi copter were this :
1. Capable to lift 1.5 kg – 2.5 kg – inside this weight about 350 grams of FPV equipment and about 500-1000 grams of batteries
2. Strong relatively shock resistant structure that can withstand small bad landings
3. Slow stable flight for 15-30 minutes also in 100-300 meters altitude.
4. Simple electronics, No micro controller.
5. designing some sort of emergency system like 360 shock absorbers for a major crash – May be I need to envelope all the electronics with 2 halves of a basketball made from Epp or other shock absorber.
6. Simple props, 11X4.7 or 12X5
7. Maybe an emergency parachute.
8. Adding some sort of HD detachable camera mount, Probably Gopro HD.
9. No special opposite props, using parts that could be used for other rc planes in the future.
10. Redundancy , Redundancy, Redundancy !!!
After reading a lot I came to the conclusion that building a Hexacopter based on a double standard tricopter schematic using a standard 120 degree swash CCPM transmitter will fit all my demands.
This way I have 3 pairs of arms that even if any motor, Esc or prop will fail on any pair of arms the Hexacopter will stay in the air.
The only part that would not have a bacup unit are the 4 Gyro's needed.
gpsnow is offline Find More Posts by gpsnow
Old Oct 20, 2010, 03:40 PM
gpsnow is offline
Joined Aug 2010
Hexacopter pics
Here some pics of the build:
Old Oct 20, 2010, 03:54 PM
gpsnow is offline
Joined Aug 2010
Parts used so far :
26 cm diameter plywood – 137 grams
6 - 10X10 mm aluminum square rods – every rod 63 cm long – 74 grams each
3 short 12X7 aluminum rails for reinforcing the middle of the 26 cm plate – about extra 50 grams
14 - M4 hex screws with washers, nuts and safety washers – about 84 grams together.
All together the skeleton weighs about 740 grams.
Old Oct 20, 2010, 04:09 PM
gpsnow is offline
Joined Aug 2010
Here are the parts I ordered :
8 Turnigy 2217 motors (2 Spair) - http://www.hobbycity.com/hobbyking/s...idProduct=5691
5 Gyros (1Spair) - http://www.hobbycity.com/hobbyking/s...dproduct=10113
20 Props 12X6 - http://www.hobbycity.com/hobbyking/s...dProduct=10051
20 Props 11X4.8 - http://www.hobbycity.com/hobbyking/s...dProduct=10049
Trex 450 CNC main blade holder for tail axe sis - http://www.hobbycity.com/hobbyking/s...idProduct=9196
Trex 450 Plastic main blade holder for tail axe sis - http://www.hobbycity.com/hobbyking/s...idProduct=8529
Link set for rudder control for tail motors - http://www.hobbycity.com/hobbyking/s...idProduct=8535
8 ESC 30 units (2 spair) http://www.leaderhobby.com/product.asp?ID=9394001070001
2 Batteries 5000Mah 3S - http://www.hobbyking.com/hobbyking/s...idProduct=9184
Servo Y cables - http://www.hobbycity.com/hobbyking/s...idProduct=9690
30cm Extension cables for servos - http://www.hobbycity.com/hobbyking/s...idProduct=9705
60cm Extension cables for servos - http://www.hobbycity.com/hobbyking/s...idProduct=9689
Old Oct 20, 2010, 04:19 PM
gpsnow is offline
Joined Aug 2010
The concept is simple in the diagram
Black lines are actual rods with Motor, Esc and Prop
Red lines are imaginary gyro axe sis for 120 degree swash plate CCPM control.
Motors 1+2 are conected to gyro1(G1)
Motors 3+4 are conected to gyro2(G2)
Motors 5+6 are conected to gyro3(G3)
2 Servos near motors 5+6 and control the rudder are conected to gyro4(G4) - (Head lock)
Mix between motors 1+2 and motors 3+4 will give aileron control
Motors 5+6 will give forward backwards control
Another axe sis on motor 5+6 will give rudder control.
Any tips and comments will be appreciated.
Still didn't build skids for this monster – suggestions will also be appreciated.
Now I have to wait for all the parts for about 14 days.
Alex.
Old Oct 20, 2010, 05:30 PM
wizprod is offline
Find More Posts by wizprod
Denmark, Region Zealand, Sorø
Joined May 2010
I have just abandoned the gyro path with a tricopter... I spentt way too much time building and testing, than flying.. Went for Mikrokopter in quad Which will later be upgraded to an octo.
I really like your redundant approach, but with two Yaw mechanisms and two servos, its gonna be heavy (i would also use nylon screws if it was my build).
Another thing I like, is that you have redundancy if loosing a motor. Something a normal hexa cant without loosing Yaw authority...
However, for my AP application, having gps locks, height hold, built in nick and roll stabilized output for cameramount, the intelligent failsafes and proven components makes the choice easy for me..
Looking forward to some more pics of your build. Eventhough I wouldnt go That way myself, it's always a joy to be inspired by others!
wizprod is offline Find More Posts by wizprod
Old Oct 20, 2010, 06:16 PM
SSM is offline
SSM
Find More Posts by SSM
SSM
Voluntary Assumption of Risk
SSM's Avatar
Australia, VIC, Canterbury
Joined Nov 2003
Looking good Alex!
I'm very interested to see how this goes
Simon
SSM is offline Find More Posts by SSM
Old Oct 20, 2010, 06:55 PM
wizprod is offline
Joined May 2010
Oh, just noticed your gyro mounting, dunno if this is final mounting?
Old Oct 20, 2010, 07:38 PM
SSM is offline
SSM
SSM
SSM's Avatar
Joined Nov 2003
Gyro mounting looks good to me. They're on foam tape and they seem to be correctly positioned for a "virtual" tricopter
Simon
Old Oct 20, 2010, 11:02 PM
FlyingMcCoy is online now
Find More Posts by FlyingMcCoy
Joined Mar 2010
Subscribed
FlyingMcCoy is online now Find More Posts by FlyingMcCoy
Old Oct 21, 2010, 02:54 AM
gpsnow is offline
Joined Aug 2010
Gyro's locations are final.
I am going to add a 90 degree small mount for the Gyro's since they have a little deviation on the plastic when they are mounted vertically.
Tomorrow I'll connect servos temporarily instead of motors to calibrate and check the Gyros.
Old Oct 21, 2010, 04:29 AM
SSM is offline
SSM
SSM
SSM's Avatar
Joined Nov 2003
I usually put a double thickness of D/S foam tape to counteract that ridge when you mount the gyros on their sides.
Simon
Old Oct 28, 2010, 06:15 AM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
bump now get back to work on this project!
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Oct 28, 2010, 09:51 AM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Amazingly Interesting, watching with anticipation.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Nov 06, 2010, 06:51 PM
gpsnow is offline
Joined Aug 2010
Had some time to work on my hexacopter project, Here aresome Pics :
2 Short movies :
Hexacopter Tail Rudder before installing a servo (0 min 16 sec)
Hexacopter Tail Rudder after installing a servo (0 min 46 sec)
Still need to :
Properly install Gyros
Order proper props (GWS r 2 soft).
Organize the wiring
Build landing skids
Total weight ~1800 grams, 5000 mAH battery weighs another 430 Grams.
I need some help with setting up the remote :
I fixed the remote to a 120 degrees swash plate and every thing seems okay, the only problem is when I check the system on the ground when trying to go forward and backwards (ele) the front left arm also gets more or less power and the front right arm has the same power ???
could some advise me if I need to setup some sort of Mix ??
Discussion Hexacopter - with no controller board ? SSM Multirotor Talk 26 Jan 26, 2011 07:09 AM
Discussion I need help building a quadcopter or hexacopter lazer155 Coaxial Helicopters 17 Feb 23, 2010 09:47 AM
Discussion Hexacopter using microkopter controller lazer155 Coaxial Helicopters 2 Apr 15, 2009 10:50 PM
